A7139 拥有电磁波唤醒以及10mW的发射功率,非常容易实现长距离通信,目前测试有障碍物可以轻松达到300m以上。
通过几天的调试,目前可以发送任意大小的数据包,大小为1-16KB,全部使用中断收发,效率极高。
增加波特率设置2Kbps-100Kbps任意设置
增加通信信道设置0-255
增加发送功率设置0-7
#include “SYSTEM.H”
#include “GPIO_INIT.H”
#include “a7139.H”
#include “LED.H”
//晶振寄存器,用于设置晶振以及PAGE地址
//用于缓存寄存器7的值
static u16 A7139_CRYSTAL_REG = 0x18;
//单包数据发送超时时间
#define A7139_SEND_TIME_OUT 5 //单位10ms
//基础频率,设置频率范围为420.500MHZ~452.375MHZ ,频道差为125KHZ
#define A7139_BASE_FRE 420.5f
//调试开关
#define A7193_DBUG 1
#if A7193_DBUG
#include “system.h”
#define A7193_debug(format,。。。) uart_printf(format,##__VA_ARGS__)
#else
#define A7193_debug(format,。。。) /
#endif //A7193_DBUG
vu8 IntCnt = 0;
//寄存器配置
typedef struct
u16 SCLOCK; //系统时钟寄存器
u16 PLL1; //PLL1
u16 PLL2; //PLL2
u16 PLL3; //PLL3
u16 PLL4; //PLL4
u16 PLL5; //PLL5
u16 PLL6; //PLL6
u16 CRYSTAL; //晶振设置
u16 PREG8S; //寄存器组,由CRYSTAL控制切换
u16 PREG9S; //寄存器组,由CRYSTAL控制切换
u16 RX1; //接收设置1
u16 RX2; //接收设置2
u16 ADC; //ADC
u16 PIN; //PIN
u16 CALIB; //Calibration
u16 MODE; //模式控制
} A7139_CONFIG_YPTE;
const u16 A7139Config[]=
0x0021, //SYSTEM CLOCK register,
0x0A21, //PLL1 register,
0xDA05, //PLL2 register, 433.301MHz
0x0000, //PLL3 register,
0x0A20, //PLL4 register,
0x0024, //PLL5 register,
0x0000, //PLL6 register,
0x0001, //CRYSTAL register,
0x0000, //PAGEA,
0x0000, //PAGEB,
0x18D4, //RX1 register, IFBW=100KHz, ETH=1
0x7009, //RX2 register, by preamble
0x4400, //ADC register,
0x0800, //PIN CONTROL register, Use Strobe CMD
0x4845, //CALIBRATION register,
0x20C0 //MODE CONTROL register, Use FIFO mode
const u16 A7139Config_PageA[]=
0xF706, //TX1 register, Fdev = 37.5kHz
0x0000, //WOR1 register,
0xF800, //WOR2 register,
0x1107, //RFI register, Enable Tx Ramp up/down
0x0170, //PM register,
0x0201, //RTH register,
0x400F, //AGC1 register,
0x2AC0, //AGC2 register,
0x0041, //GIO register GIO1-》WTR GIO2-》WTR
0xD281, //CKO register
0x0004, //VCB register,
0x0A21, //CHG1 register, 430MHz
0x0022, //CHG2 register, 435MHz
0x003F, //FIFO register, FEP=63+1=64bytes
0x1507, //CODE register, Preamble=4bytes, ID=4bytes
0x0000 //WCAL register,
const u16 A7139Config_PageB[]=
0x0337, //TX2 register,
0x8400, //IF1 register, Enable Auto-IF, IF=200KHz
0x0000, //IF2 register, 频率偏移为0
0x0000, //ACK register,
0x0000 //ART register,
//GPIO1功能设置
#define A7139_SetGIO_WTR() A7139_WritePageA(A7139_REG8_GPIO, 0x0041) //WTR模式,单包收发提示
#define A7139_SetGIO_FPF() A7139_WritePageA(A7139_REG8_GPIO, 0x0035) //FPF模式,多包收发状态提示
#define A7139_SetGIO_NULL() A7139_WritePageA(A7139_REG8_GPIO, 0x0000) //关闭GPIO1指示
