mini2440 Norflash驱动移植过程
发布者:Lianai最新更新时间:2024-06-19 来源: elecfans关键字:mini2440  Norflash  驱动移植 手机看文章 扫描二维码
随时随地手机看文章
我不知道友善linux2.6.32的内核是否支持了mini2440的norflash,我在这里还是亲自的把mini2440的norflash支持上。移植过程分享如下:
一.添加配置项
1、修改 drivers/mtd/maps/Kconfig文件,在config_EDB7312配置项下添加如下内容:
config MTD_MINI2440
tristate 'CFI Flash device mapped onMINI2440'
depends on ARM && MTD_CFI
help
This enables access to the CFI Flash on the CogentMINI2440 board.
If you have such a board, say 'Y' here.
2、修改 drivers/mtd/maps/Makefile文件,在obj-$(CONFIG_MTD_EDB7312)+= edb7312.o下添加如下内容:
obj-$(CONFIG_MTD_MINI2440)+= mini2440.o
3、复制驱动文件mini2440.c到drivers/mtd/maps目录下
二.配置编译内核
# make menuconfig
以下内容必选:
Memory Technology Devices(MTD)-->
<*>Memory Technology Device (MTD) support
[*]MTD partitioning support
  <*>Direct char device access to MTD devices
  <*>Caching block device access to MTD devices
RAM/ROM/Flash chip drivers-->
  <*>Detect flash chips by Common Flash Interface (CFI) probe
  <*>Support for Inter/Sharp flash chips
  <*>Supportfor AMD/Fujitsu/Spansion flash chips
  <*>CFI flash device mapped on mini2440
下列内容(在flash上架fat16/fat32/ntfs/ext2等文件系统时才需要选上)不要选,否则会出现加载驱动模块时会出现ftl_cs:FTL header not found.
DeviceDrivers ->
  Memory Technology Devices (MTD) ->
      <>FTL (Flash Translation Layer) support
      <> NFTL(NAND Flash Translation Layer) support
      <>INFTL(Inverse NAND Flash Translation Layer) support
三.根据edb7312单板的norflash驱动(linux/mtd/maps/edb7312.c)来写mini2440的norflash驱动
代码在mini2440.c中(带详细注释)
/*支持单板:mini2440
*支持内核:3.1.2版本
*模仿驱动:/linux/drivers/mtd/maps/edb7312.c
#include
#include
#include
#include
#include
#include
#include
#include
#define WINDOW_ADDR 0x00000000 /* NOR FLASH物理地址 */
#define WINDOW_SIZE 0x00200000 /* NOR FLASH大小 */
#define BUSWIDTH 2 /*估计是2Byte*/
/* 探测的接口类型,可以是'cfi_probe', 'jedec_probe', 'map_rom', NULL }; */
#define PROBETYPES { 'cfi_probe', NULL }
#define MSG_PREFIX 'MINI2440-NOR:' /*printk的前缀 */
#define MTDID 'mini2440-nor' /*MTD驱动*/
static struct mtd_info *mymtd;
/*定义一个map_info,代表一块norflash*/
struct map_info mini2440nor_map =
.name = 'NOR flash on MINI2440',
.size = WINDOW_SIZE,
.bankwidth = BUSWIDTH,
.phys = WINDOW_ADDR,
/* 默认分区信息*/
static struct mtd_partition static_partitions[3] =
.name = 'bootloader',
.size = 0x40000,//256K
.offset = 0
.name = 'Kernel',
.size = 0x100000,//1M
.offset = 0x40000
.name = 'RootFS',
.size = 0xC0000,//768K
.offset = 0x140000
static const char *probes[] = {NULL};
static int mtd_parts_nb = 0;
static struct mtd_partition *mtd_parts = 0;
/*Norflash模型初始化函数
*<1>物理地址映射为虚拟地址: mini2440nor_map.virt = ioremap(WINDOW_ADDR, WINDOW_SIZE);
