用tiny210V2开发板的HDMI接口输出到的10.1寸LCD,LCD无任何现象。
说明一下我的情况,我的10.1寸屏LCD是HDMI接口的,我用HDMI连接我的笔记本,信号一切输出正常(也就是说笔记本的HDMI输出能点亮我的10.1寸LCD屏),但我用TINY210V2来做,却行不通,LCD上什么都看不到。然后我将tiny210V2连接我的三星液晶电视输出到电视,却是可以的(设置为720P).但当我把HDMI连接线从电视拔到10.1寸LCD,却又没的显示输出,而且最奇怪的问题,我再插回到电视,电视上也没的输出画面?这是什么原因?难道HDMI会识别什么?还是?
tiny210v2的HDMI输出到10.1LCD,终端一直打印 same hpd_status value: 1
下面是我的串口打印信息:
Load Kernel...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.0.8-FriendlyARM (root@friendlyarm.tzs) (gcc version 4.5.1 (ctng-1.8.1-FA) ) #1 PREEMPT Tue Oct 30 10:33:04 CST 2012
[ 0.000000] CPU: ARMv7 Processor [412fc082] revision 2 (ARMv7), cr=10c53c7f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: MINI210
[ 0.000000] MINI210: HDM selected
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] CPU S5PV210/S5PC110 (id 0x43110220)
[ 0.000000] S3C24XX Clocks, Copyright 2004 Simtec Electronics
[ 0.000000] S5PV210: PLL settings, A=1000000000, M=667000000, E=80000000 V=54000000
[ 0.000000] S5PV210: ARMCLK=1000000000, HCLKM=200000000, HCLKD=166750000
[ 0.000000] HCLKP=133400000, PCLKM=100000000, PCLKD=83375000, PCLKP=66700000
[ 0.000000] sclk_dmc: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_onenand: source is hclk_dsys (1), rate is 166750000
[ 0.000000] uclk1: source is mout_mpll (6), rate is 66700000
[ 0.000000] sclk_mixer: source is sclk_dac (0), rate is 54000000
[ 0.000000] sclk_fimc: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_cam0: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_cam1: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_fimd: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_mmc: source is mout_epll (7), rate is 80000000
[ 0.000000] sclk_mfc: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_g2d: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_g3d: source is sclk_a2m (0), rate is 200000000
[ 0.000000] sclk_csis: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_spi: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_pwi: source is ext_xtal (0), rate is 24000000
[ 0.000000] sclk_pwm: source is ext_xtal (0), rate is 24000000
[ 0.000000] s5p: 36864 kbytes system memory reserved for mfc at 0x2dc00000, 0-bank base(0x2dc00000)
[ 0.000000] s5p: 36864 kbytes system memory reserved for mfc at 0x3dbf5000, 1-bank base(0x3dbf5000)
[ 0.000000] s5p: 6144 kbytes system memory reserved for fimc0 at 0x3d5f5000, 1-bank base(0x3d5f5000)
[ 0.000000] s5p: 16 kbytes system memory reserved for fimc1 at 0x3d5f1000, 1-bank base(0x3d5f1000)
[ 0.000000] s5p: 6144 kbytes system memory reserved for fimc2 at 0x3cff1000, 1-bank base(0x3cff1000)
[ 0.000000] s5p: 8192 kbytes system memory reserved for jpeg at 0x2d400000, 0-bank base(0x2d400000)
[ 0.000000] s5p: 13780 kbytes system memory reserved for fimd at 0x3c27c000, 1-bank base(0x3c27c000)
[ 0.000000] s5p: 8192 kbytes system memory reserved for g2d at 0x2cc00000, 0-bank base(0x2cc00000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 100999
[ 0.000000] Kernel command line: root=/dev/mtdblock4 rootfstype=yaffs2 console=ttySAC0,115200 init=/linuxrc lcd=HDMI576P16X9D
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 204MB 194MB 0MB = 398MB total
[ 0.000000] Memory: 393876k/510072k available, 14216k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xe0800000 - 0xfd000000 ( 456 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .init : 0xc0008000 - 0xc0174000 (1456 kB)
