单片机源程序如下:
//数码管位 高位-----低位
//四个按键控制步进电机:正转,反转,加1,减1
//上电时电机启动,数码管上显示速度最小档1,加减档位均能通过数码管显示出来,电机采用单双八拍方式
//电机转速一共10档,通过按键调节转速
//电机正转时最高位数码管显示0,反转时显示1
#include #define uchar unsigned char #define uint unsigned int #define led P0//数码管段选 #define haha P2 sbit s1 = P1^0; sbit s2 = P1^1; sbit s3 = P3^0; sbit s4 = P3^1; sbit s5 = P3^2;//按键定义,s1正转,s2反转,s3加1,s4减1 sbit wei3 = P2^3;sbit wei2 = P2^2;sbit wei1 = P2^1;sbit wei0 = P2^0;//数码管位选定义 sbit a = P2^7;sbit b = P2^6;sbit c = P2^5;sbit d = P2^4;//脉冲信号输入端定义 uchar code tab[11]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};//共阳数码管驱动信号0---9,不显示 uchar code time_counter[10][2]={{0xda,0x1c},{0xde,0xe4},{0xe1,0xec},{0xe5,0xd4},{0xe9,0xbc}, //9.7 ----1ms {0xed,0xa4},{0xf1,0x8c},{0xf5,0x74},{0xf9,0x5c},{0xfc,0x18}}; uchar code qudong[8]={0x80,0xc0,0x40,0x60,0x20,0x30,0x10,0x90}; uchar num1 = 0;//控制取励磁信号变量 uchar num2 = 8; char k=0;//加减档位控制,1为最小档 char pause=1;//暂停时保存之前的转速,开机默认1 bit flag1 = 0;//初始正转,正反转标志 uchar buf[4]={0,10,0,0};//数码管显示缓存,正转,不显示,不显示,显示1档位,高----低 //================================定时器0/1初始化函数================================ void T0_T1_init() { TMOD = 0x11;//定时器0/1均工作于方式1,16位计时方式 TH1 = time_counter[k-1][0]; TL1 = time_counter[k-1][1];//定时器1,定时10ms用于步进电机转速控制 TR1 = 0; ET1= 1;//开定时器中断 EA = 1;//开总中断 } //================================ms级延时函数======================================= void delay1m(uint x) { uint i,j; for(i=0;i } void display() { wei3=1;wei2=1;wei1=1;wei0=0;led = tab[buf[3]];delay1m(1);led=0xff; wei3=1;wei2=1;wei1=0;wei0=1;led = tab[buf[2]];delay1m(1);led=0xff; wei3=1;wei2=0;wei1=1;wei0=1;led = tab[buf[1]];delay1m(1);led=0xff; wei3=0;wei2=1;wei1=1;wei0=1;led = tab[buf[0]];delay1m(1);led=0xff; } //================================主函数============================================= void main() { T0_T1_init(); buf[1] = 10;//不显示 while(1) { display(); if(s1 == 0) { delay1m(3); if(s1 == 0) { flag1 = 0;//正转 buf[0] = 0;//最高位显示0 // haha = 0x00;//停止 } while(!s1) display(); } if(s2 == 0 ) { delay1m(3); if(s2 == 0) { flag1 = 1;//反转 buf[0] = 1;//最高位显示1 // haha = 0x00;//停止 } while(!s2) display(); } if(s3 == 0) //速度加1档 { delay1m(3); if(s3 == 0) { k++; TR1=1; if(k > 10 ) { k = 1; } buf[2]= k/10; buf[3]= k%10; } while(!s3) display(); } if(s4 == 0) //速度减1档 { delay1m(3); if(s4 == 0) { k--; TR1=1; if(k <= 0) { k = 10; } buf[2]= k/10; buf[3]= k%10; } while(!s4) display(); } if(s5==0) { delay1m(3); if(s5==0) { if(TR1==1) { pause=k; k=0; TR1=0; a=b=c=d=0; } else if(TR1==0)
上一篇:STC单片机+DM134实现LED多段控制
下一篇:基于52单片机控制编码器显示程序
- 尼得科与 Technohorizon 株式会社合作开发用于背钻检测的自动 X 射线检测设备
- 2026 IPC电子装联大师赛圆满落幕,获奖名单揭晓
- 中国芯片研发重要成果!中科院发布香山、如意系统
- 2026年,AI将给设计工程软件带来哪些变革?
- 赋能AI,智造未来:爱发科电子半导体技术研讨会暨SEMICON China 2026出展圆满举行
- 三星展示超高容量密集封装技术:单颗芯片做到4TB!
- 谷歌新内存技术“炸”了存储芯片市场 闪迪跌超11%
- 新品!从MINI到工业板:米尔T153开发板工业场景全覆盖
- 具身智能领域首个行业标准发布,6 月 1 日起正式实施
- 格罗方德起诉 Tower,指控后者侵犯专利
SN74HCT574DBR
京公网安备 11010802033920号
