代码示例_poll的多路复用
发布者:DazzlingSmile最新更新时间:2025-02-06 来源: cnblogs关键字:多路复用  S5PV210 手机看文章 扫描二维码
随时随地手机看文章
//头文件
#include <linux/init.h>
#include
#include
#include
#include
#include gpio.h>
#include
#include
#include
#include
#include
#include
#include
#include
#include
//定义一个按键的数据包
struct button_event{
    int code;         //按键的名称---键值:KEY_DOWN
    int value;        //按键的状态---按下:1,松开:0
//设计一个描述按键的结构体类型
struct buttons{
    char *name;        //名称
    unsigned int irqno;        //中断号
    int gpio;                //按键对应的gpio口
    int code;                //键值
    unsigned long flags;    //触发方式
//定义一个数组来保存多个按键的数据
struct buttons buttons_set[] = {
    [0] = {
        .name = 'key1_up',
        .irqno = IRQ_EINT(0),
        .gpio = S5PV210_GPH0(0),
        .code = KEY_UP,
        .flags = IRQF_TRIGGER_FALLING|IRQF_TRIGGER_RISING,
    [1] = {
        .name = 'key2_down',
        .irqno = IRQ_EINT(1),
        .gpio = S5PV210_GPH0(1),
        .code = KEY_DOWN,
    [2] = {
        .name = 'key3_left',
        .irqno = IRQ_EINT(2),
        .gpio = S5PV210_GPH0(2),
        .code = KEY_LEFT,
    [3] = {
        .name = 'key4_right',
        .irqno = IRQ_EINT(3),
        .gpio = S5PV210_GPH0(3),
        .code = KEY_RIGHT,
//面向对象编程----设计设备的类型
struct s5pv210_button{
    //unsigned int major;
    dev_t  devno;
    struct class * cls;
    struct device * dev;
    struct cdev  *cdev;
    unsigned int irqno;
    struct button_event event;
    wait_queue_head_t wq_head;
    int have_data;        //表示当前是否有数据可读,可读--1,不可读--0
struct s5pv210_button *button_dev;
//实现中断处理函数--------当触发中断时会被执行
irqreturn_t button_irq_svc(int irqno, void *dev)
    int value;
    struct buttons *p;
    printk('--------^_^ %s------------n',__FUNCTION__);
    //获取当前触发中断的按键信息
    p = (struct buttons *)dev;
    //获取产生中断的gpio口的值
    value = gpio_get_value(p->gpio);
    //判断是按下还是松开
    if(value){
        //松开
        printk('kernel:%s up!n',p->name);
        button_dev->event.code = p->code;
        button_dev->event.value = 0;
    }else{
        //按下
        printk('kenel:%s pressed!n',p->name);
        button_dev->event.value = 1;
    //此时有数据可读
    button_dev->have_data = 1;
    //从等待队列中唤醒阻塞的进程
    wake_up_interruptible(&button_dev->wq_head);
    return IRQ_HANDLED;
//实现设备操作接口
int button_open(struct inode *inode, struct file *filp)
    return 0;
ssize_t button_read(struct file *filp , char __user *buf , size_t size, loff_t *flags)
    int ret;
    //判读open时,有没有设置flags为NONBLOCK
    if(filp->f_flags & O_NONBLOCK && !button_dev->have_data)
        return -EAGAIN;
    //判断此时是否有数据可读
    wait_event_interruptible(button_dev->wq_head,button_dev->have_data);
    //将内核数据转换为用户空间数据
    ret = copy_to_user(buf,&button_dev->event,size);
    if(ret > 0){
        printk('copy_to_user error!n');
        return -EFAULT;
    //将数据返回给应用空间后,清空数据包,同时将hava_data置零
    memset(&button_dev->event,0,sizeof(button_dev->event));
    button_dev->have_data = 0;
    return size;
ssize_t button_write(struct file *filp, const char __user *buf, size_t size, loff_t *flags)
