// TsRs485.c
// Test of RS485 network protocol
// Version 1.0 beta
// Processor: PIC16F87x
// Compiler: CCS PCM 3.02
#DEVICE PIC16F873 *=16
#include <16f873.h>
#define MASTER
#use delay(clock=4000000)
#fuses HS,NOWDT,PUT,BROWNOUT,NOPROTECT,NOLVP,NOCPD,NOWRT
#include #include #include //#include #include #use fast_io(A) #use fast_io(B) #use fast_io(C) #use fast_io(D) #use fast_io(E) char cTest[10]; //************************************************** // Timer Interrupt service routine //************************************************** #INT_RTCC clock_isr() { TMR0 = TMR0_RELOAD; // Reload PICs timer BIT_CLEAR( INTCON, T0IF ); // Clear interrupt flag } //************************************************** // USART interrupt service routine //************************************************** #INT_RDA void UsartInterrupt(void) { while ( BIT_TEST( PIR1, RCIF ) ) // If USART RX Interrupt { TMR0 = TMR0_RELOAD; cRs485RxChar = RCREG; if ( !( RCSTA & 6 ) ) // Then if no errors { // Process received character Rs485Decode(); // Decode RS485 network trafic bit_set( RCSTA, CREN ); // Enable receiver. } else { bit_clear( RCSTA, CREN ); // Clear any errors cRs485RxChar = RCREG; cRs485RxChar = RCREG; bit_set( RCSTA, CREN ); // Enable receiver. } bit_clear( PIR1, RCIF ); } } void main(void) { char cPacketReady; char cLenOfData; char cCmd, c; Setup(); BIT_CLEAR( INTCON, T0IE ); // Timer interrupts off #ifndef MASTER LcdWrite("Waiting........"); #else LcdWrite("Sending message"); #endif // Just setup the network address //write_eeprom( NET_ADDRESS_HIGH, 0x10 ); //write_eeprom( NET_ADDRESS_LOW, 0x10 ); //cOurAddrHigh = read_eeprom( NET_ADDRESS_HIGH ); //cOurAddressLow = read_eeprom( NET_ADDRESS_LOW ); while ( 1 ) { cOurAddrHigh = 0x10; cOurAddrLow = 0x10; Rs485Initialise( cOurAddrHigh,cOurAddrLow ); #ifdef MASTER cTest[0] = 'H'; cTest[1] = 'e'; cTest[2] = 'l'; cTest[3] = 'l'; cTest[4] = 'o'; cTest[5] = 0; ClearLine2(); LcdWrite("GET DATA PKT"); Rs485SendPacket( SENSOR_GET_DATA, 5, &cTest[0] ); delay_ms(250); delay_ms(250); delay_ms(250); delay_ms(250); ClearLine2(); LcdWrite("POLL PKT"); Rs485SendPacket( SENSOR_POLL_CMD, 0, &cTest[0] ); delay_ms(250); delay_ms(250); delay_ms(250); delay_ms(250); cOurAddrHigh = 0x10; cOurAddrLow = 0x18; // Send a packet to another node Rs485Initialise( cOurAddrHigh,cOurAddrLow ); Rs485SendPacket( SENSOR_POLL_CMD, 0, &cTest[0] ); delay_ms(250); delay_ms(250); delay_ms(250); delay_ms(250); #endif cPacketReady = Rs485Process(); if ( cPacketReady ) { Rs485GetPacket( &cCmd, &cLenOfData, &cTest[0] ); ClearLine2(); LcdWrite( "CMD: " ); BinToHexAscii( cCmd ); LcdWrite( ' ' ); if ( cLenOfData != 0 ) { for ( c=0; c } //Rs485SendPacket( SENSOR_ACK, 0, NULL ); delay_ms(255); Rs485Initialise(cOurAddrHigh,cOurAddrLow); ClearLine1(); LcdWrite("Waiting........"); } } } //************************** // Setup Hardware //************************** void Setup(void) { OPTIONREG = 0x84; // pullups,prescailer = TMR0 , rate = 1:32 INTCON = 0; // disable global interupts ADCON1 = 0x07; // Disable ADC TRISA = PortAConfig; TRISB = PortBConfig; TRISC = PortCConfig; TRISD = PortDConfig; TRISE = PortEConfig; PORTC = 0xFF; LCDSetup(); // Setup the LCD Display ConfigureComms(); /* Configure USART for Asyncronous Comms */ PORTC = 0xF7; } //*******************************************************/ //* Configure PIC16F87x USART for communications */ //* */ //* Asynchronous mode */ //* 8 data bits ( For other rates see PIC16F8XX Data ) */ //* 1 stop bits */ //* No Parity */ //* */ //*******************************************************/ void ConfigureComms(void) { BIT_SET( RCSTA, SPEN ); // Enable Serial port BIT_CLEAR( RCSTA, RX9 ); // 8 bit receive mode BIT_CLEAR( TXSTA, TX9 ); // 8 bit transmit mode // SPBRG = 0; // SPBRG = 1 ( Set Baud rate 115,200 ) // SPBRG = 5; // SPBRG = 5 ( Set Baud rate 38,400 ) // SPBRG = 22; // SPBRG = 22 ( Set Baud rate 9,600 ) // SPBRG = 11; // SPBRG = 11 ( Set Baud rate 19,200 ) // SPBRG = 22; // SPBRG = 22 ( Set Baud rate 9,600 ) // SPBRG = 47; // SPBRG = 47 ( 9600 Baud at 7.3728 Mhx clock ) // SPBRG = 22; // SPBRG = 22 ( 9600 Baud at 3.579545Mhz clock ) SPBRG = 25; // SPBRG = 25 ( 9600 Baud at 4 Mhx clock ) BIT_SET( TXSTA, BRGH ); // BRGH = 1 ( High speed mode ) BIT_CLEAR( TXSTA, SYNC ); // Asyncronous mode; BIT_SET( TXSTA, TXEN ); // Enable Transmitter BIT_SET( RCSTA, CREN ); // Enable continuous receive BIT_SET( INTCON, PEIE ); // Enable all Peripheral Interrupts }
上一篇:HD44780模块LCD接口例程
下一篇:最后一页
- 【EEWORLD第二十九届】2011年08月社区明星人物揭晓!
- 【有奖直播】 聚焦语音识别核心技术,走进Microchip Timberwolf™音频处理器研讨会
- 【开工大吉,抢楼有礼】聊一聊你感兴趣的技术和板子
- 2020 STM32全国研讨会火热报名中,新技术新方案等你收获,还有好礼拿!
- 爱“拼”才会赢 英飞凌栅极驱动IC拼图闯关 活动开始啦!
- 有奖学习 | Multi-Die系统的设计和验证很难吗?教你轻松“拿捏”
- 泰克MDO系列:1招搞定6大仪器,轻松穿越模拟、数字、频域测量
- 电机小课堂 | 单相无刷电机无感控制,小功率电机驱动应用中的最佳解决方案
- TE 最新趋势报告|《温度监测对发电机市场有何影响》
ASM10DTBD-S664
京公网安备 11010802033920号
