今天是:2025年10月13日(星期一)
正在发生
2022年10月13日 | mini2440 简单nandflash驱动代码记录(2.6.32.2内核)
发布者:ShiningSmile 来源: csdn关键字:mini2440  nandflash驱动  6  2内核 手机看文章 扫描二维码
随时随地手机看文章
#include <linux/module.h>
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
static struct nand_chip *mini2440_nand;
static struct mtd_info *mini2440_mtd_info;
static struct nand_regs_t{
unsigned long NFCONF;
unsigned long NFCONT;
unsigned long NFCMD;
unsigned long NFADDR;
unsigned long NFDATA;
unsigned long NFMECCD0;
unsigned long NFMECCD1;
unsigned long NFSECCD;
unsigned long NFSTAT;
unsigned long NFESTAT0;
unsigned long NFESTAT1;
unsigned long NFMECC0;
unsigned long NFMECC1;
unsigned long NFSECC;
unsigned long NFSBLK;
unsigned long NFEBLK;
static volatile struct nand_regs_t *nand_regs;
static void grh_select_chip(struct mtd_info *mtd, int chipnr){
if(-1 == chipnr){ //取消选中nfcont[1] = 1
nand_regs->NFCONT |= (1<<1);
else{ //选中芯片 nfcont[1] = 0
nand_regs->NFCONT &= ~(1<<1);
static void grh_cmd_ctrl(struct mtd_info *mtd, int dat, unsigned int ctrl){
if(ctrl & NAND_CLE){ //发送命令 nfcmmd = dat
nand_regs->NFCMD = dat;
else{ //发送地址 nfaddr = dat
nand_regs->NFADDR = dat;
static int grh_dev_ready(struct mtd_info *mdt){
//return nfstat[0]
return nand_regs->NFSTAT &(1<<0);
//falsh分区表
static struct mtd_partition grh_nand_parts[] = {
[0] = {
.name = "grh_supervivi",
.size = 0x00040000,
.offset = 0,
[1] = {
.name = "grh_param",
.offset = 0x00040000,
.size = 0x00020000,
[2] = {
.name = "grh_Kernel",
.offset = 0x00060000,
.size = 0x00500000,
[3] = {
.name = "grh_root",
.offset = 0x00560000,
.size = 1024 * 1024 * 1024, //
[4] = {
.name = "grh_nand",
.offset = 0x00000000,
static int nand_init(void){
struct clk *clk;
/*分配nand_chip结构体
  该结构体里面需要提供对nandflash的硬件操作(发命令,发数据,读数据,复位,选通等)的
  具体实现,mtd_info实现了怎么用命令来操作flash,而nand_chip就得在更低一层对命令进行实现
mini2440_nand = kzalloc(sizeof(struct nand_chip), GFP_KERNEL);
nand_regs = ioremap(0x4e000000, sizeof(struct nand_regs_t));
//设置参数
mini2440_nand->select_chip = grh_select_chip; //设置选中芯片的函数
mini2440_nand->cmd_ctrl = grh_cmd_ctrl; //设置发送命令和地址的函数
mini2440_nand->IO_ADDR_R = &(nand_regs->NFDATA); //nfdata虚拟地址
mini2440_nand->IO_ADDR_W = &(nand_regs->NFDATA); //nfdata虚拟地址
mini2440_nand->dev_ready = grh_dev_ready; //判断芯片是否就绪的函数
mini2440_nand->ecc.mode = NAND_ECC_SOFT; //软件生成ECC校验码,存入OOB区
//使能nandflash控制器时钟,才能操作相关的寄存器
clk = clk_get(NULL, "nand");
clk_enable(clk);
//设置硬件相关的时间参数
nand_regs->NFCONF = 0<<12; //TACLS=0
nand_regs->NFCONF |= (1<<8); //TWRPH0=1
nand_regs->NFCONF |= (0<<4); //TWRPH1=0
nand_regs->NFCONT |= (1<<1); //先不选中芯片
nand_regs->NFCONT |= (1<<0); //使能nandflash控制器
//使用nand_chip
mini2440_mtd_info = kzalloc(sizeof(struct mtd_info), GFP_KERNEL);
mini2440_mtd_info->owner = THIS_MODULE;
mini2440_mtd_info->priv = mini2440_nand;
//扫描识别芯片构造mtd_info结构体,mtd_info确定了对flash进行读写需要怎么发送命令
nand_scan(mini2440_mtd_info, 1);
//add_mtd_partition划分flash的分区
add_mtd_partitions(mini2440_mtd_info , grh_nand_parts , 5);
return 0;
static void nand_exit(void){
iounmap(nand_regs);
kfree(mini2440_nand);
kfree(mini2440_mtd_info);
return ;
module_init(nand_init);
module_exit(nand_exit);
MODULE_AUTHOR("GRH");
MODULE_VERSION("1.0");
MODULE_DESCRIPTION("NAND FLASH DRIVER");
MODULE_LICENSE("GPL");
版权声明:本文为CSDN博主「皓首不倦」的原创文章,遵循CC 4.0 BY-SA版权协议,转载请附上原文出处链接及本声明。
原文链接:https://blog.csdn.net/xiaohaowudi_grh/article/details/38810601
关键字:mini2440  nandflash驱动  6  2内核 引用地址:mini2440 简单nandflash驱动代码记录(2.6.32.2内核)
上一篇:mini2440 入门块设备驱动(用RAM缓存模拟磁盘)代码记录(内核用的是2.6.32.2)
下一篇:mini2440 make menuconfig 找不到Flash CFI支持的解决办法
都说现在企业融资难,事实上在某些行业,钱太多了也是“病”。2016年开始,工业机器人行业的资本热潮一直烧到现在,危机四伏。 “现在是最黑暗的时候。工业机器人行业本身很枯燥乏味,一直不受资本关注。直到2016年开始,行业集中涌入大量热钱。两年多时间过去了,现在越来越危险。”一位长期关注工业机器人领域的投资人告诉投资界。 在这个圈子里,很...
尽管从2018年开始到现在,SCARA市场增速有所下滑,但是,2014-2018年期间,应用在3C、新能源行业的SCARA工业机器人年均复合增长率41.66%,远超工业机器人整体销量28.81%的年均复合增速。 2019年,入局者的增多,新品的层出不穷以及应用场景的进一步开拓都预示着SCARA领域竞争更加激烈,甚至可以用“贴身肉搏”来形容,有业内人士提出,不用多久,最多1-...
1984年,Ross Freeman与同事共同创立了赛灵思公司,并推出了世界上第一颗真正意义上的FPGA芯片XC2064,一个全新的行业就此诞生。2020年,历经36年发展的赛灵思公司早已成为硅谷中的明星公司,FPGA行业也今非昔比。5G、AI为这个行业带来了难得的机会,广阔的发展空间就在眼前,但是领头者赛灵思公司却突然陷入了收购的传闻中。人们不禁会发问,独立的FPGA...
如果我们不仅能为全球最亟需的地方提供能源,而且是提供经济高效的能源,会怎么样?这是谈到发展中国家时经常会提出的问题,这些国家的电网往往处于初级发展阶段。由于无法储存能源,并在需求高峰时段调节能源的使用,所以不可避免地会出现停电、限电甚至导致能源短缺问题。目前面临的核心问题就是能源存储:市面上没有经济高效的电池可用来补充现有的电网...
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