    return size;
long button_ioctl(struct file *filp, unsigned int cmd , unsigned long args)
    return 0;
unsigned int button_poll(struct file *filp, struct poll_table_struct *pts)
    unsigned int mask = 0;
    //1,将等待队列头注册到系统中(VFS)
    poll_wait(filp,&button_dev->wq_head,pts);
    //2,如果产生按键中断-有数据可读,此时返回POLLIN,如果没有数据返回0
    if(button_dev->have_data)
        mask |= POLLIN;
    return mask;
int button_close(struct inode *inode, struct file *filp)
    return 0;
static struct file_operations fops = {
    .open = button_open,
    .read = button_read,
    .write = button_write,
    .poll = button_poll,
    .unlocked_ioctl = button_ioctl,
    .release = button_close,
//加载函数和卸载函数
static int __init button_init(void)   //加载函数-----在驱动被加载时执行
    int ret,i;
    //0,实例化设备对象
    //参数1 ---- 要申请的空间的大小
    //参数2 ---- 申请的空间的标识
    button_dev = kzalloc(sizeof(struct s5pv210_button),GFP_KERNEL);
    if(IS_ERR(button_dev)){
        printk('kzalloc error!n');
        ret = PTR_ERR(button_dev);
        return -ENOMEM;
    //1,申请设备号-----新方法
#if 0
    //静态申请设备号
    button_dev->major = 256;
    ret = register_chrdev_region(MKDEV(button_dev->major,0),1,'button_drv');
    if(ret < 0){
        printk('register_chrdev_region error!n');
        ret =  -EINVAL;
        goto err_kfree;
#else
    //动态申请设备号
    ret = alloc_chrdev_region(&button_dev->devno,0,1,'button_drv');
    if(ret < 0){
        ret =  -EINVAL;
        goto err_kfree;
#endif
    //创建cdev
    //申请cdev的空间
    button_dev->cdev = cdev_alloc();
    if(IS_ERR(button_dev->cdev)){
        printk('button_dev->cdev error!n');
        ret = PTR_ERR(button_dev->cdev);
        goto err_unregister;
    //初始化cdev的成员
    cdev_init(button_dev->cdev,&fops);
    //将cdev加入到内核中----链表
    ret = cdev_add(button_dev->cdev,button_dev->devno,1);
    //2,创建设备文件-----/dev/button
    button_dev->cls = class_create(THIS_MODULE,'button_cls');
    if(IS_ERR(button_dev->cls)){
        printk('class_create error!n');
        ret = PTR_ERR(button_dev->cls);
        goto err_cdev_del;
    button_dev->dev = device_create(button_dev->cls,NULL,button_dev->devno,NULL,'button');
    if(IS_ERR(button_dev->dev)){
        printk('device_create error!n');
        ret = PTR_ERR(button_dev->dev);
        goto err_class;
    //3,硬件初始化---申请中断
    for(i = 0; i < ARRAY_SIZE(buttons_set);i++){
        ret = request_irq(buttons_set[i].irqno,button_irq_svc,buttons_set[i].flags,buttons_set[i].name,&buttons_set[i]);
        if(ret != 0){
            printk('request_irq error!n');
            ret = -EBUSY;
            goto err_device;
    //初始化等待队列头
    init_waitqueue_head(&button_dev->wq_head);
    return 0;
err_device:
    device_destroy(button_dev->cls,button_dev->devno);
err_class:
    class_destroy(button_dev->cls);
err_cdev_del:
    cdev_del(button_dev->cdev);
err_unregister:
    unregister_chrdev_region(button_dev->devno,1);
err_kfree:
    kfree(button_dev);
    return ret;
static void __exit button_exit(void)   //卸载函数-----在驱动被卸载时执行
    int i;
