基于ESP-IDF4.1
1 #include 2 #include 'freertos/FreeRTOS.h' 3 #include 'freertos/task.h' 4 #include 'esp_system.h' 5 #include 'nvs_flash.h' 6 #include 'nvs.h' 7 #include 'driver/gpio.h' 8 9 #define STORAGE_NAMESPACE 'storage' 10 11 12 //保存设备重启数 13 esp_err_t save_restart_counter(void) 14 { 15 nvs_handle_t my_handle; 16 esp_err_t err; 17 18 // 打开 19 err = nvs_open(STORAGE_NAMESPACE, NVS_READWRITE, &my_handle); 20 if (err != ESP_OK) return err; 21 22 // 读取 23 int32_t restart_counter = 0; 24 err = nvs_get_i32(my_handle, 'restart_conter', &restart_counter); 25 if (err != ESP_OK && err != ESP_ERR_NVS_NOT_FOUND) return err; 26 27 // 写入 28 restart_counter++; 29 err = nvs_set_i32(my_handle, 'restart_conter', restart_counter); 30 if (err != ESP_OK) return err; 31 32 // 提交写入的值 33 err = nvs_commit(my_handle); 34 if (err != ESP_OK) return err; 35 36 // 关闭 37 nvs_close(my_handle); 38 return ESP_OK; 39 } 40 41 /* Save new run time value in NVS 42 by first reading a table of previously saved values 43 and then adding the new value at the end of the table. 44 Return an error if anything goes wrong 45 during this process. 46 */ 47 esp_err_t save_run_time(void) 48 { 49 nvs_handle_t my_handle; 50 esp_err_t err; 51 52 // 打开 53 err = nvs_open(STORAGE_NAMESPACE, NVS_READWRITE, &my_handle); 54 if (err != ESP_OK) return err; 55 56 // 读取内存空间大小 57 size_t required_size = 0; // value will default to 0, if not set yet in NVS 58 err = nvs_get_blob(my_handle, 'run_time', NULL, &required_size); 59 if (err != ESP_OK && err != ESP_ERR_NVS_NOT_FOUND) return err; 60 61 // 读取之前保存的blob 62 uint32_t* run_time = malloc(required_size + sizeof(uint32_t)); 63 if (required_size > 0) { 64 err = nvs_get_blob(my_handle, 'run_time', run_time, &required_size); 65 if (err != ESP_OK) { 66 free(run_time); 67 return err; 68 } 69 } 70 71 // 写入值,包含之前保存的blob 72 required_size += sizeof(uint32_t); 73 run_time[required_size / sizeof(uint32_t) - 1] = xTaskGetTickCount() * portTICK_PERIOD_MS; 74 err = nvs_set_blob(my_handle, 'run_time', run_time, required_size); 75 free(run_time); 76 77 if (err != ESP_OK) return err; 78 79 // 提交 80 err = nvs_commit(my_handle); 81 if (err != ESP_OK) return err; 82 83 // 关闭 84 nvs_close(my_handle); 85 return ESP_OK; 86 } 87 88 89 //从NVS读取和打印重启计数和运行时表 90 esp_err_t print_what_saved(void) 91 { 92 nvs_handle_t my_handle; 93 esp_err_t err; 94 95 // 打开 96 err = nvs_open(STORAGE_NAMESPACE, NVS_READWRITE, &my_handle); 97 if (err != ESP_OK) return err; 98 99 // 读取重启数 100 int32_t restart_counter = 0; // NVS没有设置值时需要设置默认值0 101 err = nvs_get_i32(my_handle, 'restart_conter', &restart_counter); 102 if (err != ESP_OK && err != ESP_ERR_NVS_NOT_FOUND) return err; 103 printf('Restart counter = %dn', restart_counter); 104 105 // 读取运行时blob 106 size_t required_size = 0; 107 //获取内存空间存储从NVS读取的blob 108 err = nvs_get_blob(my_handle, 'run_time', NULL, &required_size); 109 if (err != ESP_OK && err != ESP_ERR_NVS_NOT_FOUND) return err; 110 printf('Run time:n'); 111 if (required_size == 0) { 112 printf('Nothing saved yet!n'); 113 } else { 114 //malloc和free是申请内存空间与释放内存空间的函数 115 uint32_t* run_time = malloc(required_size); 116 err = nvs_get_blob(my_handle, 'run_time', run_time, &required_size); 117 if (err != ESP_OK) { 118 free(run_time); 119 return err; 120 } 121 for (int i = 0; i < required_size / sizeof(uint32_t); i++) { 122 printf('%d: %dn', i + 1, run_time[i]); 123 } 124 free(run_time); 125 } 126 127 // 关闭 128 nvs_close(my_handle); 129 return ESP_OK; 130 } 131 132 133 void app_main(void) 134 { 135 esp_err_t err = nvs_flash_init(); 136 if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) { 137 // NVS分区被截断,需要擦除并重新初始化 138 ESP_ERROR_CHECK(nvs_flash_erase()); 139 err = nvs_flash_init(); 140 } 141 ESP_ERROR_CHECK( err ); 142 143 err = print_what_saved(); 144 if (err != ESP_OK) printf('Error (%s) reading data from NVS!n', esp_err_to_name(err)); 145 146 err = save_restart_counter(); 147 if (err != ESP_OK) printf('Error (%s) saving restart counter to NVS!n', esp_err_to_name(err)); 148 149 gpio_pad_select_gpio(GPIO_NUM_0); 150 gpio_set_direction(GPIO_NUM_0, GPIO_MODE_DEF_INPUT); 151 152 // 读取GPIO0状态,低电平超过一秒则保存运行时并重启 153 while (1) { 154 if (gpio_get_level(GPIO_NUM_0) == 0) { 155 vTaskDelay(1000 / portTICK_PERIOD_MS); 156 if(gpio_get_level(GPIO_NUM_0) == 0) { 157 err = save_run_time(); 158 if (err != ESP_OK) printf('Error (%s) saving run time blob to NVS!n', esp_err_to_name(err)); 159 printf('Restarting...n'); 160 fflush(stdout); 161 esp_restart(); 162 } 163 } 164 vTaskDelay(200 / portTICK_PERIOD_MS); 165 } 166 }
上一篇:ESP32使用SPIFFS文件系统笔记
下一篇:ESP32非易失性存储整型数据笔记
推荐阅读最新更新时间:2026-03-20 12:23
- 使用 ON Semiconductor 的 FAN2518S 的参考设计
- LTC1530S8、3.3V/3A 稳压器
- 使用 ON Semiconductor 的 ADP3167 的参考设计
- 使用 Analog Devices 的 LT3420EDD 的参考设计
- 基于Kinetis® M的低成本单相电表参考设计
- LTC3708、具有上升/下降轨跟踪功能的 2.5V/15A 和 1.2V/15A 稳压器
- NXQ1TXH5插件板
- 应变仪仪表放大器
- WRL-13287,基于 ESP8266 802.11 无线局域网的 SparkFun Wi-Fi Shield
- 4.1W、3-LED 通用 LED 照明驱动器
【Follow me第三季第3期】代码
【Follow me第三季第3期】XIAO ESP32S3任务代码提交
Follow me第三季第3期源代码
非常经典的关于LLC的杨波博士论文
LTC6102HVHMS8
1-292148-8
京公网安备 11010802033920号
