.name = 'dm9000',
.id = -1,
.num_resources = ARRAY_SIZE(mini2440_dm9k_resource),
.resource = mini2440_dm9k_resource,
.dev = {
.platform_data = &mini2440_dm9k_pdata,
static struct s3c24xx_mci_pdata mini2440_mmc_cfg = {
.gpio_detect = S3C2410_GPG(8),
.gpio_wprotect = S3C2410_GPH(8),
.set_power = NULL,
.ocr_avail = MMC_VDD_32_33|MMC_VDD_33_34,
static struct platform_device *mini2440_devices[] __initdata = {
&s3c_device_usb,
&s3c_device_rtc,
&s3c_device_lcd,
&s3c_device_wdt,
&s3c_device_i2c0,
&s3c_device_iis,
&mini2440_device_eth,
&s3c24xx_uda134x,
&s3c_device_nand,
&s3c_device_sdi,
&s3c_device_usbgadget,
static void __init mini2440_map_io(void)
s3c24xx_init_io(mini2440_iodesc, ARRAY_SIZE(mini2440_iodesc));
s3c24xx_init_clocks(12000000); // 外部时钟频率为12000000
s3c24xx_init_uarts(mini2440_uartcfgs, ARRAY_SIZE(mini2440_uartcfgs));
static void __init mini2440_machine_init(void)
s3c24xx_fb_set_platdata(&mini2440_fb_info); // lcd platform device add
s3c_i2c0_set_platdata(NULL); // i2c
s3c2410_gpio_cfgpin(S3C2410_GPC(0), S3C2410_GPC0_LEND); // lcd 背光
s3c_device_nand.dev.platform_data = &friendly_arm_nand_info; //nand
s3c_device_sdi.dev.platform_data = &mini2440_mmc_cfg; //SD card
platform_add_devices(mini2440_devices, ARRAY_SIZE(mini2440_devices));
s3c_pm_init();
MACHINE_START(MINI2440, 'FriendlyARM Mini2440 development board')
.phys_io = S3C2410_PA_UART,
.io_pg_offst = (((u32)S3C24XX_VA_UART) >> 18) & 0xfffc,
.boot_params = S3C2410_SDRAM_PA + 0x100,
.init_irq = s3c24xx_init_irq,
.map_io = mini2440_map_io,
.init_machine = mini2440_machine_init,
.timer = &s3c24xx_timer,
MACHINE_END
可以启动了,神了,但是还是有错误:
Creating 5 MTD partitions on 'NAND 128MiB 3,3V 8-bit':
0x000000000000-0x000000040000 : 'supervivi'
0x000000040000-0x000000060000 : 'param'
uncorrectable error :
0x000000060000-0x000000560000 : 'Kernel'
0x000000560000-0x000040560000 : 'root'
mtd: partition 'root' extends beyond the end of device 'NAND 128MiB 3,3V 8-bit' -- size truncated to 0x7aa0000
ftl_cs: FTL header not found.
0x000000000000-0x000040000000 : 'nand'
mtd: partition 'nand' extends beyond the end of device 'NAND 128MiB 3,3V 8-bit' -- size truncated to 0x8000000
可能是分区不对,先不管,移植文件系统再说.贴上完整的启动信息
Copy linux kernel from 0x00060000 to 0x30008000, size = 0x00200000 ... done
zImage magic = 0x016f2818
Setup linux parameters at 0x30000100
linux command line is: 'noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0'
MACH_TYPE = 1999
NOW, Booting Linux......
Uncompressing Linux................................................................................................................................. done, booting the kernel.
Linux version 2.6.32.2 (root@FC9) (gcc version 4.3.2 (Sourcery G++ Lite 2008q3-72) ) #4 Thu Jul 8 13:43:27 CST 2010
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: FriendlyARM Mini2440 development board
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 405.000 MHz, memory 101.250 MHz, peripheral 50.625 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock3 init=/linuxrc console=ttySAC0
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 60620KB available (3588K code, 418K data, 132K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Hierarchical RCU implementation.