//发送数据结构
typedef struct
u8 *pSendData; //发送数据缓冲区指针
u16 SendLen; //需要发送数据长度
u16 TranLen; //已经发送数据长度
bool isSendOK; //发送完成
bool isSendError;//发送失败
}A7139_SEND_TYPE;
volatile A7139_SEND_TYPE SendConfig; //发送数据的信息
//接收数据结构
typedef struct
u8 *pRevData; //接收数据缓冲区指针
u16 RevLen; //需要接收数据长度
u16 TranLen; //已经接收数据长度
u16 RevBuffSize;//接收缓冲区大小
bool isRevOK; //接收完成
bool isRevError;//接收失败
}A7139_REV_TYPE;
volatile A7139_REV_TYPE RevConfig; //发送数据的信息
//收发模式记录,用于中断处理发送或接收模式
static bool isSendMode = FALSE; //默认为接收模式
#define A7139_SendMode(x) (isSendMode=x)
/*命令选择
地址格式
BIT7 BIT6-BIT4 BIT3-BIT0
R/W Command Address
0:写 000 读写控制寄存器
1:读 010 读写ID
100 读写FIFO
110 复位FIFO
111 RF复位
void A7139_SetBaseFreq(float RfFreq); //基础频率设置
bool A7139_Cali(void); //频率校准
* 函数 : void A7139_SetTrafficRate(u8 Rate)
* 功能 : A7139设置通信速率,单位Kbps
* 参数 : Rate:通信速率,单位Kbps
* 返回 : 无
* 依赖 : 底层宏定义
* 说明 : 用于设置通信速率
范围2-100Kbps
设置系统时钟2分频,设置为12.8MHZ后如果IFBW设置过小会导致初始化时自动校准失败
如果设置为50会出现校准失败
u16 SDR;
if(Rate 《 2) Rate = 2;
if(Rate 》 100) Rate = 100;
//IFBW设置 DMOS=1 64分频 ETH=1 CSC=0 FCSCK=12.8MHZ
if(Rate 《= 50) //IFBW=100KHZ
A7139_WriteReg(A7139_RX1, 0x18D0 | (1《《2));
else //IFBW=100KHZ
SDR = 100/Rate;
SDR -= 1; //计算波特率分频值
A7139_WriteReg(A7139_SCLOCK,0x0021|(SDR《《9)); //CSC=1 GRC=1 SDR
* 函数 : void A7139_SetChannel(u8 Channel)
* 功能 : A7139设置通信信道
* 参数 : Channel:通信信道0-255
* 返回 : 无
* 依赖 : 底层宏定义
* 说明 : 用于设置通信频道
Channel*0.125/0.0125,最小频率偏差为12.5KHZ,设置通道间隔为125KHZ(最少为100KHZ)
A7139_WritePageB(A7139_REG9_IF2,Channel*10);
* 函数 : void A7139_SetTxPowerSupply(u8 PowerSupply)
* 功能 : 设置A7139发射功率
* 参数 : PowerSupply:功率等级0-7
* 返回 : 无
* 依赖 : 底层宏定义
* 说明 : 用于设置发射功率
由于不同频率下TX驱动电流与PA驱动电流并不相同,因此按照文档设置
目前只支持433频段设置,其它频段请按照文档进行设置。
if(PowerSupply》6)PowerSupply=6; //最大功率为6
if(PowerSupply == 0)
A7139_WritePageB(A7139_REG9_TX2, 0x0300); //功率最小-34dBm,PAC=0,TDC=0,TBG=增益
else
A7139_WritePageB(A7139_REG9_TX2, 0x0300|(1《《5)|(1《《3)|PowerSupply); //PAC=1,TDC=1,TBG=增益
* 函数 : bool A7139_Init(u8 Channel, u16 RfID, u8 PowerSupply, u8 Rate)
* 功能 : A7139初始化
* 参数 : Channel:通信信道0-80,RfID:RF ID,PowerSupply:发射功率0-7;Rate:通信波特率2-100Kbps
* 返回 : TRUE:成功;FALSE:失败
* 依赖 : 底层宏定义
* 说明 : RF_ID:用于区分网络
2-100Kbps频率间隔至少为100KHZ,150~200KHZ频道间隔必须大于200KHZ
u32 ID;
u32 temp;
A7139_DisableInt(); //关闭中断
A7139_DisableNVIC(); //关闭总中断
A7139_IO_INIT(); //初始化IO
A7139_CS_H();
A7139_CLK_L();
A7139_DIO_H();
ID = RfID;
ID 《《= 16;
ID |= RfID;
A7193_debug(“[RF]频率:%dKHz, 通信速率:%dKbps, RFID:%X!rn”,(u32)(A7139_BASE_FRE*1000+Channel*0.125*1000),Rate, ID);
A7139_CRYSTAL_REG = 0x0001;
A7139_SoftReset(); //软复位
