按照官方手册进行mini2440 linux移植及遇到的问题
发布者:快乐阳光最新更新时间:2024-07-15 来源: elecfans关键字:官方手册  mini2440  linux移植 手机看文章 扫描二维码
随时随地手机看文章
arch/arm/mach-s3c2440/mach-mini2440.c:210: warning: type defaults to 'int' in declaration of 'type name'
arch/arm/mach-s3c2440/mach-mini2440.c:210: error: negative width in bit-field ''
arch/arm/mach-s3c2440/mach-mini2440.c:211: error: field name not in record or union initializer
arch/arm/mach-s3c2440/mach-mini2440.c:211: error: (near initialization for 'mini2440_nand_sets')
arch/arm/mach-s3c2440/mach-mini2440.c:215: error: variable 'mini2440_nand_info' has initializer but incomplete type
arch/arm/mach-s3c2440/mach-mini2440.c:216: error: unknown field 'tacls' specified in initializer
arch/arm/mach-s3c2440/mach-mini2440.c:216: warning: excess elements in struct initializer
arch/arm/mach-s3c2440/mach-mini2440.c:216: warning: (near initialization for 'mini2440_nand_info')
arch/arm/mach-s3c2440/mach-mini2440.c:217: error: unknown field 'twrph0' specified in initializer
arch/arm/mach-s3c2440/mach-mini2440.c:217: warning: excess elements in struct initializer
arch/arm/mach-s3c2440/mach-mini2440.c:217: warning: (near initialization for 'mini2440_nand_info')
arch/arm/mach-s3c2440/mach-mini2440.c:218: error: unknown field 'twrph1' specified in initializer
arch/arm/mach-s3c2440/mach-mini2440.c:218: warning: excess elements in struct initializer
arch/arm/mach-s3c2440/mach-mini2440.c:218: warning: (near initialization for 'mini2440_nand_info')
arch/arm/mach-s3c2440/mach-mini2440.c:219: error: unknown field 'nr_sets' specified in initializer
arch/arm/mach-s3c2440/mach-mini2440.c:219: warning: type defaults to 'int' in declaration of 'type name'
arch/arm/mach-s3c2440/mach-mini2440.c:219: error: negative width in bit-field ''
arch/arm/mach-s3c2440/mach-mini2440.c:219: warning: excess elements in struct initializer
arch/arm/mach-s3c2440/mach-mini2440.c:219: warning: (near initialization for 'mini2440_nand_info')
arch/arm/mach-s3c2440/mach-mini2440.c:220: error: unknown field 'sets' specified in initializer
arch/arm/mach-s3c2440/mach-mini2440.c:220: warning: excess elements in struct initializer
arch/arm/mach-s3c2440/mach-mini2440.c:220: warning: (near initialization for 'mini2440_nand_info')
arch/arm/mach-s3c2440/mach-mini2440.c:221: error: unknown field 'ignore_unset_ecc' specified in initializer
arch/arm/mach-s3c2440/mach-mini2440.c:221: warning: excess elements in struct initializer
arch/arm/mach-s3c2440/mach-mini2440.c:221: warning: (near initialization for 'mini2440_nand_info')
make[1]: *** [arch/arm/mach-s3c2440/mach-mini2440.o] 错误 1
make: *** [arch/arm/mach-s3c2440] 错误 2
baidu一下,发现有人(原文)遇到同样的错误,OK,按照原文的做,在mach-mini2440.c加入头文件,在 static void __init mini2440_map_io(void)加入红色内容
#include <linux/mtd/mtd.h>
#include
#include
#include
#include
    s3c24xx_init_io(mini2440_iodesc, ARRAY_SIZE(mini2440_iodesc));
    s3c24xx_init_clocks(120000000);
    s3c24xx_init_uarts(mini2440_uartcfgs, ARRAY_SIZE(mini2440_uartcfgs));
    s3c_device_nand.dev.platform_data = &mini2440_nand_info;
再次make试试看....
还是出现错误,提示找不到mini2440_nand_info'
arch/arm/mach-s3c2440/mach-mini2440.c: In function 'mini2440_map_io':
arch/arm/mach-s3c2440/mach-mini2440.c:172: error: 'mini2440_nand_info' undeclared (first use in this function)
arch/arm/mach-s3c2440/mach-mini2440.c:172: error: (Each undeclared identifier is reported only once
arch/arm/mach-s3c2440/mach-mini2440.c:172: error: for each function it appears in.)
可能是分区信息在文件的后面导致找不到的原因,把第二步加入的分区信息移到最前面试试看…经过十多分钟,make成功了,把zImage下载到板上试试看
郁闷,跟第一步信息一下,到booting the kernel.就不到了. 下班了,先吃饭去,下午再回来试试.