[ 0.000000] .text : 0xc0174000 - 0xc08c9ec0 (7512 kB)
[ 0.000000] .data : 0xc08ca000 - 0xc0921f80 ( 352 kB)
[ 0.000000] .bss : 0xc0921fa4 - 0xc0967460 ( 278 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:393
[ 0.000000] VIC @fd000000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd010000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd020000: id 0x00041192, vendor 0x41
[ 0.000000] VIC @fd030000: id 0x00041192, vendor 0x41
[ 0.000000] mult[140737]
[ 0.000000] max_delta_ns[2937815369]
[ 0.000000] min_delta_ns[30517]
[ 0.000000] rate[32768]
[ 0.000000] HZ[256]
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttySAC0] enabled
[ 0.439662] Calibrating delay loop... 994.84 BogoMIPS (lpj=1941504)
[ 0.464732] pid_max: default: 32768 minimum: 301
[ 0.464893] Mount-cache hash table entries: 512
[ 0.465225] Initializing cgroup subsys debug
[ 0.465267] Initializing cgroup subsys cpuacct
[ 0.465314] Initializing cgroup subsys freezer
[ 0.468089] CPU: Testing write buffer coherency: ok
[ 0.475667] print_constraints: dummy:
[ 0.476801] NET: Registered protocol family 16
[ 0.486245] S3C Power Management, Copyright 2004 Simtec Electronics
[ 0.492603] fimd at 0x3c27c000
[ 0.492680] hsmmc0: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.496810] hsmmc1: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.502850] hsmmc2: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.509080] hsmmc3: sclk_mmc: source is mout_mpll, rate is 47642857
[ 0.516123] S5PV210: Initializing architecture
[ 0.520383] s3c-adc s5pv210-adc: attached adc driver
[ 0.524843] s3c24xx-pwm s3c24xx-pwm.0: tin at 66700000, tdiv at 66700000, tin=divclk, base 0
[ 0.533459] print_constraints: pd_tv_supply: 5000 mV normal
[ 0.538873] print_constraints: pd_lcd_supply: 5000 mV normal
[ 0.544590] print_constraints: pd_g3d_supply: 5000 mV normal
[ 0.550297] print_constraints: pd_mfc_supply: 5000 mV normal
[ 0.556025] print_constraints: pd_audio_supply: 5000 mV normal
[ 0.592455] bio: create slab [ 0.593461] SCSI subsystem initialized [ 0.595662] usbcore: registered new interface driver usbfs [ 0.595947] usbcore: registered new interface driver hub [ 0.596136] usbcore: registered new device driver usb [ 0.596663] s3c-i2c s3c2440-i2c.0: slave address 0x10 [ 0.598734] s3c-i2c s3c2440-i2c.0: bus frequency set to 378 KHz [ 0.605270] s3c-i2c s3c2440-i2c.0: i2c-0: S3C I2C adapter [ 0.610054] s3c-i2c s3c2440-i2c.1: slave address 0x10 [ 0.615038] s3c-i2c s3c2440-i2c.1: bus frequency set to 65 KHz [ 0.621091] s3c-i2c s3c2440-i2c.1: i2c-1: S3C I2C adapter [ 0.626235] s3c-i2c s3c2440-i2c.2: slave address 0x10 [ 0.631223] s3c-i2c s3c2440-i2c.2: bus frequency set to 378 KHz [ 0.637480] s3c-i2c s3c2440-i2c.2: i2c-2: S3C I2C adapter [ 0.643036] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.649346] Bluetooth: Core ver 2.16 [ 0.652497] NET: Registered protocol family 31 [ 0.656811] Bluetooth: HCI device and connection manager initialized [ 0.663117] Bluetooth: HCI socket layer initialized [ 0.667960] Bluetooth: L2CAP socket layer initialized [ 0.672984] Bluetooth: SCO socket layer initialized [ 0.678069] Switching to clocksource clock_source_systimer [ 0.683431] Switched to NOHz mode on CPU #0 [ 0.698945] NET: Registered protocol family 2 [ 0.699164] IP route cache hash table entries: 4096 (order: 2, 16384 bytes) [ 