ESP32非易失性存储整型数据笔记
发布者:纯真年代最新更新时间:2025-09-10 来源: cnblogs关键字:ESP32  非易失性存储  整型数据 手机看文章 扫描二维码
随时随地手机看文章
基于ESP-IDF4.1
 1 #include
 2 #include 'freertos/FreeRTOS.h'
 3 #include 'freertos/task.h'
 4 #include 'esp_system.h'
 5 #include 'nvs_flash.h'
 6 #include 'nvs.h'
 8 void app_main(void)
 9 {
10     // 初始化非易失性存储
11     esp_err_t err = nvs_flash_init();
12     if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) {
13         // NVS分区被截断,需要擦除并重新初始化
14         ESP_ERROR_CHECK(nvs_flash_erase());
15         err = nvs_flash_init();
16     }
17     ESP_ERROR_CHECK( err );
19     // 打开
20     printf('n');
21     printf('Opening Non-Volatile Storage (NVS) handle... ');
22     nvs_handle_t my_handle;
23     err = nvs_open('storage', NVS_READWRITE, &my_handle);
24     if (err != ESP_OK) {
25         printf('Error (%s) opening NVS handle!n', esp_err_to_name(err));
26     } else {
27         printf('Donen');
28
29         // 读取
30         printf('Reading restart counter from NVS ... ');
31         int32_t restart_counter = 0; // NVC中没有设置值得话,需要设置默认值为0
32         err = nvs_get_i32(my_handle, 'restart_counter', &restart_counter);
33         switch (err) {
34             case ESP_OK:
35                 printf('Donen');
36                 printf('Restart counter = %dn', restart_counter);
37                 break;
38             case ESP_ERR_NVS_NOT_FOUND:
39                 printf('The value is not initialized yet!n');
40                 break;
41             default :
42                 printf('Error (%s) reading!n', esp_err_to_name(err));
43         }
44
45         // 写入
46         printf('Updating restart counter in NVS ... ');
47         restart_counter++;
48         err = nvs_set_i32(my_handle, 'restart_counter', restart_counter);
49         printf((err != ESP_OK) ? 'Failed!n' : 'Donen');
51         //提交写入的值,其它时间提交写入没有保证
52         printf('Committing updates in NVS ... ');
53         err = nvs_commit(my_handle);
54         printf((err != ESP_OK) ? 'Failed!n' : 'Donen');
55
56         // 关闭
57         nvs_close(my_handle);
58     }
59
60     printf('n');
61
62     // 设备重启
63     for (int i = 10; i >= 0; i--) {
64         printf('Restarting in %d seconds...n', i);
65         vTaskDelay(1000 / portTICK_PERIOD_MS);
66     }
67     printf('Restarting now.n');
68     fflush(stdout);
69     esp_restart();
70 }
关键字:ESP32  非易失性存储  整型数据 引用地址:ESP32非易失性存储整型数据笔记
上一篇:ESP32存储blog笔记
下一篇:ESP32智能配网笔记
推荐阅读最新更新时间:2026-03-25 12:54
中国研发团队研发出一种新二维存储芯片
相比三星、东芝、美光等公司,中国现在DRAM内存、NAND闪存技术上要落后多年,不过中国的科研人员也一直在追赶最新一代技术,前不久有报道称中国投资130亿元开建PCM相变内存,性能是普通存储芯片的1000倍,现在更厉害的来了——复旦大学微电子学院教授张卫、周鹏带领的团队研发了一种新的二维非易失性存储芯片,他们使用了半导体结构,研发的存储芯片性能优秀,是传统二维存储芯片的100万倍,而且性能更长,刷新时间是内存的156倍,也就是说具备更强的耐用性。 DIY玩家应该知道内存、闪存各自的优缺点——内存速度极快,但是断电就会损失数据,而且成本昂贵,闪存的延迟比内存高一个量级,但好处就是能保存数据,同时成本更低,所以业界一直在寻找能同时