NR_IRQS:85
irq: clearing subpending status 00000003
irq: clearing subpending status 00000002
Console: colour dummy device 80x30
console [ttySAC0] enabled
Calibrating delay loop... 201.93 BogoMIPS (lpj=504832)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
NET: Registered protocol family 16
S3C Power Management, Copyright 2004 Simtec Electronics
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb s3c-i2c s3c2440-i2c: slave address 0x10 s3c-i2c s3c2440-i2c: bus frequency set to 98 KHz s3c-i2c s3c2440-i2c: i2c-0: S3C I2C adapter NET: Registered protocol family 2 IP route cache hash table entries: 1024 (order: 0, 4096 bytes) TCP established hash table entries: 2048 (order: 2, 16384 bytes) TCP bind hash table entries: 2048 (order: 1, 8192 bytes) TCP: Hash tables configured (established 2048 bind 2048) TCP reno registered NET: Registered protocol family 1 RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. ROMFS MTD (C) 2007 Red Hat, Inc. msgmni has been set to 118 alg: No test for stdrng (krng) io scheduler noop registered io scheduler anticipatory registered (default) io scheduler deadline registered io scheduler cfq registered Console: switching to colour frame buffer device 60x53 fb0: s3c2410fb frame buffer device s3c2440-uart.0: s3c2410_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440 s3c2440-uart.1: s3c2410_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440 s3c2440-uart.2: s3c2410_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440 brd: module loaded S3C24XX NAND Driver, (c) 2004 Simtec Electronics s3c24xx-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns s3c24xx-nand s3c2440-nand: NAND soft ECC NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit) Scanning device for bad blocks Creating 5 MTD partitions on 'NAND 128MiB 3,3V 8-bit': 0x000000000000-0x000000040000 : 'supervivi' 0x000000040000-0x000000060000 : 'param' uncorrectable error : 0x000000060000-0x000000560000 : 'Kernel' uncorrectable error : 0x000000560000-0x000040560000 : 'root' mtd: partition 'root' extends beyond the end of device 'NAND 128MiB 3,3V 8-bit' -- size truncated to 0x7aa0000 ftl_cs: FTL header not found. 0x000000000000-0x000040000000 : 'nand' mtd: partition 'nand' extends beyond the end of device 'NAND 128MiB 3,3V 8-bit' -- size truncated to 0x8000000 dm9000 Ethernet Driver, V1.31 dm9000 dm9000: eth%d: Invalid ethernet MAC address. Please set using ifconfig eth0: dm9000e at c486e300,c4872304 IRQ 51 MAC: 00:00:00:00:00:00 (chip) ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver s3c2410-ohci s3c2410-ohci: S3C24XX OHCI s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1 s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000 usb usb1: configuration #1 chosen from 1 choice hub 1-0:1.0: USB hub found hub 1-0:1.0: 2 ports detected usbcore: registered new interface driver libusual s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes mice: PS/2 mouse device common for all mice S3C24XX RTC, (c) 2004,2006 Simtec Electronics s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0 i2c /dev entries driver S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled cpuidle: using governor ladder sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman s3c-sdi s3c2440-sdi: powered down. s3c-sdi s3c2440-sdi: mmc0 - using pio, sw SDIO IRQ usbcore: registered new interface driver hiddev usbcore: registered new interface driver usbhid usbhid: v2.6:USB HID core driver Advanced Linux Sound Architecture Driver Version 1.0.21. No device for DAI UDA134X No device for DAI s3c24xx-i2s S3C24XX_UDA134X SoC Audio driver UDA134X SoC Audio Codec asoc: UDA134X <-> s3c24xx-i2s mapping ok ALSA device list: #0: S3C24XX_UDA134X (UDA134X) TCP cubic registered NET: Registered protocol family 17 s3c2410-rtc s3c2410-rtc: setting system clock to 2009-06-21 08:21:07 UTC (1245572467) List of all partitions: 1f00 256 mtdblock0 (driver?) 1f01 128 mtdblock1 (driver?) 1f02 5120 mtdblock2 (driver?) 1f03 125568 mtdblock3 (driver?) 1f04 131072 mtdblock4 (driver?) No filesystem could mount root, tried: ext3 cramfs vfat msdos romfs Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3) [
上一篇:boot移植(十一)---代码修改---支持nandflash
下一篇:ARM-Linux移植之(四)——根文件系统构建
推荐阅读最新更新时间:2026-03-19 14:53
- LTC2945IUD-1 在 -48V 系统中使用低侧检测进行电源监控的典型应用
- 用于 24V 汽车应用的 LTC4367IDD 过压电源保护控制器的典型应用
- LTC2635-HZ12 四通道、12 位数模转换器的典型应用
- 使用 ROHM Semiconductor 的 BU4821 的参考设计
- 使用 Analog Devices 的 AD9625 的参考设计
- LT1307CS8 高压反激式转换器的典型应用电路
- AD7858L 3V 至 5V 单电源、200ksps、8 通道、12 位采样 ADC 的典型应用
- AND8337/D、1.2V、1.5V DC 至 DC 单路输出电源参考设计
- DER-713 - 使用 InnoSwitch3-EP PowiGaN 和 MinE-CAP 的 65 W 高功率密度适配器
- LDK120C11R 1.1V低压降稳压器典型应用(可调版)电路
树莓派官方出品的《制作手册 2026》(Book of Making 2026)
非常经典的关于LLC的杨波博士论文
XC6406PP60DL
京公网安备 11010802033920号