[1] [2]
关键字:多路复用  S5PV210 引用地址:代码示例_poll的多路复用
上一篇:内核提供的读写寄存器接口实现可移植性
下一篇:ARM—配置交叉编译环境
推荐阅读最新更新时间:2026-03-20 11:35
代码示例_poll多路复用
//头文件 #include linux/init.h #include linux/module.h #include linux/fs.h #include linux/device.h #include linux/slab.h #include linux/gpio.h #include linux/cdev.h #include linux/interrupt.h #include linux/input.h #include linux/sched.h #include linux/poll.h #include asm/io.h #include asm/string.h #include
[单片机]
Linux驱动入门(六)poll机制实现按键驱动
一、poll应用编程 二、驱动poll机制的实现 三、源码 四、测试 如何使用read阻塞去读取按键驱动,那么就意味着一个线程只能监听一个按键,如果想要监听多个按键,就需要启动多个线程,开启线程会耗费资源,并且多线程会增加编程难度,那么有没有一种机制,使得一个线程可以监听多路IO呢? Linux提供的select、poll、epoll机制,select、poll、epoll可以监听多路IO的状态,直到有IO满足条件(可读或可写等)时返回 其中select、poll系统调用的实现原理是类似的,epoll有别于这两者 但是对于底层驱动的实现都是一样的,都是实现驱动的poll函数 本文将介绍如何实现一个支持多路IO复用的驱动程序 一、p
[单片机]
S3C2440 开发板实战(9):poll机制
内核:linux -2.6.22.6 内核执行poll过程 从代码的角度来看,poll机制是通过应用程序调用poll() 函数,poll()函数的使用方法可以通过man poll进行查看,可仿照最终程序中进行改写,这里不做重复说明。配合驱动函数中相对应的drv_poll() 函数配套使用的。函数执行的入口当然是应用程序中的poll()函数,接着进入内核中的sys_poll() 函数,poll机制的函数在路经:linux/fs/select.c下,原代码如下: 739 asmlinkage long sys_poll(struct pollfd __user *ufds, unsigned int nfds, 740
[单片机]
S3C2440 开发板实战(9):<font color='red'>poll</font>机制
Tiny210驱动之按键poll机制
forth_drv.c驱动源码: #include linux/device.h #include linux/interrupt.h #include linux/module.h #include linux/kernel.h #include linux/fs.h #include linux/init.h #include linux/delay.h #include linux/irq.h #include asm/uaccess.h #include asm/irq.h #include asm/io.h #include mach/gpio.h #include linux/poll.h s
[单片机]
字符设备驱动程序之poll机制
驱动源码: #include linux/module.h #include linux/kernel.h #include linux/fs.h #include linux/init.h #include linux/delay.h #include linux/irq.h #include asm/uaccess.h #include asm/irq.h #include asm/io.h #include asm/arch/regs-gpio.h #include asm/hardware.h #include linux/poll.h int major = 0; st
[单片机]
字符设备驱动程序之<font color='red'>poll</font>机制
(一)S5PV210开发板常用易忘操作记录
一、调试串口 2、SD卡槽 (三)启动方式选择 蜂鸣器下面的白色2针插座(图中红色线圈出来的那个)为选择USB/SD卡启动的开关。默认情况下为SD卡启动,如果需要USB启动则使用短路帽(若没有短路帽,只要用其他金属导电物短路2根针即可)短接2个针脚,即可从USB启动。 (四)刷机 注意:刷andorid4.0系统使用uart2作为调试串口,android2.3、linux、wince都使用uart0作为调试串口;然后波特率设置为115200 用 fastboot 刷Android4.0: 用的镜像文件: uboot.bin、x210.img、zImage-android 用到的工具: DNW.exe fa
[单片机]
(一)<font color='red'>S5PV210</font>开发板常用易忘操作记录
S5PV210 点亮Led
GPC1CON, R/W, Address = 0xE020_0080 GPC1DAT, R/W, Address = 0xE020_0084 举例 #define GPC1CON *((volatile unsigned int*)0xE0200080) #define GPC1DAT *((volatile unsigned int*)0xE0200084) *(unsigned int*)GPC1CON &= ~(0xf 12); *(unsigned int*)GPC1CON |= (0x1 12); *(unsigned int*)GPC1DAT &= ~(0x1 3); *(un
[单片机]
<font color='red'>S5PV210</font> 点亮Led
基于s5pv210的uboot总结
1、启动过程特征总结   (1)第一阶段为汇编阶段、第二阶段为C阶段   (2)第一阶段在SRAM中、第二阶段在DRAM中   (3)第一阶段注重SoC内部、第二阶段注重SoC外部Board内部 2、uboot的第一阶段做了哪些工作   (1)构建异常向量表   (2)设置CPU为SVC模式   (3)关看门狗   (4)开发板供电置锁   (5)时钟初始化   (6)DDR初始化   (7)串口初始化并打印 OK   (8)重定位   (9)建立映射表并开启MMU   (10)跳转到第二阶段 3、uboot第二阶段主要是对开发板级别的硬件、软件数据结构进行初始化。   init_sequence   cpu_init 空的
[单片机]
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
