这里有个坑,我的路虎开发板原理图上是AT45DB161这样的芯片,实际上丝印却是SST25VF016B,这两个器件都是存储设备,但是它们不是pin对pin的,这里大家需要注意下!!!
/******************** (C) COPYRIGHT 2008 STMicroelectronics ********************
* File Name : spi_flash.h
* Author : MCD Application Team
* Version : V2.0.3
* Date : 09/22/2008
* Description : Header for spi_flash.c file.
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
* AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT,
* INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE
* CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING
* INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __SPI_FLASH_H__
#define __SPI_FLASH_H__
/* Includes ------------------------------------------------------------------*/
#include "lpc17xx.h"
#include "def.h"
typedef enum
Clear_4_K = 0,
Clear_32_K = 1,
Clear_64_K = 2,
Clear_ALL_FLASH = 3,
}Block_Cnt;
/* Exported macro ------------------------------------------------------------*/
/* Select SPI FLASH: Chip Select pin low P0.16 */
#define CS_LOW() LPC_GPIO0->FIOCLR = (1<<16) //GPIO_ResetBits(GPIO_CS, GPIO_Pin_CS)
/* Deselect SPI FLASH: Chip Select pin high */
#define CS_HIGH() LPC_GPIO0->FIOSET = (1<<16) //GPIO_SetBits(GPIO_CS, GPIO_Pin_CS)
void SPI_FLASH_Init(void);
void Read_ID(void);
void Read_Data(long add,u16 cnt,u8 *buff);
u8 Read_State_Register(void);
void Write_State_Register(u8 dat);
void Write_Mul_Byte(u32 add,u8 *buff,u32 cnt);
void Block_Clear(Block_Cnt flag,u32 add);
#endif /* __SPI_FLASH_H */
/******************* (C) COPYRIGHT 2008 STMicroelectronics *****END OF FILE****/
本文在STM32F103上实现SSH25的驱动,实现数据的写入和读取:
1:此驱动未加擦除时候是否擦除成功的判断,一般写入FLASH不成功的最大原因就是擦除不成功,
所以一般特选FLASH里面的一个地址存储一个特征字,比如0x12,当执行完操作擦除命令后,
去判断这个特征字是否被擦除为0xff,如果擦除成功,执行写指令,当然,也可以进行CRC校验,
判断写入和读取的是否一致;
2:FLASH的写入时,避免被中断打断;
作者:恰冯同学年少
来源:CSDN
原文:https://blog.csdn.net/golf_research/article/details/52133604
版权声明:本文为博主原创文章,转载请附上博文链接!
#include "sst25VF016b.h"
#include "lpc17xx_spi.h"
#include "lpc17xx_libcfg.h"
#include "lpc17xx_pinsel.h"
#include "lpc17xx_gpio.h"
#include "def.h"
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void delay_us(int a)
int i=a*25;
while(i--);
* Function Name : SPI_FLASH_Init
* Description : Initializes the peripherals used by the SPI FLASH driver.
* Input : None
* Output : None
* Return : None
* Initialize SPI pin connect
* P0.15 - SCK;
* P0.16 - SSEL - used as GPIO
* P0.17 - MISO
* P0.18 - MOSI
PINSEL_CFG_Type PinCfg;
SPI_CFG_Type SPI_ConfigStruct;
PinCfg.Funcnum = 3;
PinCfg.OpenDrain = 0;
PinCfg.Pinmode = 0;
PinCfg.Portnum = 0;
PinCfg.Pinnum = 15;
PINSEL_ConfigPin(&PinCfg);
PinCfg.Pinnum = 17;
PinCfg.Pinnum = 18;
// PinCfg.Pinnum = 16;
// PinCfg.Funcnum = 0;
// PINSEL_ConfigPin(&PinCfg);
LPC_GPIO0->FIODIR|=(1<<16); //CS引脚配置为输出(默认为输入)
/* Deselect the FLASH: Chip Select high */
CS_HIGH();