下午,实在不知道问题在哪里,修改一下mach-mini2440.c,源代码如下(网上copy的):
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include gpio.h>
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
static struct map_desc mini2440_iodesc[] __initdata = {
static struct s3c2410_uartcfg mini2440_uartcfgs[] __initdata = {
[0] = {
.hwport     = 0,
.flags     = 0,
.ucon       = 0x3c5,
.ulcon     = 0x03,
.ufcon     = 0x51,
[1] = {
.hwport     = 1,
.flags     = 0,
.ucon       = 0x3c5,
.ulcon     = 0x03,
.ufcon     = 0x51,
[2] = {
.hwport     = 2,
.flags     = 0,
.ucon       = 0x3c5,
.ulcon     = 0x03,
.ufcon     = 0x51,
#define LCD_WIDTH 240
#define LCD_HEIGHT 320
#define LCD_PIXCLOCK 170000
#define LCD_RIGHT_MARGIN 25
#define LCD_LEFT_MARGIN 0
#define LCD_HSYNC_LEN 4
#define LCD_UPPER_MARGIN 1
#define LCD_LOWER_MARGIN 4
#define LCD_VSYNC_LEN 1
static struct s3c2410fb_display mini2440_lcd_cfg __initdata = {
.lcdcon5 = S3C2410_LCDCON5_FRM565 |
 S3C2410_LCDCON5_INVVLINE |
 S3C2410_LCDCON5_INVVFRAME |
 S3C2410_LCDCON5_PWREN |
 S3C2410_LCDCON5_HWSWP,
.type = S3C2410_LCDCON1_TFT,
.width = LCD_WIDTH,
.height = LCD_HEIGHT,
.pixclock = LCD_PIXCLOCK,
.xres = LCD_WIDTH,
.yres = LCD_HEIGHT,
.bpp = 16,
.left_margin = LCD_LEFT_MARGIN + 1,
.right_margin = LCD_RIGHT_MARGIN + 1,
.hsync_len  = LCD_HSYNC_LEN + 1,
.upper_margin = LCD_UPPER_MARGIN + 1,
.lower_margin = LCD_LOWER_MARGIN + 1,
.vsync_len  = LCD_VSYNC_LEN + 1,
static struct s3c2410fb_mach_info mini2440_fb_info __initdata = {
.displays = &mini2440_lcd_cfg,
.num_displays = 1,
.default_display = 0,
.gpccon =       0xaa955699,
.gpccon_mask =  0xffc003cc,
.gpcup =        0x0000ffff,
.gpcup_mask =   0xffffffff,
.gpdcon =       0xaa95aaa1,
.gpdcon_mask =  0xffc0fff0,
.gpdup =        0x0000faff,
.gpdup_mask =   0xffffffff,
.lpcsel = 0xf82,
static struct s3c24xx_uda134x_platform_data s3c24xx_uda134x_data = {
.l3_clk = S3C2410_GPB(4),     // IO表示方法,定义在mach/regs-gpio.h->mach/gpio-nrs.h中
.l3_data = S3C2410_GPB(3),
.l3_mode = S3C2410_GPB(2),
.model = UDA134X_UDA1341,
static struct platform_device s3c24xx_uda134x = {
.name = 's3c24xx_uda134x',
.dev = {
.platform_data    = &s3c24xx_uda134x_data,
static struct mtd_partition friendly_arm_default_nand_part[] = {
[0] = {
.name = 'supervivi',
.size = 0x00040000,
.offset = 0,
[1] = {
.name = 'param',
.offset = 0x00040000,
.size = 0x00020000,
[2] = {
.name = 'Kernel',
.offset = 0x00060000,
.size = 0x00500000,
[3] = {
.name = 'root',
.offset = 0x00560000,
.size = 1024 * 1024 * 1024, //为以后拓展用
[4] = {
.name = 'nand',
.offset = 0x00000000,
static struct s3c2410_nand_set friendly_arm_nand_sets[] = {
[0] = {
.name = 'NAND',
.nr_chips = 1,
.nr_partitions = ARRAY_SIZE(friendly_arm_default_nand_part),
.partitions = friendly_arm_default_nand_part,
static struct s3c2410_platform_nand friendly_arm_nand_info = {
.tacls = 20, // 建立时间
.twrph0 = 60, // 等待时间
.twrph1 = 20, // 保持时间
.nr_sets = ARRAY_SIZE(friendly_arm_nand_sets),
.sets = friendly_arm_nand_sets,
.ignore_unset_ecc = 1,
#define MACH_MINI2440_DM9K_BASE (S3C2410_CS4 + 0x300)
static struct resource mini2440_dm9k_resource[] = {
        [0] = {
                .start = MACH_MINI2440_DM9K_BASE,
                .end   = MACH_MINI2440_DM9K_BASE + 3,
                .flags = IORESOURCE_MEM
        [1] = {
                .start = MACH_MINI2440_DM9K_BASE + 4,
                .end   = MACH_MINI2440_DM9K_BASE + 7,
        [2] = {
                .start = IRQ_EINT7,
                .end   = IRQ_EINT7,
                .flags = IORESOURCE_IRQ | IORESOURCE_IRQ_HIGHEDGE,
static struct dm9000_plat_data mini2440_dm9k_pdata = {
        .flags          = (DM9000_PLATF_16BITONLY | DM9000_PLATF_NO_EEPROM),
static struct platform_device mini2440_device_eth = {
[1] [2] [3]
关键字:官方手册  mini2440  linux移植 引用地址:按照官方手册进行mini2440 linux移植及遇到的问题
上一篇:boot移植(十一)---代码修改---支持nandflash
下一篇:ARM-Linux移植之(四)——根文件系统构建
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