*<2>探测norflash芯片,得到map_info:do_map_probe(); //应该是mtd_info,而不是map_info,转载者注释
*<3>探测分区信息,得到mtd_partition:parse_mtd_partitions();
*<4>利用map_info和mtd_partition注册设备:mtd_device_register();//应该是mtd_info,而不是map_info,转载者注释
int __init init_mini2440nor(void)
static const char *rom_probe_types[] = PROBETYPES;
const char **type;
const char *part_type = 0;
printk(KERN_NOTICE MSG_PREFIX '0x%08x at 0x%08xn', WINDOW_SIZE, WINDOW_ADDR);
/*物理地址映射为虚拟地址*/
if (!mini2440nor_map.virt)
printk(MSG_PREFIX 'failed to ioremapn');
return -EIO;
simple_map_init(&mini2440nor_map);
mymtd = 0;
type = rom_probe_types;
for (; !mymtd && *type; type++)
/*根据map_info探测norflash芯片,若成功则返回mtd_info*/
mymtd = do_map_probe(*type, &mini2440nor_map);
if (mymtd)
mymtd->owner = THIS_MODULE;
/*探测分区信息,若探测成功,则mtd_parts中保存了分区信息;若探测失败,使用数组定义的默认分区信息*/
mtd_parts_nb = parse_mtd_partitions(mymtd, probes, &mtd_parts, MTDID);
if (mtd_parts_nb > 0)
part_type = 'detected';
if (mtd_parts_nb == 0)
mtd_parts = static_partitions;
mtd_parts_nb = ARRAY_SIZE(static_partitions);
part_type = 'static';
printk(KERN_NOTICE MSG_PREFIX 'no partition info availablen');
else
printk(KERN_NOTICE MSG_PREFIX 'using %s partition definitionn',
part_type);
/*注册设备*/
mtd_device_register(mymtd, NULL, 0);
mtd_device_register(mymtd, mtd_parts, mtd_parts_nb);
return 0;
iounmap((void *)mini2440nor_map.virt);
return -ENXIO;
/*Norflash模块卸载函数
*<1>注销设备:mtd_device_unregister();
*<2>销毁map_info:map_destroy();
*<3>取消映射:iounmap();
static void __exit cleanup_mini2440nor(void)
if (mymtd)
/*注销设备*/
mtd_device_unregister(mymtd);
/*销毁map_info*/
map_destroy(mymtd);
if (mini2440nor_map.virt)
iounmap((void*)mini2440nor_map.virt);
mini2440nor_map.virt = 0;
module_init(init_mini2440nor);
module_exit(cleanup_mini2440nor);
MODULE_LICENSE('GPL');
MODULE_AUTHOR('WeiDong Wu <625769020@qq.com>');
MODULE_DESCRIPTION('Generic configurable MTD map driver');
关键字:mini2440  Norflash  驱动移植 引用地址:mini2440 Norflash驱动移植过程
上一篇:Mini2440开发板PWM驱动与测试程序简要分析
下一篇:mini2440 led驱动程序经典分析
推荐阅读最新更新时间:2026-03-19 13:32
【番外篇】mini2440裸机开发——程序下载SRAM,NorFlash方法
一、开发准备 开发板:mini2440, NorFlash:SST39VF1601 2MByte大小,CPU:S3C2440A 。 开发环境:MDK5.13 仿真器:Jlink v8 二、开发流程 先介绍讲程序下载到Nor Flash中的方法: 编写分散加载文件RuninFlash.sct ;************************************************************* ; *** Scatter-Loading Description File generated by uVision ; ***************************
[单片机]
【番外篇】<font color='red'>mini2440</font>裸机开发——程序下载SRAM,<font color='red'>NorFlash</font>方法
mini2440使用jlink烧写superboot到norflash
Jlink版本:J-flash ARM V4.12 J-Flash ARM的配置。 一般说来file-- open project里面会找到一些*.jflash的配置文件,加载他们就行了,但是没找到适合S3C2440的。所以自己建了一个mini2440.jflash,手动进行配置: j-link设置 1. 打开J-Flash ARM,并进入菜单:Options-- Project settings 2.主要设置CPU选项和Flash选项 CPU : Core -- ARM9, Little endian Use target RAM(faster)-- Addr:40000000 4KB(不选很慢
