// serial number search direction write bit
OWWriteBit(search_direction);
// increment the byte counter id_bit_number
// and shift the mask rom_byte_mask
id_bit_number++;
rom_byte_mask <<= 1;
// if the mask is 0 then go to new SerialNum byte rom_byte_number and reset mask
if (rom_byte_mask == 0)
docrc8(ROM_NO[rom_byte_number]); // accumulate the CRC
rom_byte_number++;
rom_byte_mask = 1;
while(rom_byte_number < 8); // loop until through all ROM bytes 0-7
// if the search was successful then
if (!((id_bit_number < 65) || (crc8 != 0)))
// search successful so set LastDiscrepancy,LastDeviceFlag,search_result
LastDiscrepancy = last_zero;
// check for last device
if (LastDiscrepancy == 0)
LastDeviceFlag = TRUE;
search_result = TRUE;
// if no device found then reset counters so next 'search' will be like a first
if (!search_result || !ROM_NO[0])
LastDiscrepancy = 0;
LastDeviceFlag = FALSE;
LastFamilyDiscrepancy = 0;
search_result = FALSE;
return search_result;
// Verify the device with the ROM number in ROM_NO buffer is present.
// Return TRUE : device verified present
// FALSE : device not present
int OWVerify()
unsigned char rom_backup[8];
int i,rslt,ld_backup,ldf_backup,lfd_backup;
// keep a backup copy of the current state
for (i = 0; i < 8; i++)
rom_backup[i] = ROM_NO[i];
ld_backup = LastDiscrepancy;
ldf_backup = LastDeviceFlag;
lfd_backup = LastFamilyDiscrepancy;
// set search to find the same device
LastDiscrepancy = 64;
if (OWSearch())
// check if same device found
rslt = TRUE;
if (rom_backup[i] != ROM_NO[i])
rslt = FALSE;
break;
else
rslt = FALSE;
// restore the search state
ROM_NO[i] = rom_backup[i];
LastDiscrepancy = ld_backup;
LastDeviceFlag = ldf_backup;
LastFamilyDiscrepancy = lfd_backup;
// return the result of the verify
return rslt;
// Setup the search to find the device type 'family_code' on the next call
// to OWNext() if it is present.
void OWTargetSetup(unsigned char family_code)
int i;
// set the search state to find SearchFamily type devices
ROM_NO[0] = family_code;
for (i = 1; i < 8; i++)
ROM_NO[i] = 0;
// Setup the search to skip the current device type on the next call
// to OWNext().
void OWFamilySkipSetup()
// set the Last discrepancy to last family discrepancy
LastDiscrepancy = LastFamilyDiscrepancy;
// check for end of list
// 1-Wire Functions to be implemented for a particular platform
// Reset the 1-Wire bus and return the presence of any device
// Return TRUE : device present
// FALSE : no device present
int OWReset()
u8 temp = 0;
DQ(1);
DQ(0);
DqDelay(784); //784
DQ(1);
DqDelay(110); //110
temp = READ_DQ;
DqDelay(675); //675
return !temp;
// Send 8 bits of data to the 1-Wire bus
void OWWriteByte(unsigned char dat)
u8 i = 0;
for ( i = 0 ; i < 8 ; i++ )
DQ(0);
DqDelay(1);
if ( dat & 0x01 )
DQ(1);
else
DQ(0);
dat = dat >> 1;
DqDelay(100);
DQ(1);
DqDelay(1);
// Send 1 bit of data to teh 1-Wire bus
void OWWriteBit(unsigned char bit_value)
DQ(0);
DqDelay(1);
if ( bit_value & 0x01 )
DQ(1);
else
DQ(0);
DqDelay(100);
DQ(1);
DqDelay(1);
// Read 1 bit of data from the 1-Wire bus
// Return 1 : bit read is 1
// 0 : bit read is 0
unsigned char OWReadBit()
u8 dat = 0;
DQ(0);
DqDelay(1);
DQ(1);
DqDelay(2);
if ( READ_DQ )
dat = 1;
DqDelay(100);
return dat;
// TEST BUILD
static unsigned char dscrc_table[] = {
0, 94,188,226, 97, 63,221,131,194,156,126, 32,163,253, 31, 65,
157,195, 33,127,252,162, 64, 30, 95, 1,227,189, 62, 96,130,220,
35,125,159,193, 66, 28,254,160,225,191, 93, 3,128,222, 60, 98,
190,224, 2, 92,223,129, 99, 61,124, 34,192,158, 29, 67,161,255,
70, 24,250,164, 39,121,155,197,132,218, 56,102,229,187, 89, 7,
219,133,103, 57,186,228, 6, 88, 25, 71,165,251,120, 38,196,154,
101, 59,217,135, 4, 90,184,230,167,249, 27, 69,198,152,122, 36,
248,166, 68, 26,153,199, 37,123, 58,100,134,216, 91, 5,231,185,
140,210, 48,110,237,179, 81, 15, 78, 16,242,172, 47,113,147,205,
17, 79,173,243,112, 46,204,146,211,141,111, 49,178,236, 14, 80,
175,241, 19, 77,206,144,114, 44,109, 51,209,143, 12, 82,176,238,
50,108,142,208, 83, 13,239,177,240,174, 76, 18,145,207, 45,115,
202,148,118, 40,171,245, 23, 73, 8, 86,180,234,105, 55,213,139,
87, 9,235,181, 54,104,138,212,149,203, 41,119,244,170, 72, 22,
233,183, 85, 11,136,214, 52,106, 43,117,151,201, 74, 20,246,168,
116, 42,200,150, 21, 75,169,247,182,232, 10, 84,215,137,107, 53};
上一篇:STM32中断使用笔记
下一篇:STM32中ucos的编写程序
推荐阅读最新更新时间:2026-02-17 20:02
- CMC1003-2M-55-8,EP4CE55 模块,允许在紧凑型模块中实现通用逻辑功能,Altera Nios II 处理器操作
- OM13054: LPC-Link2
- 使用 LTC1863CGN 12 位、8 通道、200Ksps ADC 实现差分输入的典型应用电路
- 具有 PowerPath 的 LTC4162EUFD-FFS 1 节 USB 电力传输充电器的典型应用
- Over-the-Top 电流检测应用电路
- 使用 Silicon Labs 的 C8051F018 的参考设计
- LT3750 电路将 400F 电容器充电至 300V
- LTC3624IDD-5 5V 输出电压、2A 同步降压型稳压器的典型应用,具有 2.25MHz
- 使用 Microchip Technology 的 TC2574 的参考设计
- NBC12430EVB/D、NBC12430 PLL 合成时钟发生器评估板
stm32驱动屏IC rm68042
STM32 PMSM FOC 简介
基于STM32G031的测试测量训练平台完成虚拟仪器实现
非常经典的关于LLC的杨波博士论文
7662CPA
京公网安备 11010802033920号
