UART学习笔记
发布者:meirong最新更新时间:2024-10-17 来源: cnblogs关键字:UART  串口 手机看文章 扫描二维码
随时随地手机看文章
串口(UART)
DIV_VAL = (PCLK / (bps x 16 ) ) −1
        35 =  115200/66.5/16-1
查看芯片手册:
GPACON  0x7F008000  R/W  Port A Configuration Register  0x0000
GPA0  [3:0]  0000 = Input   0001 = Output
0010 = UART RXD[0]  0011 = Reserved
0100 = Reserved  0101 = Reserved
0110 = Reserved  0111 = External Interrupt Group 1 [0]
0000
GPA1  [7:4]  0000 = Input   0001 = Output
0010 = UART TXD[0]  0011 = Reserved
0110 = Reserved  0111 = External Interrupt Group 1 [1]
0000
ULCON0 0x7F005000 R/W UART channel 0 line control register  0x00
Reserved [7]  0
Infra-Red Mode  [6]  Determine whether ornot to use the Infra-Red mode.
0 = Normal mode operation
1 = Infra-Red Tx/Rx mode
Parity Mode  [5:3]  Specify the type of parity generation and checking during
UART transmit and receive operation.
0xx = No parity
100 = Odd parity
101 = Even parity
110 = Parity forced/checked as 1
111 = Parity forced/checked as 0
000
Number of Stop Bit  [2]  Specify how many stop bits are to be used for end-of-frame
signal.
0 = One stop bit per frame
1 = Two stop bit per frame
Word Length  [1:0]  Indicate the number ofdata bits to be transmitted or received
per frame.
00 = 5-bit 01 = 6-bit
10 = 7-bit 11 = 8-bit
UCON0 0x7F005004 R/W UART channel 0 control register  0x00
Transmit Mode  [3:2]  Determine which function is currently able to write Tx data to the
UART transmit buffer register.
00 = Disable
01 = Interrupt request or polling mode
10 = DMA request (DMA_UART0)
11 = DMA request (DMA_UART1)
00
Receive Mode  [1:0]  Determine which function is currently able to read data from UART
receive buffer register.
00 = Disable
UFCON0 0x7F005008 R/W UART channel 0 FIFO control register  0x0
FIFO Enable  [0]  0 = Disable 1 = Enable  0
UMCON0 0x7F00500C R/W UART channel 0 Modem control register  0x0
DIV_VAL = UBRDIVn + (num of 1’s in UDIVSLOTn)/16
For example, if the baud-rate is 115200 bps and EXT_UCLK0 is UART baud-rate clock and 40 MHz, UBRDIVn
and UDIVSLOTn are:
 DIV_VAL  = (40000000 / (115200 x 16) ) -1  = 21.7 -1
= 20.7
UBRDIVn = 20 (integer part of DIV_VAL )
 (num of 1’s in UDIVSLOTn)/16 = 0.7
 then, (num of 1’s in UDIVSLOTn) = 11
66.5mhz*10(6)=66500000
UBRDIV0  0x7F005028  R/W  Baud rate divisior register 0  0x0000
UDIVSLOT0  0x7F00502C  R/W  Baud rate divisior register 0  0x0000
UFSTAT0 0x7F005018 R UART channel 0 FIFO status register  0x00
Tx FIFO Full  [14]  Set to 1 automatically whenever transmit FIFO is full
during transmit operation
0 = 0-byte ≤Tx FIFO data ≤63-byte
1 = Full
Tx FIFO Count  [13:8]  Number of data in Tx FIFO  0
Reserved [7]  0
Rx FIFO Full  [6]  Set to 1 automaticallywhenever receive FIFO is full during
receive operation
0 = 0-byte ≤Rx FIFO data ≤63-byte
1 = Full
Rx FIFO Count  [5:0]  Number of data in Rx FIFO  0
URXH0  0x7F005024  R  UART channel 0 receive buffer register  0x00
UTXH0  0x7F005020  W  UART channel 0 transmit buffer register  -
1 = Full
示例代码如下:
#define ULCON0     (*((volatile unsigned long *)0x7F005000))
#define UCON0      (*((volatile unsigned long *)0x7F005004))
#define UFCON0     (*((volatile unsigned long *)0x7F005008))
#define UMCON0     (*((volatile unsigned long *)0x7F00500C))
#define UTRSTAT0   (*((volatile unsigned long *)0x7F005010))
#define UFSTAT0    (*((volatile unsigned long *)0x7F005018))
#define UTXH0      (*((volatile unsigned char *)0x7F005020))
#define URXH0      (*((volatile unsigned char *)0x7F005024))
#define UBRDIV0    (*((volatile unsigned short *)0x7F005028))
#define UDIVSLOT0  (*((volatile unsigned short *)0x7F00502C))
#define GPACON     (*((volatile unsigned long*)0x7F008000))
void init_uart(void)
/*将GPACON的前八位清零*/
/*1010 1010*/
/*0000 0000 (~0xff)*/
/*0000 0000*/
GPACON &= ~0xff;
/*设GPACON初值*/
GPACON |= 0x22;
/* ULCON0 */
ULCON0 = 0x3;  /* 数据位:8, 无较验, 停止位: 1, 8n1 */
UCON0  = 0x5;  /* 使能UART发送、接收 */
UFCON0 = 0x01; /* FIFO ENABLE */
UMCON0 = 0;
/* 波特率 */
/* DIV_VAL = (PCLK / (bps x 16 ) ) - 1
 * bps = 57600
 * DIV_VAL = (66500000 / (115200 x 16 ) ) - 1
 *         = 35.08
UBRDIV0   = 35;
/* x/16 = 0.08
 * x = 1
UDIVSLOT0 = 0x1;
char getchar(void)
while ((UFSTAT0 & (1<<6)) == 0 && (UFSTAT0 & 0x3f) == 0);
return URXH0;
void putchar(char c)
while ((UFSTAT0 & (1<<14));
UTXH0 = c;
关键字:UART  串口 引用地址:UART学习笔记
上一篇:系统时钟学习笔记
下一篇:uboot理解
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
