12m晶振 ----->pll ------> cpu
Mux 多路选择器
Div 分频器
示例代码如下:
汇编实现
.globl clock_init
clock_init:
/* 1.设置LOCK_TIME */
ldr r0, =0x7E00F000 /* APLL_LOCK */
ldr r1, =0x0000FFFF
str r1, [r0]
str r1, [r0, #4] /* MPLL_LOCK */
str r1, [r0, #8] /* EPLL_LOCK */
#define OTHERS 0x7e00f900
@ set async mode /* 当CPU时钟 != HCLK时,要设为异步模式 */
ldr r0, =OTHERS
ldr r1, [r0]
bic r1, #0xc0
str r1, [r0]
loop1: /* 等待,直到CPU进入异步模式 */
ldr r0, =OTHERS
ldr r1, [r0]
and r1, #0xf00
cmp r1, #0
bne loop1
/* SYNC667 */
/* MISC_CON[19] = 0 */
#define ARM_RATIO 0 /* ARMCLK = DOUTAPLL / (ARM_RATIO + 1) */
#define HCLKX2_RATIO 1 /* HCLKX2 = HCLKX2IN / (HCLKX2_RATIO + 1) */
#define HCLK_RATIO 1 /* HCLK = HCLKX2 / (HCLK_RATIO + 1) */
#define PCLK_RATIO 3 /* PCLK = HCLKX2 / (PCLK_RATIO + 1) */
#define MPLL_RATIO 0 /* DOUTMPLL = MOUTMPLL / (MPLL_RATIO + 1) */
ldr r0, =0x7E00F020 /* CLK_DIV0 */
ldr r1, =(ARM_RATIO) | (MPLL_RATIO << 4) | (HCLK_RATIO << 8) | (HCLKX2_RATIO << 9) | (PCLK_RATIO << 12)
str r1, [r0]
/* 2.配置时钟 */
/* 2.1 配置APLL */
/* 2.1.1 设置APLL
* 2.1.2 MUXAPLL
* 2.1.3 SYNC667
* 2.1.4 DIVAPLL
#define APLL_CON_VAL ((1<<31) | (266 << 16) | (3 << 8) | (1))
ldr r0, =0x7E00F00C
ldr r1, =APLL_CON_VAL
str r1, [r0] /* APLL_CON, FOUTAPL = MDIV * Fin / (PDIV*2^SDIV) = 266*12/(3*2^1) = 532MHz */
/* 2.2 配置MPLL */
/* 2.2.1 设置MPLL
* 2.2.2 MUXMPLL
* 2.2.3 SYNCMUX
* 2.2.4 SYNC667
* 2.2.5 HCLKX2_RATIO
* 2.2.6 PCLK_RATIO
#define MPLL_CON_VAL ((1<<31) | (266 << 16) | (3 << 8) | (1))
ldr r0, =0x7E00F010
ldr r1, =MPLL_CON_VAL
str r1, [r0] /* MPLL_CON, FOUTMPL = MDIV * Fin / (PDIV*2^SDIV) = 266*12/(3*2^1) = 532MHz */
/* 3.选择PLL的输出作为时钟源 */
ldr r0, =0x7E00F01C
ldr r1, =0x03
str r1, [r0]
mov pc, lr
C实现
#define APLL_LOCK (*((volatile unsigned long *)0x7E00F000))
#define MPLL_LOCK (*((volatile unsigned long *)0x7E00F004))
#define EPLL_LOCK (*((volatile unsigned long *)0x7E00F008))
#define OTHERS (*((volatile unsigned long *)0x7E00F900))
#define CLK_DIV0 (*((volatile unsigned long *)0x7E00F020))
#define ARM_RATIO 0
#define HCLKX2_RATIO 4
#define HCLK_RATIO 0
#define PCLK_RATIO 1
#define APLL_CON (*((volatile unsigned long *)0x7E00F00C))
#define APLL_CON_VAL ((1<<31)|(250<<16)|(3<<8)|(1))
#define MPLL_CON (*((volatile unsigned long *)0x7E00F010))
#define MPLL_CON_VAL ((1<<31)|(250<<16)|(3<<8)|(1))
#define CLK_SRC (*((volatile unsigned long *)0x7E00F01C))
void clock_init(void){
APLL_LOCK=0XFFFF;
MPLL_LOCK=0XFFFF;
EPLL_LOCK=0XFFFF;
/*当CPU时钟!=HCLK时,要设为异步模式*/
OTHERS&=~0XC0;
while((OTHERS&0XF00)!=0);
CLK_DIV0=(ARM_RATIO)|(MPLL_RATIO<<4)|(HCLK_RATIO<<8)|(HCLKX2_RATIO<<9)|(PCLK_RATIO<<12);
APLL_CON=APLL_CON_VAL;/*500MHZ*/
MPLL_CON=MPLL_CON_VAL;/*500MHZ*/
CLK_SRC=0X03;
推荐阅读最新更新时间:2026-03-21 04:00
- LM2904DMR2G 函数发生器运算放大器的典型应用
- DEMO9RS08KA2: DEMO9RS08KA2 Demonstration Board
- MCP73871EV,MCP73871 锂离子电池充电器评估板
- STEVAL-IHM039V1,采用 STM32F415 微控制器的双电机控制演示板
- LTC1606CG 演示板、16 位、250ksps ADC
- RT8086B 3.5A、1.2MHz、同步降压转换器的典型应用
- TS4999EIJT 典型应用 免滤波器立体声 2.8 W D 类音频功率放大器,可选择 3D 音效
- LTM4615,采用 15mm-15mm 封装的完整双路和三路输出负载点模块稳压器
- LTC2415-1IGN 24 位 ADC 的典型应用电路使用电阻器阵列在励磁放大器中提供精确匹配
- 使用 Analog Devices 的 LTC1450LIN 的参考设计
HMC7044配置上位机
嵌入式视频应用系统设计与实现 基于TI DaVinci DM355处理器
现代雷达系统的信号设计
BFR340T
京公网安备 11010802033920号
