在代码中有
// VIDTCON0
#define VBPDE(n) (((n-1)&0xff)<<24)
#define VBPD(n) (((n-1)&0xff)<<16)
#define VFPD(n) (((n-1)&0xff)<<8)
#define VSPW(n) (((n-1)&0xff)<<0)
// VIDTCON1
#define VFPDE(n) (((n-1)&0xff)<<24)
#define HBPD(n) (((n-1)&0xff)<<16)
#define HFPD(n) (((n-1)&0xff)<<8)
#define HSPW(n) (((n-1)&0xff)<<0)
// VIDTCON2
#define LINEVAL(n) (((n-1)&0x7ff)<<11)
#define HOZVAL(n) (((n-1)&0x7ff)<<0)
#ifdef CONFIG_FB_S3C_LTE480WV
.width = 480,
.height = 272,
.bpp = 16,
.freq = 60,
.timing = {
.h_fp = 2, //HFPD_Value = 2
.h_bp = 2, //HBPD_Value = 2
.h_sw = 41,//HSPW_Value = 41;
.v_fp = 2, //VFPD_Value = 2
.v_fpe = 1,
.v_bp = 2, //VBPD_Value = 2
.v_bpe = 1,
.v_sw = 10,
.polarity = {
.rise_vclk = 0,
.inv_hsync = 1,
.inv_vsync = 1,
.inv_vden = 0,
#endif
里面的
v_fpe和h_bpe 是啥玩意呢?
在代码中有
int s3cfb_set_timing(struct s3cfb_global *ctrl)
struct s3cfb_lcd_timing *time;
u32 cfg;
time = &ctrl->lcd->timing;
cfg = 0;
cfg |= S3C_VIDTCON0_VBPDE(time->v_bpe - 1);
cfg |= S3C_VIDTCON0_VBPD(time->v_bp - 1);
cfg |= S3C_VIDTCON0_VFPD(time->v_fp - 1);
cfg |= S3C_VIDTCON0_VSPW(time->v_sw - 1);
writel(cfg, ctrl->regs + S3C_VIDTCON0);
cfg = 0;
cfg |= S3C_VIDTCON1_VFPDE(time->v_fpe - 1);
cfg |= S3C_VIDTCON1_HBPD(time->h_bp - 1);
cfg |= S3C_VIDTCON1_HFPD(time->h_fp - 1);
cfg |= S3C_VIDTCON1_HSPW(time->h_sw - 1);
writel(cfg, ctrl->regs + S3C_VIDTCON1);
return 0;
在手册有如下说明:
VBPDE [31:24] Vertical back porch specifies the number of inactive lines at the
start of a frame after vertical synchronization period. (Only for even
field of YVU interface)
VFPDE [31:24] Vertical front porch specifies the number of inactive lines at the end
of a frame before vertical synchronization period. (Only for the even
field of YVU interface).
Only for the even field of YVU interface 这个是啥意思?我在wince的VGA 1440*900 1280*720 1280*1024 当中根本没有设置这个
v_fpe和h_bpe,也就是默认就是0.在android下就有这玩意。
上一篇:S5PV210 串口实验(中断方式)
下一篇:9.S5PV210的时钟系统
推荐阅读最新更新时间:2026-03-19 11:05
- 基于 Blackfin 数字信号处理器 (DSP) 的 ADZS-BF518F-EZLITE、ADSP-BF518F EZ-Kit Lite 评估系统
- 使用 ON Semiconductor 的 CAT3200Z 的参考设计
- LTC2162 演示板,16 位 65Msps ADC,LVDS 输出,5-140MHz
- 使用 Analog Devices 的 LTC3526BEDC-2 的参考设计
- LT3091HT7 在极低输出电压下低压降操作的典型应用
- 蓝牙协议分析工具nRF52840 MDK USB Dongle
- NCV2902DR2G 维恩桥振荡器运算放大器的典型应用
- LTC4100EGN 演示板,智能电池充电器 DCIN = 15V-20V / 3.5V
- TC78H620FNG 双桥直流有刷电机驱动器评估板
- 带有 DRP w/Try.SRC 和 Type-C 插座的 PTN5110 USB PD 的典型应用
S5PV210_iROM_ApplicationNote_Preliminary_20091126
非常经典的关于LLC的杨波博士论文
1CIS223-04TG3M
京公网安备 11010802033920号