// initialize SPI configuration structure to default
SPI_ConfigStructInit(&SPI_ConfigStruct);
// Initialize SPI peripheral with parameter given in structure above
SPI_Init(LPC_SPI, &SPI_ConfigStruct);
/*SST25发送一个字节的数据*/
u8 SST25_Send_Byte(u8 dat)
LPC_SPI->SPDR = dat; //--- 向SPI写数据 ---
while(0 == (LPC_SPI->SPSR & (1<<7))); //--- 等待SPI发送完毕 ---
return(LPC_SPI->SPDR);
/*SST25读取一个字节的数据*/
u8 SST25_Receive_Byte(void)
return SST25_Send_Byte(0xff);
/*读状态寄存器*/
u8 flag = 0;
CS_LOW(); //使能片选信号
SST25_Send_Byte(0x05); //发送读状态寄存器操作码0x05*/
flag = SST25_Receive_Byte();
CS_HIGH(); //禁止片选信号
return flag;
/*等待内部擦除或者编程操作结束*/
void Wait_Busy_Clear(void)
while((Read_State_Register()&0x01) != 0x00);
/*写状态寄存器*/
CS_LOW(); //使能片选信号
SST25_Send_Byte(0x50); //发送写状态寄存器使能操作码0x50
CS_HIGH(); //禁止片选信号
CS_LOW(); //使能片选信号
SST25_Send_Byte(0x01); //发送写状态寄存器操作码0x01
SST25_Send_Byte(dat); //写状态寄存器为0x00
CS_HIGH(); //禁止片选信号
Wait_Busy_Clear();
/*写使能操作*/
void Write_Enable(void)
CS_LOW(); //使能片选信号
SST25_Send_Byte(0x06); //发送写使能操作码0x06
CS_HIGH(); //禁止片选信号
/*写禁止操作*/
void Write_Disable()
CS_LOW(); //使能片选信号
SST25_Send_Byte(0x04); //发送写使能操作码0x04
CS_HIGH(); //禁止片选信号
/* 读操作:0x03 */
CS_LOW(); //使能片选信号
SST25_Send_Byte(0x03); //发送写使能操作码0x03
SST25_Send_Byte(add>>16);//发送存储地址,24位
SST25_Send_Byte(add>>8); //发送存储地址,24位
SST25_Send_Byte(add); //发送存储地址,24位
for(;cnt>0;cnt--)
*(buff++) = SST25_Receive_Byte();
CS_HIGH(); //禁止片选信号
/* 高速读:0x0B */
void Read_High_Speed_Data(u32 add,u16 cnt,u8 *buff)
CS_LOW(); //使能片选信号
SST25_Send_Byte(0x0b); //发送写使能操作码0x0b
SST25_Send_Byte(0x00); //发送一个空周期
for(;cnt>0;cnt--)
CS_HIGH(); //禁止片选信号
/* 写单个字节操作,字节编程:0x02 */
void Write_Byte(u32 add,u8 dat)
Write_Enable(); //写使能
CS_LOW(); //使能片选信号
SST25_Send_Byte(0x02); //发送字节编程操作码0x02*/
SST25_Send_Byte(dat); //发送写入的数据
CS_HIGH(); //禁止片选信号
Wait_Busy_Clear();
/* 写多个字节操作,AAI编程:0xAD */
u32 i = 0;
CS_LOW(); //使能片选信号
SST25_Send_Byte(0xad); //发送AAI编程操作码0xad*/
SST25_Send_Byte(buff[0]);//发送写入的数据
SST25_Send_Byte(buff[1]);//发送写入的数据
CS_HIGH(); //禁止片选信号
i = 2;
while(i delay_us(10); CS_LOW(); //使能片选信号 SST25_Send_Byte(0xad); //发送AAI编程操作码0xad*/ SST25_Send_Byte(buff[i++]);//发送写入的数据 SST25_Send_Byte(buff[i++]);//发送写入的数据 CS_HIGH(); //禁止片选信号 } delay_us(10); Write_Disable(); //退出AAI模式 delay_us(10); Wait_Busy_Clear(); //等待写结束 } /*4k扇区擦除或者32k块擦除或者64k块擦除*/ const u8 bclr_cmd[]={0x20,0x52,0xd8,0x60}; void Block_Clear(Block_Cnt flag,u32 add) { if(flag<4) { Write_Enable(); //写使能 CS_LOW(); //使能片选信号 SST25_Send_Byte(bclr_cmd[flag]); //发送扇区擦除操作码0x20 SST25_Send_Byte(add>>16);//发送存储地址,24位 SST25_Send_Byte(add>>8); //发送存储地址,24位 SST25_Send_Byte(add); //发送存储地址,24位 CS_HIGH(); //禁止片选信号 Wait_Busy_Clear(); //等待写结束 } } u8 ID[3];//0xBF2541 /* 读设备ID:0x9F */ void Read_ID(void) { CS_LOW(); //使能片选信号
上一篇:ARM体系结构之点亮LED灯
下一篇:LPC1788的spi使用
XC6406PP60DL
京公网安备 11010802033920号
