hugepages= [HW,IA-32,IA-64] Maximal number of HugeTLB pages.
noirqbalance [IA-32,SMP,KNL] Disable kernel irq balancing
i8042.direct [HW] Put keyboard port into non-translated mode
i8042.dumbkbd [HW] Pretend that controlled can only read data from
keyboard and can not control its state
(Don't attempt to blink the leds)
i8042.noaux [HW] Don't check for auxiliary (== mouse) port
i8042.nokbd [HW] Don't check/create keyboard port
i8042.nomux [HW] Don't check presence of an active multiplexing
controller
i8042.nopnp [HW] Don't use ACPIPnP / PnPBIOS to discover KBD/AUX
controllers
i8042.panicblink=
[HW] Frequency with which keyboard LEDs should blink
when kernel panics (default is 0.5 sec)
i8042.reset [HW] Reset the controller during init and cleanup
i8042.unlock [HW] Unlock (ignore) the keylock
i810= [HW,DRM]
i8k.ignore_dmi [HW] Continue probing hardware even if DMI data
indicates that the driver is running on unsupported
hardware.
i8k.force [HW] Activate i8k driver even if SMM BIOS signature
does not match list of supported models.
i8k.power_status
[HW] Report power status in /proc/i8k
(disabled by default)
i8k.restricted [HW] Allow controlling fans only if SYS_ADMIN
capability is set.
ibmmcascsi= [HW,MCA,SCSI] IBM MicroChannel SCSI adapter
See Documentation/mca.txt.
icn= [HW,ISDN]
Format: ide= [HW] (E)IDE subsystem Format: ide=nodma or ide=doubler or ide=reverse See Documentation/ide.txt. ide?= [HW] (E)IDE subsystem Format: ide?=noprobe or chipset specific parameters. See Documentation/ide.txt. idebus= [HW] (E)IDE subsystem - VLB/PCI bus speed See Documentation/ide.txt. idle= [HW] Format: idle=poll or idle=halt ihash_entries= [KNL] Set number of hash buckets for inode cache. in2000= [HW,SCSI] See header of drivers/scsi/in2000.c. init= [KNL] Format: Run specified binary instead of /sbin/init as init process. initcall_debug [KNL] Trace initcalls as they are executed. Useful for working out where the kernel is dying during startup. initrd= [BOOT] Specify the location of the initial ramdisk inport.irq= [HW] Inport (ATI XL and Microsoft) busmouse driver Format: inttest= [IA64] io7= [HW] IO7 for Marvel based alpha systems See comment before marvel_specify_io7 in arch/alpha/kernel/core_marvel.c. ip= [IP_PNP] See Documentation/nfsroot.txt. ip2= [HW] Set IO/IRQ pairs for up to 4 IntelliPort boards See comment before ip2_setup() in drivers/char/ip2.c. ips= [HW,SCSI] Adaptec / IBM ServeRAID controller See header of drivers/scsi/ips.c. irqfixup [HW] When an interrupt is not handled search all handlers for it. Intended to get systems with badly broken firmware running. irqpoll [HW] When an interrupt is not handled search all handlers for it. Also check all handlers each timer interrupt. Intended to get systems with badly broken firmware running. isapnp= [ISAPNP] Format: isolcpus= [KNL,SMP] Isolate CPUs from the general scheduler. Format: This option can be used to specify one or more CPUs to isolate from the general SMP balancing and scheduling algorithms. The only way to move a process onto or off an 'isolated' CPU is via the CPU affinity syscalls. 'number of CPUs in system - 1'. This option is the preferred way to isolate CPUs. The alternative -- manually setting the CPU mask of all tasks in the system -- can cause problems and suboptimal load balancer performance. isp16= [HW,CD] Format:
上一篇:s3c2440对nandflash的操作1
下一篇:GCC 内联汇编(GCC内嵌ARM汇编规则)
推荐阅读最新更新时间:2026-03-03 22:39
- LT1964 的典型应用 - 200mA、低噪声、低压差负微功率稳压器
- NSI45030AZT1G 大电流 LED 灯串的典型应用
- LTC4419IDD 18V 双输入微电源路径优先器的典型应用电路
- 使用 Silicon Labs 的 EZR32WG330F256R63G 的参考设计
- 使用 Analog Devices 的 LT3467AES67 的参考设计
- 使用 Analog Devices 的 LT1183CS 的参考设计
- 基于HVLED815PF和SPSGRF的智能家居照明
- LT3430 的典型应用 - 高电压、3A、200kHz 降压型开关稳压器
- 仪器模拟放大
- Protues仿真实例(8051)-PCF8574应用.rar
Windows驱动开发技术详解
非常经典的关于LLC的杨波博士论文
ASM10DTBD-S664
京公网安备 11010802033920号
