c101= [NET] Moxa C101 synchronous serial card
cachesize= [BUGS=IA-32] Override level 2 CPU cache size detection.
Sometimes CPU hardware bugs make them report the cache
size incorrectly. The kernel will attempt work arounds
to fix known problems, but for some CPUs it is not
possible to determine what the correct size should be.
This option provides an override for these situations.
cdu31a= [HW,CD]
Format: See header of drivers/cdrom/cdu31a.c. chandev= [HW,NET] Generic channel device initialisation checkreqprot [SELINUX] Set initial checkreqprot flag value. Format: { '0' | '1' } See security/selinux/Kconfig help text. 0 -- check protection applied by kernel (includes any implied execute protection). 1 -- check protection requested by application. Default value is set via a kernel config option. Value can be changed at runtime via /selinux/checkreqprot. clock= [BUGS=IA-32,HW] gettimeofday timesource override. Forces specified timesource (if avaliable) to be used when calculating gettimeofday(). If specicified timesource is not avalible, it defaults to PIT. Format: { pit | tsc | cyclone | pmtmr } hpet= [IA-32,HPET] option to disable HPET and use PIT. Format: disable cm206= [HW,CD] Format: { auto | [ com20020= [HW,NET] ARCnet - COM20020 chipset Format: com90io= [HW,NET] ARCnet - COM90xx chipset (IO-mapped buffers) Format: com90xx= [HW,NET] ARCnet - COM90xx chipset (memory-mapped buffers) Format: condev= [HW,S390] console device conmode= console= [KNL] Output console device and options. tty ttyS Use the specified serial port. The options are of the form 'bbbbpn', where 'bbbb' is the baud rate, 'p' is parity ('n', 'o', or 'e'), and 'n' is bits. Default is '9600n8'. See also Documentation/serial-console.txt. uart,io, uart,mmio, Start an early, polled-mode console on the 8250/16550 UART at the specified I/O port or MMIO address, switching to the matching ttyS device later. The options are the same as for ttyS, above. cpcihp_generic= [HW,PCI] Generic port I/O CompactPCI driver Format: cpia_pp= [HW,PPT] Format: { parport crashkernel=nn[KMG]@ss[KMG] [KNL] Reserve a chunk of physical memory to hold a kernel to switch to with kexec on panic. cs4232= [HW,OSS] Format: cs89x0_dma= [HW,NET] Format: cs89x0_media= [HW,NET] Format: { rj45 | aui | bnc } cyclades= [HW,SERIAL] Cyclades multi-serial port adapter. dasd= [HW,NET] See header of drivers/s390/block/dasd_devmap.c. db9.dev[2|3]= [HW,JOY] Multisystem joystick support via parallel port (one device per port) Format: See also Documentation/input/joystick-parport.txt debug [KNL] Enable kernel debugging (events log level). decnet= [HW,NET] Format: [, See also Documentation/networking/decnet.txt. devfs= [DEVFS] See Documentation/filesystems/devfs/boot-options. dhash_entries= [KNL] Set number of hash buckets for dentry cache. digi= [HW,SERIAL] IO parameters + enable/disable command. digiepca= [HW,SERIAL] See drivers/char/README.epca and Documentation/digiepca.txt. dmascc= [HW,AX25,SERIAL] AX.25 Z80SCC driver with DMA support available.
上一篇:s3c2440对nandflash的操作1
下一篇:GCC 内联汇编(GCC内嵌ARM汇编规则)
推荐阅读最新更新时间:2026-02-21 23:50
- 采用双电源模块的 LTC3882EUJ-1 高密度、1.5V/45A、650kHz 降压转换器的典型应用电路
- FEBFIS1100MEMS_IMU6D3X,评估板基于 FIS1100 6D 惯性测量单元,带有运动协处理器和传感器融合库
- X-NUCLEO-IHM02A1,基于用于 STM32 Nucleo 的 L6470 两轴步进电机驱动器的扩展板
- 适用于正负输入电压的高精度、低成本、单电源 ADC
- 使用基于 ADuC7020 ARM7 MCU 的单个加速度计提高计步器的性能
- OP497GSZ精密绝对值运算放大器典型应用电路
- NCV7471B5V1GEVB:NCV7471B 系统基础芯片 250mA 评估板
- LTC2945CUD 电源监控在 -48V 恶劣环境中的典型应用,使用 INTVCC 并联稳压器来承受 200V 瞬态
- 1.8V DC 至 DC 单输出便携式电源
- EV1HMC1120LP4、HMC1120LP4E 射频集成电路评估板
- 艾利特CSF系列力控协作机器人来了!
- MTBF突破4万小时!这家工业级3D相机品牌产品稳定性获权威机构认可
- 英特尔创始人、“摩尔定律”提出者戈登·摩尔去世
- 本周机器人行业大事件TOP5
- G20周刊|埃斯顿与北自所达成战略合作、海康机器人发布光伏组件汇流带视觉检测解决方案
- 安兔兔谈手机跑分:厂商优化很重要,成绩仅供参考
- 性能跑分比标压i5强悍?疑似新iPad Pro跑分亮相GeekBench跑分库
- 为应对游戏容量越来越大,索尼公布 2TB 版本 PS4 Pro
- IC Insights:IC市场Q4增速降至6%,半导体产业进入周期性降温
- 大容量+支持双卡,三星折叠手机 Galaxy F 发布将进入倒计时
Windows驱动开发技术详解
非常经典的关于LLC的杨波博士论文
XC6406PP60DL
京公网安备 11010802033920号