[网络通信]
赛普拉斯推出全新Excelon F-RAM 高速、高可靠存储
先进嵌入式解决方案的领导者赛普拉斯半导体公司(纳斯达克股票代码:CY)近日宣布推出新型串行非易失性存储器系列,为关键任务数据采集提供卓越性能和高可靠性。Excelon™铁电随机存取存储器(F-RAM™)系列具有高速非易失性数据记录功能,即使在恶劣的汽车和工业环境中,以及处于极端温度的情况下均可防止数据的丢失。ExcelonAuto系列具有2Mb至4Mb的汽车级存储密度,而ExcelonUltra系列具有4Mb至8Mb的工业级存储密度。这两个系列均提供低引脚数的小型封装选项,是各类先进汽车和工业应用的理想选择。 ExcelonAuto系列提供符合功能安全标准(ISO 26262)的AEC-Q100扩展温度选项。 Exce
[汽车电子]
半导体存储器的相变机制
非易失性存储器(NVM)在半导体市场占有重要的一席之地,特别是主要用于手机和其它便携电子设备的闪存芯片。今后几年便携电子系统对非易失性存储器的要求更高,数据存储应用需要写入速度极快的高密度存储器,而代码执行应用则要求存储器的随机访存速度更快。 经过研究人员对浮栅存储技术的坚持不懈的研究,现有闪存的技术能力在2010年底应该有所提升,尽管如此,现在人们越来越关注有望至少在2020年末以前升级到更小技术节点的新式存储器机制和材料。 目前存在多种不同的可以取代浮栅概念的存储机制,相变存储器(PCM)就是其中一个最被业界看好的非易失性存储器,具有闪存无法匹敌的读写性能和升级能力。 在室温环境中,基于第六族元素的某些金属(硫族化合
[工业控制]
<font color='red'>非</font><font color='red'>易</font><font color='red'>失</font><font color='red'>性</font>半导体<font color='red'>存储</font>器的相变机制
Ramtron推出业界首个4兆位FRAM存储
全新并行FRAM器件结合了德州仪器公认的130纳米工艺和Ramtron先进的FRAM单元架构 世界顶尖的非易失性铁电存储器 (FRAM) 和集成半导体产品开发商及供应商Ramtron International Corporation宣布推出半导体业界首个4兆位 (Mb) FRAM存储器,这是目前最高容量的FRAM产品,其容量是原有最大FRAM存储器容量的四倍。FM22L16是采用44脚薄型小尺寸塑封 (TSOP) 的3V、4Mb并行非易失性FRAM,具有高存取速度、几乎无限的读/写次数和低功耗等特点。FM22L16与异步静态 RAM (SRAM) 在管脚上兼容,并适用于工业控制系统如机器人、网络和数据存储应用、多功能打印机、自
[新品]
ESP32与STM32:比较并非明智之举
大家好,最近有遇到刚入行的小伙伴问学习的时候先学ESP32还是先学STM32。 先说, 这两个东西主打的都不是一个方向,STM32是增强版的STC51 出来的产物,51的资源真的太少了,寄存器少,RAM、ROM少,要是开发多点功能代码都不能多写几行,所以就出来了STM32,在STM32流行之前,开发者们还用了一个上古产物AVR单片机来替代,但是后面发现不如直接玩STM32来得实际,所以各种电赛就开始用STM32来玩。 所以MCU老手玩STM32会觉得很顺手,软件背景的开发者用ESP32更容易上手。 开发方式上,ESP32主打物联网,基于ESP-IDF框架开发,底层协议栈(TCP/IP、WiFi、WebServer)都是现成的,开发
[单片机]
ESP32 ADF windows开发环境搭建 适配ADF到ESP32A1S
搭建ESP32A1S的ADF开发环境 一,获取IDF和IDF-TOOL adf是乐鑫的音频开发框架,里面有许多乐鑫的音频开发API,同时ADF是基于IDF的。 这一部分可以按照官网的教程一步一步来。 官网教程地址: ADF安装指南 首先下载esp-idf,如果是第一次使用idf,可以在官网下载一个 idf工具安装器 ,通过这个安装器直接安装idf,同时还可以安装编译工具链。下载的速度也还可以接受。大概三十分钟就可以搞定。 本安装器可为您安装所需的交叉编译器、OpenOCD、cmake 和 Ninja 编译工具,以及一款 mconf-idf 配置工具。此外,本安装器还可在有需要时下载、运行 Python 3.7 和 Git
[单片机]
<font color='red'>ESP32</font> ADF windows开发环境搭建 适配ADF到ESP32A1S
ESP32高分辨率计时器笔记
尽管FreeRTOS提供了软件计时器,但这些计时器有一些限制: 最大分辨率等于RTOS滴答周期 计时器回调从低优先级任务分派 硬件计时器不受这两个限制,但是通常它们使用起来不太方便。例如,应用组件可能需要定时器事件在将来的特定时间触发,但是硬件定时器仅包含一个用于中断产生的“比较”值。这意味着需要在硬件计时器之上构建一些功能来管理挂起事件列表,以便在发生相应的硬件中断时可以调度这些事件的回调。 esp_timer 一组API提供了一次性的计时器和定期的计时器,微秒级的时间分辨率以及64位范围。 基于ESP-IDF4.1 1 #include stdio.h 2 #include string.h 3 #
[单片机]
ESP32存储blog笔记
基于ESP-IDF4.1 1 #include stdio.h 2 #include freertos/FreeRTOS.h 3 #include freertos/task.h 4 #include esp_system.h 5 #include nvs_flash.h 6 #include nvs.h 7 #include driver/gpio.h 8 9 #define STORAGE_NAMESPACE storage 10 11 12 //保存设备重启数 13 esp_err_t save_restart_counter(void) 14 { 15 nvs_hand
[单片机]
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
