//头文件
#include <linux/init.h>
#include #include #include #include #include #include #include #include #include #include #include #include #include #define LED_NUM_ON _IOW('L',0x1122,int) #define LED_NUM_OFF _IOW('L',0x3344,int) #define LED_ALL_ON _IO('L',0x1234) #define LED_ALL_OFF _IO('L',0x5678) //定义一个按键的数据包 struct button_event{ int code; //按键的名称---键值:KEY_DOWN int value; //按键的状态---按下:1,松开:0 }; //面向对象编程----设计设备的类型 struct s5pv210_button{ //unsigned int major; dev_t devno; struct class * cls; struct device * dev; struct cdev *cdev; unsigned int irqno; struct button_event event; wait_queue_head_t wq_head; int have_data; //表示当前是否有数据可读,可读--1,不可读--0 }; struct s5pv210_button *button_dev; //实现中断处理函数--------当触发中断时会被执行 irqreturn_t button_irq_svc(int irqno, void *dev) { int value; printk('--------^_^ %s------------n',__FUNCTION__); //获取按键信息 value = gpio_get_value(S5PV210_GPH0(1)); //判断是按下还是松开 if(value){ //松开 printk('kenel:keydown up!n'); button_dev->event.code = KEY_DOWN; button_dev->event.value = 0; }else{ //按下 printk('kenel:keydown pressed!n'); button_dev->event.code = KEY_DOWN; button_dev->event.value = 1; } //此时有数据可读 button_dev->have_data = 1; //从等待队列中唤醒阻塞的进程 wake_up_interruptible(&button_dev->wq_head); return IRQ_HANDLED; } //实现设备操作接口 int button_open(struct inode *inode, struct file *filp) { printk('--------^_^ %s------------n',__FUNCTION__); return 0; } ssize_t button_read(struct file *filp , char __user *buf , size_t size, loff_t *flags) { int ret; printk('--------^_^ %s------------n',__FUNCTION__); //判读open时,有没有设置flags为NONBLOCK if(filp->f_flags & O_NONBLOCK && !button_dev->have_data) return -EAGAIN; //判断此时是否有数据可读 wait_event_interruptible(button_dev->wq_head,button_dev->have_data); //将内核数据转换为用户空间数据 ret = copy_to_user(buf,&button_dev->event,size); if(ret > 0){ printk('copy_to_user error!n'); return -EFAULT; } //将数据返回给应用空间后,清空数据包,同时将hava_data置零 memset(&button_dev->event,0,sizeof(button_dev->event)); button_dev->have_data = 0; return size; } ssize_t button_write(struct file *filp, const char __user *buf, size_t size, loff_t *flags) { printk('--------^_^ %s------------n',__FUNCTION__); return size; } long button_ioctl(struct file *filp, unsigned int cmd , unsigned long args) { printk('--------^_^ %s------------n',__FUNCTION__); return 0; } int button_close(struct inode *inode, struct file *filp) { printk('--------^_^ %s------------n',__FUNCTION__); return 0; } static struct file_operations fops = { .open = button_open, .read = button_read, .write = button_write, .unlocked_ioctl = button_ioctl, .release = button_close, }; //加载函数和卸载函数 static int __init button_init(void) //加载函数-----在驱动被加载时执行 { int ret; printk('--------^_^ %s------------n',__FUNCTION__); //0,实例化设备对象 //参数1 ---- 要申请的空间的大小 //参数2 ---- 申请的空间的标识 button_dev = kzalloc(sizeof(struct s5pv210_button),GFP_KERNEL); if(IS_ERR(button_dev)){ printk('kzalloc error!n'); ret = PTR_ERR(button_dev); return -ENOMEM; } //1,申请设备号-----新方法 #if 0 //静态申请设备号 button_dev->major = 256; ret = register_chrdev_region(MKDEV(button_dev->major,0),1,'button_drv'); if(ret < 0){ printk('register_chrdev_region error!n'); ret = -EINVAL; goto err_kfree; } #else //动态申请设备号 ret = alloc_chrdev_region(&button_dev->devno,0,1,'button_drv'); if(ret < 0){ printk('register_chrdev_region error!n'); ret = -EINVAL; goto err_kfree; } #endif //创建cdev //申请cdev的空间 button_dev->cdev = cdev_alloc(); if(IS_ERR(button_dev->cdev)){ printk('button_dev->cdev error!n'); ret = PTR_ERR(button_dev->cdev); goto err_unregister; } //初始化cdev的成员 cdev_init(button_dev->cdev,&fops); //将cdev加入到内核中----链表 ret = cdev_add(button_dev->cdev,button_dev->devno,1); //2,创建设备文件-----/dev/button button_dev->cls = class_create(THIS_MODULE,'button_cls'); if(IS_ERR(button_dev->cls)){ printk('class_create error!n'); ret = PTR_ERR(button_dev->cls); goto err_cdev_del; } button_dev->dev = device_create(button_dev->cls,NULL,button_dev->devno,NULL,'button'); if(IS_ERR(button_dev->dev)){ printk('device_create error!n'); ret = PTR_ERR(button_dev->dev); goto err_class; } //3,硬件初始化---申请中断 button_dev->irqno = IRQ_EINT(1); ret = request_irq(button_dev->irqno,button_irq_svc,IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,'eint-keydown',NULL); if(ret != 0){ printk('request_irq error!n'); ret = -EBUSY; goto err_device; } //初始化等待队列头 init_waitqueue_head(&button_dev->wq_head); return 0; err_device: device_destroy(button_dev->cls,button_dev->devno); err_class: class_destroy(button_dev->cls); err_cdev_del: cdev_del(button_dev->cdev); err_unregister: unregister_chrdev_region(button_dev->devno,1); err_kfree: kfree(button_dev); return ret; } static void __exit button_exit(void) //卸载函数-----在驱动被卸载时执行 { printk('--------^_^ %s------------n',__FUNCTION__); free_irq(button_dev->irqno,NULL); device_destroy(button_dev->cls,button_dev->devno); class_destroy(button_dev->cls); cdev_del(button_dev->cdev); unregister_chrdev_region(button_dev->devno,1); kfree(button_dev); } //声明和认证 module_init(button_init); module_exit(button_exit); MODULE_LICENSE('GPL'); #include #include #include #include #include #include #include #include #include //定义一个按键的数据包 struct button_event{ int code; //按键的名称---键值:KEY_DOWN int value; //按键的状态---按下:1,松开:0 }; int main(void) { int fd; int ret; struct button_event event; //fd = open('/dev/button',O_RDWR|O_NONBLOCK); fd = open('/dev/button',O_RDWR); if(fd < 0){ perror('open'); exit(1); } while(1){ bzero(&event,sizeof(event)); ret = read(fd,&event,sizeof(event)); #if 0 if(ret < 0){ perror('read'); exit(1); } #endif if(event.code == KEY_DOWN){ if(event.value) printf('按下了下键!n'); else printf('松开了下键!n'); } sleep(1); } close(fd); return 0; } #指定内核源码路径 KERNEL_DIR = /home/farsight/s5pv210/kernel/linux-3.0.8 CUR_DIR = $(shell pwd) MYAPP = test all: #让make进入内核源码编译,同时将当前目录中的c程序作为内核模块一起编译 make -C $(KERNEL_DIR) M=$(CUR_DIR) modules arm-none-linux-gnueabi-gcc -o $(MYAPP) $(MYAPP).c clean: #删除上面编译生成的文件 make -C $(KERNEL_DIR) M=$(CUR_DIR) clean rm -rf $(MYAPP) install: cp *.ko $(MYAPP) /opt/rootfs/drv_module #指定当前目录下哪个文件作为内核模块编 obj-m = button_drv.o
上一篇:ARM Cortex-A Series Processors
下一篇:[kernel 启动流程] (第四章)第一阶段之——dtb的验证
推荐阅读最新更新时间:2026-03-20 14:05
- ADR435B 5 Vout 超低噪声 XFET 电压基准的典型应用,具有灌电流和拉电流能力
- 使用 Analog Devices 的 ADP8140 的参考设计
- NCP699SN30T1G 150mA、3 路输出电压 CMOS 低 Iq LDO 的典型应用,在 TSOP-5 中启用
- ZTL431过压/欠压保护电路典型应用
- 使用 Microchip Technology 的 DVR2802B3 的参考设计
- 开源的浮游生物监测分析设备PlanktoScope
- STK503,旨在评估 AT90USB AVR MCU 的入门套件,通过 AVR Studio 支持 JTAGICE mkII 和 AVRISP mkII
- 使用 BittWare 的 XCVU190 的参考设计
- 远程声控参考设计
- NCP4354AADAPGEVB,用于 NCP4354、65W 适配器关闭模式控制器的评估板
S5PV210_iROM_ApplicationNote_Preliminary_20091126
C++牛客大佬总结面试经验.docx
非常经典的关于LLC的杨波博士论文
XC6406PP60DL
京公网安备 11010802033920号
