Format: dmasound= [HW,OSS] Sound subsystem buffers dscc4.setup= [NET] dtc3181e= [HW,SCSI] earlyprintk= [IA-32,X86-64] earlyprintk=vga earlyprintk=serial[,ttySn[,baudrate]] Append ',keep' to not disable it when the real console takes over. Only vga or serial at a time, not both. Currently only ttyS0 and ttyS1 are supported. Interaction with the standard serial driver is not very good. The VGA output is eventually overwritten by the real console. eata= [HW,SCSI] eda= [HW,PS2] edb= [HW,PS2] edd= [EDD] Format: {'of[f]' | 'sk[ipmbr]'} See comment in arch/i386/boot/edd.S eicon= [HW,ISDN] Format: eisa_irq_edge= [PARISC,HW] See header of drivers/parisc/eisa.c. elanfreq= [IA-32] See comment before function elanfreq_setup() in arch/i386/kernel/cpu/cpufreq/elanfreq.c. elevator= [IOSCHED] Format: {'as' | 'cfq' | 'deadline' | 'noop'} See Documentation/block/as-iosched.txt and Documentation/block/deadline-iosched.txt for details. elfcorehdr= [IA-32] Specifies physical address of start of kernel core image elf header. See Documentation/kdump.txt for details. enforcing [SELINUX] Set initial enforcing status. Format: {'0' | '1'} See security/selinux/Kconfig help text. 0 -- permissive (log only, no denials). 1 -- enforcing (deny and log). Default value is 0. Value can be changed at runtime via /selinux/enforce. es1370= [HW,OSS] Format: See also header of sound/oss/es1370.c. es1371= [HW,OSS] Format: See also header of sound/oss/es1371.c. ether= [HW,NET] Ethernet cards parameters This option is obsoleted by the 'netdev=' option, which has equivalent usage. See its documentation for details. eurwdt= [HW,WDT] Eurotech CPU-1220/1410 onboard watchdog. Format: fd_mcs= [HW,SCSI] See header of drivers/scsi/fd_mcs.c. fdomain= [HW,SCSI] See header of drivers/scsi/fdomain.c. floppy= [HW] See Documentation/floppy.txt. ftape= [HW] Floppy Tape subsystem debugging options. See Documentation/ftape.txt. gamecon.map[2|3]= [HW,JOY] Multisystem joystick and NES/SNES/PSX pad support via parallel port (up to 5 devices per port) Format: See also Documentation/input/joystick-parport.txt gamma= [HW,DRM] gdth= [HW,SCSI] See header of drivers/scsi/gdth.c. gpt [EFI] Forces disk with valid GPT signature but invalid Protective MBR to be treated as GPT. gscd= [HW,CD] Format: gt96100eth= [NET] MIPS GT96100 Advanced Communication Controller gus= [HW,OSS] Format: gvp11= [HW,SCSI] hashdist= [KNL,NUMA] Large hashes allocated during boot are distributed across NUMA nodes. Defaults on for IA-64, off otherwise. Format: 0 | 1 (for off | on) hcl= [IA-64] SGI's Hardware Graph compatibility layer hd= [EIDE] (E)IDE hard drive subsystem geometry Format: hd?= [HW] (E)IDE subsystem hd?lun= See Documentation/ide.txt. highmem=nn[KMG] [KNL,BOOT] forces the highmem zone to have an exact size of highmem otherwise. This also works to reduce highmem size on bigger boxes. hisax= [HW,ISDN] See Documentation/isdn/README.HiSax.
上一篇:s3c2440对nandflash的操作1
下一篇:GCC 内联汇编(GCC内嵌ARM汇编规则)
推荐阅读最新更新时间:2025-12-19 09:47
- 具有低电池电量指示的 MCP1258 稳压 3.3V、低纹波电荷泵和低工作电流睡眠模式或旁路模式的典型应用
- NCS36510GEVK:适用于 2.4 GHz IEEE 802.15.4-2006 应用评估套件的低功耗片上系统
- 用于完整 3V、12 位、1MHz 模数转换系统的 AD8601ARTZ-REEL7 运算放大器的典型应用
- LTC4368CDD-2 100V UV/OV 和具有双向断路器的反向保护控制器的典型应用电路
- LT1307CN8 单节 CCFL 电源典型应用电路
- 3.3V 直流转直流单输出医疗电源
- 用于手机的 6-LED 通用 LED 驱动器
- EVAL-AD7656SDZ,AD7656 ADC 评估板
- MC78M08ABDTG 8V 电流升压稳压器的典型应用
- 使用 Silicon Labs 的 Si51211-A16AFMR 的参考设计
Python编程无师自通 专业程序员的养成 ([美]科里·奥尔索夫(Cory Althoff))
非常经典的关于LLC的杨波博士论文
XC6406PP60DL
京公网安备 11010802033920号