[单片机]
linux-2.6.32在mini2440开发板上移植-移植UDA1341 音频驱动
1 在初始化文件中加入UDA1341 设备结构 Linux-2.6.32.2 已经完美的支持UDA1341 音频芯片的驱动, 我们只要在arch/arm/mach-s3c2440/mach-mini2440.c 文件中注册UDA1341 平台设备的控制端口就可以了,打开mach-mini2440.c,添加如下内容: ;在文件首部添加头文件 #include sound/s3c24xx_uda134x.h ;在LCD 平台设备后面添加UDA1341 设备结构 static struct s3c24xx_uda134x_platform_data s3c24xx_uda134x_data = { .l3_clk =
[单片机]
linux-2.6.32在mini2440开发板上移植 添加触摸屏驱动程序
在内核中添加触摸屏驱动程序 编者:linux2.6.32并没有带S3C2440触摸屏驱动程序,需要自己实现。而在此的触摸屏驱动程序时作为一个输入设备来实现的。在linux中,对于输入设备而言,内核专为其设计了输入子系统,由核心层处理公共的工作。因为对于输入设备而言,只是中断、读键值/坐标值是与设备相关的,其余的如输入事件的缓冲区的管理以及字符设备驱动的file_operations接口则是输入设备通用的。所以在此是在输入子系统的框架下进行编写触摸屏驱动程序。对于这个驱动的移植以及讲解,参考了网上的一些文章,一部分摒弃了手册。 1 在内核中添加触摸屏驱动程序 Linux-2.6.32.2 内核也没有包含支持S3C2440 的触摸屏
[单片机]
linux2.6.32.2 mini2440平台移植-- ADC 驱动移植
1.2.1 关于 S3C2440 的 ADC 和触摸屏接口 Linux-2.6.32.2 内核并没有提供支持 S3C2440 的 ADC 驱动程序,因此我们自行设计了一个,这个驱动比较简单,属于字符设备,。在 S3C2440 芯片中,AD 输入和触摸屏接口使用共同的 A/D 转换器,见S3C2440芯片手册第 16 章节,如图。 1.2.2 在内核中添加 ADC 驱动 在 S3C2440 芯片中,AD 输入和触摸屏接口使用共同的 A/D 转换器,因此,ADC 驱动和触摸屏驱动若想共存,就必须解决共享 A/D 转换器 资源这个问 题,因此在 ADC 驱动程序中声明了一个全局的 ADC_LOCK 信号量。 (1)将
[单片机]
linux2.6.32.2 <font color='red'>mini2440</font>平台<font color='red'>移植</font>-- ADC <font color='red'>驱动</font><font color='red'>移植</font>
linux2.6.32.2 mini2440平台移植--LCD 背光驱动
1.3.1 LCD 背光控制原理 到目前为止,我们一直都在命令行下移植,查看结果,在 mini2440/micro2440 开发板中,LCD 背光是通过 CPU 的 LCD_PWR 引脚来控制的,从原理图中可以看出,它对应于 GPG4 。 当 LCD_PWR 输出为高电平 1 时,将打开背光;当输出为低电平 0 时,将关闭背光(注意:这里只是打开和关闭背光,而并没有背光亮度的调节作用)。 1.3.2 在内核中添加背光驱动程序 现在,我们需要增加一个简单的背光驱动,以便能够通过软件便可简单的控制背光的开关。我们要达到的目的是:在命令终端通过向背光设备发送偶数比如 0 便可关闭背光,发送奇数比如 1 便可打开背光,这样
[单片机]
Linux2.6.32移植MINI2440(4)移植+分析DM9000网卡驱动
开发环境: 主机:fedora 14 虚拟机:vmware workstation 10 交叉编译工具:arm-linux-gcc 4.3.2 开发板:mini2440(2m nor ,64m sdram,256m nand) 内核版本:linux2.6.32.2 上一篇帖子的uImage可以起yaffs2文件系统,但是起不了nfs,我的yaffs2使用nfs打包来的,换一个内核可以起,bootargs也没有问题,可能是这里网卡没有移植造成的,移植结束之后再看能不能起,因为nfs对后面做驱动开发优势比较大,方便调试看现象,不需要每次都烧写进去,所以还是需要能够起nfs的。DM9000内核
[单片机]
Linux2.6.32<font color='red'>移植</font>到<font color='red'>MINI2440</font>(4)<font color='red'>移植</font>+分析DM9000网卡<font color='red'>驱动</font>
linux-2.6.32在mini2440开发板上移植(17)之按键驱动程序移植
编者:按键驱动程序涉及到linux中断程序的编写。 1、按键原理图。 2、驱动程序的编写移植。 在/linux-2.6.32.2/drivers/char/目录下创建一个新的驱动程序文件mini2440_buttons.c,内容及详细注释如下: #include linux/module.h #include linux/kernel.h #include linux/fs.h #include linux/init.h #include linux/delay.h #include linux/poll.h #include linux/irq.h #include asm/irq.h #incl
[单片机]
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