if(A7139_ReadID() != 0)
A7139_DelayMS(1);
A7139_Config(); //初始化寄存器
A7139_SetBaseFreq(A7139_BASE_FRE); //设置基础频率
A7139_SetChannel(Channel); //设置信道
A7139_SetTrafficRate(Rate); //设置通信速率
A7139_WriteID(ID); //写入ID
temp = A7139_ReadID(); //读取用户ID
if(temp != ID)
A7193_debug(“A7139 初始化失败,芯片检测错误!rn”);
return FALSE;
A7193_debug(“A7139 用户ID:%Xt硬件ID:%Xrn”,ID, A7139_ReadDeverID());
A7139_DelayMS(5);
if(A7139_Cali()==FALSE) //校准
A7193_debug(“A7139 初始化失败,校准失败!rn”);
return FALSE;
A7193_debug(“A7139 初始化成功!rn”);
A7139_SetTxPowerSupply(PowerSupply); //设置发射功率
A7139_EnableInt(); //开启上升沿触发中断
return TRUE;
* 函数 : void A7139_WriteByte(u8 data)
* 功能 : A7139写一字节
* 参数 : data:需要写入的数据
* 返回 : 无
* 依赖 : 底层宏定义
* 说明 : 不带片选,最底层写入1B
u8 i;
for(i = 0;i 《 8;i ++)
if(data & 0x80)
A7139_DIO_H();
else
A7139_DIO_L();
nop;nop;
A7139_CLK_H();
data 《《= 1;
nop;nop;
A7139_CLK_L();
* 函数 : u8 A7139_ReadByte(void)
* 功能 : A7139读取一字节
* 参数 : 无
* 返回 : 读取的数据
* 依赖 : 底层宏定义
* 说明 : 不带片选,最底层读取1B
u8 i;
u8 data = 0;
A7139_CLK_H();
data 《《= 1;
if(A7139_DIO_IN())
data |= 1;
nop;
A7139_CLK_L();
nop;nop;nop;
return data;
* 函数 : u16 A7139_ReadReg(A7139_CREG RegAddr)
* 功能 : 读取控制寄存器
* 参数 : RegAddr:寄存器地址
* 返回 : 寄存器值
* 依赖 : 底层宏定义
* 说明 :
u16 data;
RegAddr &= 0x0f; //地址限制为BIT0-BIT3
RegAddr |= A7139_RCR_CMD; //读命令
A7139_CS_L();
A7139_OutMode();
A7139_WriteByte(RegAddr);
A7139_InMode(); //输入
data = A7139_ReadByte();
data 《《= 8;
data |= A7139_ReadByte();
A7139_CS_H();
return data;
* 函数 : void A7139_WriteReg(u8 RegAddr, u16 data)
* 功能 : 写入控制寄存器
* 参数 : RegAddr:寄存器地址,data:要写入的值
* 返回 : 无
* 依赖 : 底层宏定义
* 说明 :
void A7139_WriteReg(A7139_CREG RegAddr, u16 data)
RegAddr |= A7139_WCR_CMD; //写命令
A7139_CS_L();
A7139_OutMode();
A7139_WriteByte(data》》8);
A7139_WriteByte(data);
A7139_CS_H();
* 函数 : u16 A7139_ReadPageA(A7139_PAGE_A RegAddr)
* 功能 : 读取控制寄存器组寄存器A
* 参数 : RegAddr:寄存器组地址
* 返回 : 寄存器值
* 依赖 : 底层宏定义
* 说明 : 寄存器组8
上一篇:STM32F407V芯片断电的时候FLASH被异常改写的解决方案
下一篇:Cortex-M3的STM32微控制器处理先进电机控制方法
推荐阅读最新更新时间:2026-03-05 11:33
- Sg1526单端配置的典型应用
- LT3663IMS8E、1.2V 降压转换器的典型应用
- AD8316-EVAL,AD8316 评估板,0.1GHz 至 2.5GHz,70dB 对数检波器/控制器
- LTM8003IY -5Vout 从 5V 到 35Vin 正负转换器的典型应用电路
- STEVAL-IHP005V1,基于 ST7540 PLM 和 STM32 微控制器的通用电力线调制解调器评估模块
- AD9248BST-40EB,用于评估 AD9248BSTZ-40、40Msps、14 位、双 ADC 的评估套件
- 使用 Semtech 的 SC338 的参考设计
- 相位/串行输入2相步进电机驱动IC —— TB62218AFG
- 适用于 75W 等效灯的 Cree XLamp XQ-D LED A19 灯驱动器参考设计
- EVAL-AD9832EB,用于评估 AD9832 直接数字合成器的评估板
stm32驱动屏IC rm68042
STM32 PMSM FOC 简介
基于STM32G031的测试测量训练平台完成虚拟仪器实现
现代雷达系统的信号设计
BFR340T
京公网安备 11010802033920号
