stm32之DMA研究
发布者:和谐共融最新更新时间:2024-10-18 来源: cnblogs关键字:stm32  DMA  传输通道 手机看文章 扫描二维码
随时随地手机看文章
        //设置系统SYSCLK时钟为HSE输入
        RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
        //等待时钟切换成功
        while(RCC_GetSYSCLKSource() != 0x04);
    //下面是给各模块开启时钟
    //启动GPIO
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                           RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD,
                           ENABLE);
    //启动AFIO
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
    //启动USART1
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE);
    //启动DMA时钟
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : GPIO设置
* Input          : None
* Output         : None
* Return         : None
void GPIO_Configuration(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    //PC口4567脚设置GPIO输出,推挽 2M
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    //KEY2 KEY3 JOYKEY
    //位于PD口的3 4 11-15脚,使能设置为输入
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_11 | GPIO_Pin_12 |
        GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    //USART1_TX
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    //USART1_RX
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
* Function Name  : NVIC_Configuration
* Description    : NVIC设置
* Input          : None
* Output         : None
* Return         : None
void NVIC_Configuration(void)
    NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
    // Set the Vector Table base location at 0x20000000
    NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
    // Set the Vector Table base location at 0x08000000
    NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
    //设置NVIC优先级分组为Group2:0-3抢占式优先级,0-3的响应式优先级
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
    //串口接收中断打开
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
* Function Name  : USART1_Configuration
* Description    : NUSART1设置
* Input          : None
* Output         : None
* Return         : None
void USART1_Configuration(void)
    USART_InitTypeDef USART_InitStructure;
    USART_InitStructure.USART_BaudRate = 9600;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Tx | USART_Mode_Rx;
    USART_Init(USART1, &USART_InitStructure);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    USART_Cmd(USART1, ENABLE);
void DMA_Configuration(void)
    DMA_InitTypeDef DMA_InitStructure;
    //DMA设置:
    //设置DMA源:内存地址&串口数据寄存器地址
    //方向:内存-->外设
    //每次传输位:8bit
    //传输大小DMA_BufferSize=SENDBUFF_SIZE
    //地址自增模式:外设地址不增,内存地址自增1
    //DMA模式:一次传输,非循环
    //优先级:中
    DMA_DeInit(DMA1_Channel4);//串口1的DMA传输通道是通道4
    DMA_InitStructure.DMA_PeripheralBaseAddr = USART1_DR_Base;
    DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SendBuff;
    DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;//外设作为DMA的目的端
    DMA_InitStructure.DMA_BufferSize = SENDBUFF_SIZE;//传输大小
    DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址不增加
    DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;//内存地址自增1
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
    DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
    DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//DMA_Mode_Normal(只传送一次), DMA_Mode_Circular (不停地传送)
    DMA_InitStructure.DMA_Priority = DMA_Priority_Medium;//(DMA传送优先级为中等)
    DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel4, &DMA_InitStructure);
需要说明的是,由于DMA传输不需要CPU的参与。
所以在调试的时候会发现,在我们单步停止的时候,串口依然不停地向外发送数据。
[1] [2]
关键字:stm32  DMA  传输通道 引用地址:stm32之DMA研究
上一篇:STM32管脚重定义
下一篇:stm32之DMA中断
推荐阅读最新更新时间:2026-02-14 07:40
STM32F4系列的DMA请求与DMA传输通道的映射关系
STM32家族中的有些系列,比如STM32G0/STM32G4/STM32L4+/STM32H7等系列都内置了DMAMUX模块,它是干什么用的?跟DMA有什么关联? 简单点说,它是DMA请求中转调度器,或说DMA请求路由器。基本功能就是将各路DMA请求经过它的再分配调度后连接到相应的DMA控制器传输通道以实现DMA传输。 用过不带DMAMUX的STM32芯片的DMA模块的人可能会问,之前没这个模块,不是照样用吗?外设申请DMA请求,DMA控制器做出应答响应后即可实现DMA传输。为什么后面推出的STM32系列往往要增加这个DMA请求复用路由器呢? 我们不妨先看看那些片内不带DMAMUX的DMA外设请求与DMA传输通道的关系。 下
[单片机]
STM32F4系列的<font color='red'>DMA</font>请求与<font color='red'>DMA</font><font color='red'>传输</font><font color='red'>通道</font>的映射关系
stm32 ,DMA,adc,fft. . .(基于库函数)
用TIM2定时器触发adc,DMA采集之后进行fft转换. fft是一种快速傅里叶算法. 官方给的256点运算时间仅需要0.362ms,1024点也只要2.138ms(72mHz) 傅里叶变换就像是将一桶各个颜色混杂在一起的油漆分离出来.并将每种颜料的含量也计算出来. 而各种颜色代表了各种频率,含量代表幅值.(个人的浅显理解) 了解个差不多就可以开始了~ 先将fft的官方库添加到自己的工程.(https://pan.baidu.com/s/1Gw1NXCa3q8SHxc-E1H-6yw 提取码:m1et) 添加之后可以看到官方提供了两种快速傅里叶变换函数,分别为256点和1024点.这里视自己情况进行使用.不过要注意在这之前要调用
[单片机]
STM32 DMA技术全方位解析:原理、实战及应用指南
知识点1【DMA的介绍】 直接内存访问(DMA)用来提供在外设和存储器之间或者存储器和存储器之间的高速数据传输,无需CPU的干预,数据可以通过DMA快速地移动,这就节省了CPU的资源,来做其他的操作——提高CPU的效率 在STM32F103ZET6中 两个DMA控制器 12个通道:DMA1(7个),DMA2(5个) 每个通道用来专门管理来自于一个或多个外设对存储器访问的请求。还有一个仲裁其来协调各个DMA请求的优先权 下面我分析一下这张框图 1、DMA框图 寄存器是一种特殊的SRAM,CPU可以对寄存器进行读写,进而来来操作外设,寄存器是软件和硬件之间的桥梁。 内核外设有 NVIC和SysTick 总线矩阵左端 是主动单
[单片机]
<font color='red'>STM32</font> <font color='red'>DMA</font>技术全方位解析:原理、实战及应用指南
STM32 SPI DMA通信详解
今天被要求做了实验,要求提升SPI读写数据速度,那首先想到的就是提升SPI的速率以及添加DMA了,很简单,跟着做就好。 芯片: STM32F103,我是HKF103国产的,大差不差。 软件:STM32CUBEMX,非常方便的配置软件 编译IDE:KEIL和vscode均可 1.参数配置 2.DMA配置,全部默认就行 3.中断,三个都打开 4.生成代码后添加代码 定义两个标志位,用来表示接收完成。 添加回调函数,在回调函数里置标志位。 我用SPI来读写W25QXX的芯片,而我用到了SFUD,我在底层里这样实现。如果你用W25的库函数可以参照着改一下,大差不大的都。 最终速率比较客观,读取16m的F
[单片机]
<font color='red'>STM32</font> SPI <font color='red'>DMA</font>通信详解
案例 stm32单片机,adc的双通道+dma 内部温度
可以这样理解 先配置adc :有几个通道就配置几个通道. 然后配置dma,dma是针对adc的,而不是针对通道的. 一开始我以为一个adc通道对应一个dma通道.(这里是错的,其实是我想复杂了) 一个adc,对应一个dma. adc可以开多个通道.比如采集电池的电量是一个通道,采集单片机温度是另一个通道. adc1的所有通道对应着dma的某一个通道. 然后开启后dma,就会依次把各通道的数据存入数组: 数组元素1: 通道1的数据 数组元素2: 通道2的数据 数组元素3: 通道3的数据 数组元素4: 通道4的数据 数组元素5: 通道5的数据 然后又会从头存,一直循环下去....
[单片机]
stm32DMA重新工作
下面是在战舰V3寄存器程序例子中找到的: //开启一次DMA传输 void MYDMA_Enable(DMA_Channel_TypeDef*DMA_CHx) { DMA_CHx- CCR&=~(1 0); //关闭DMA传输 DMA_CHx- CNDTR=DMA1_MEM_LEN; //DMA1,传输数据量 DMA_CHx- CCR|=1 0; //开启DMA传输 }
[单片机]
<font color='red'>stm32</font>的<font color='red'>DMA</font>重新工作
STM32 USART使用DMA设置
1、外设时钟初始化 首先初始化需要用到的外围设备设备的时钟,需要初始化的始终有USART RX DMA使用的DMA1、USART1、USART1使用的GPIO、AFIO(如果USART的管脚需要Remap则需要打开否则不用); /* DMA clock enable (USART RX using dma1) */ RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); /* USART clock */ RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); /* Enable GPIO cloc
[单片机]
STM32串口收发数据为什么要使用DMA?有哪些常见问题?
直接存储器访问(Direct Memory Access),简称DMA。DMA是CPU一个用于数据从一个地址空间到另一地址空间“搬运”(拷贝)的组件,数据拷贝过程不需CPU干预,数据拷贝结束则通知CPU处理。因此,大量数据拷贝时,使用DMA可以释放CPU资源。 在STM32控制器中,芯片采用Cortex-M3架构,总线结构有了很大的优化,DMA占用另外的总线,并不会与CPU的系统总线发生冲突。也就是说,DMA的使用不会影响CPU的运行速度。 DMA数据拷贝过程,典型的有:(1)内存— 内存,内存间拷贝;(2)外设— 内存,如uart、spi、i2c等总线接收数据过程;(3)内存— 外设,如uart、spi、i2c等总线发送
[单片机]
<font color='red'>STM32</font>串口收发数据为什么要使用<font color='red'>DMA</font>?有哪些常见问题?
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