0.699749] TCP established hash table entries: 16384 (order: 5, 131072 bytes) [ 0.706305] TCP bind hash table entries: 16384 (order: 6, 327680 bytes) [ 0.712816] TCP: Hash tables configured (established 16384 bind 16384) [ 0.719017] TCP reno registered [ 0.722111] UDP hash table entries: 256 (order: 1, 12288 bytes) [ 0.728030] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes) [ 0.734550] NET: Registered protocol family 1 [ 0.738908] RPC: Registered named UNIX socket transport module. [ 0.744606] RPC: Registered udp transport module. [ 0.749243] RPC: Registered tcp transport module. [ 0.753924] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.769494] NetWinder Floating Point Emulator V0.97 (double precision) [ 0.769629] PMU: registered new PMU device of type 0 [ 0.772090] cpuidle: phy_regs_save:0x3bf2d000 [ 0.776265] Loaded driver for PL330 DMAC-0 s3c-pl330 [ 0.781153] DBUFF-64x8bytes Num_Chans-8 Num_Peri-2 Num_Events-32 [ 0.787185] Loaded driver for PL330 DMAC-1 s3c-pl330 [ 0.792059] DBUFF-8x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32 [ 0.798181] Loaded driver for PL330 DMAC-2 s3c-pl330 [ 0.803061] DBUFF-8x4bytes Num_Chans-8 Num_Peri-32 Num_Events-32 [ 0.817262] ashmem: initialized [ 0.830806] NTFS driver 2.1.30 [Flags: R/W]. [ 0.831307] ROMFS MTD (C) 2007 Red Hat, Inc. [ 0.831576] msgmni has been set to 769 [ 0.832798] io scheduler noop registered [ 0.832836] io scheduler deadline registered [ 0.832926] io scheduler cfq registered (default) [ 0.837333] start plist test [ 0.844870] end plist test [ 0.845664] s3cfb s3cfb: win 2: pmem_start=0x3c73b000 [ 0.847879] s3cfb s3cfb: [fb2] dma: 0x3c73b000, cpu: 0xe1000000, size: 0x008b6000 [ 0.867674] Console: switching to colour frame buffer device 90x36 [ 0.873284] FIMD src sclk = 166750000 [ 0.873353] s3cfb s3cfb: registered successfully [ 0.873394] Start display and show logo [ 0.878938] s5pv210-uart.0: ttySAC0 at MMIO 0xe2900000 (irq = 16) is a S3C6400/10 [ 0.882831] s5pv210-uart.1: ttySAC1 at MMIO 0xe2900400 (irq = 20) is a S3C6400/10 [ 0.894371] s5pv210-uart.2: ttySAC2 at MMIO 0xe2900800 (irq = 24) is a S3C6400/10
上一篇:uboot-spl 编译流程
下一篇:platform总线驱动代码分析
- 热门资源推荐
- 热门放大器推荐
- LTC1733,用于 4.1V 或 4.2V 电池的完整 1.5A 单节锂离子充电器
- MCP39F521,电源监控演示板是一个全功能的 I2C 总线单相电源和能量监控系统
- 具有 4.6A 输入电流限制和 12V、48W 备份模式的 LTC3350IUHF 11V 至 20V、5.3A LiFePO4 电池充电器的典型应用电路
- LT1934IS6-1 1.8V 降压转换器的典型应用电路
- STPIC6D595电源逻辑8位移位寄存器的典型应用
- CAT3200HU2EVB,基于CAT3200HU2升压转换器的评估板
- OP213FSZ-REEL7 5V Only 18-Bit Stereo Op-Amp DAC 的典型应用
- 使用 Analog Devices 的 ADM3066EBRMZ 的参考设计
- RT9284A微型封装、高性能、白光LED恒流开关稳压器驱动5串WLED的典型应用
- LTC2207 演示板,16 位高性能 ADC 驱动器
- 后摩尔时代,先进封装将迎来高光时刻
- SABIC将亮相PCIM ASIA 2021,展示ELCRES™ HTV150电容薄膜
- 大摩:9月电视面板价格或将继续下跌
- STM8单片机串口同时识别自定义协议和Modbus协议
- IDTechEx报告:使用高功率充电器为电动汽车充电 速度堪比加油
- 昉•惊鸿7110高性能RISC-V视觉处理平台明年Q2量产
- PIC12F629解码PT2262IR(asm程序)
- ROHM的SiC MOSFET和SiC SBD成功应用于Apex Microtechnology的工业设备功率模块系列
- 变频调速给水方式的适用条件
- COSEL为要求苛刻的应用提供输出功率为3500W的新型无风扇传导冷却式三相高效电源
- 单片机C语言程序设计实训100例--基于AVR+PROTEUS仿真
- 没有十里桃花,谁能告诉我这是海棠花还是樱花?
- 存储器
- can I use file system filter driver in windows ce 4 and above
- MSP430设置串口波特率的方法
- 为什么小鸟站在高压线上不会被电死?
- DDR的电源分类
- 我的电路板上的3.3v输出lm1117芯片,实际输出却是4.2v
- vc2005开发的智能设备ocx,如何改造能在pc(x86)下的智能设备应用中开发使用? 我快要疯了 ,请高手详细指点
- 使用Nios II 9.1 SP1 SBTE的Flash Programmer的几点注意事项.[Nios II]
现代雷达系统的信号设计
ACA0861CS7CTR
BFR340T
京公网安备 11010802033920号
