STM32 通用底层函数集锦, 自用
发布者:知识智慧最新更新时间:2024-10-21 来源: cnblogs关键字:STM32 手机看文章 扫描二维码
随时随地手机看文章
#include 'xustm32.h'
#include 'xucommon.h'
//#define COM_DEBUG
#include 'xudebug.h'
//-------------------- STM32通用函数集锦 ---------------------------------------------------
#if 0
HardFault_Handler
                PROC
; EXPORT HardFault_Handler [WEAK]
; B .
                IMPORT hard_fault_handler_c
                TST LR, #4
                ITE EQ
                MRSEQ R0, MSP
                MRSNE R0, PSP
                B hard_fault_handler_c
                ENDP
#endif
// hard fault handler in C, with stack frame location as input parameter
void hard_fault_handler_c(unsigned long * hardfault_args)
  unsigned long stacked_r0, stacked_r1, stacked_r2, stacked_r3, stacked_r12, stacked_lr, stacked_pc, stacked_psr;
  stacked_r0 = ((unsigned long) hardfault_args[0]);
  stacked_r1 = ((unsigned long) hardfault_args[1]);
  stacked_r2 = ((unsigned long) hardfault_args[2]);
  stacked_r3 = ((unsigned long) hardfault_args[3]);
  stacked_r12 = ((unsigned long) hardfault_args[4]);
  stacked_lr = ((unsigned long) hardfault_args[5]);
  stacked_pc = ((unsigned long) hardfault_args[6]);
  stacked_psr = ((unsigned long) hardfault_args[7]);
  UARTprintf ('[Hard fault handler]????n');
  UARTprintf ('R0 = %x, R1 = %x, R2 = %x, R3 = %x, R12 = %xn', stacked_r0, stacked_r1, stacked_r2, stacked_r3);
  UARTprintf ('R12 = %x, LR = %x, PC = %x, PSR = %xn', stacked_r12, stacked_lr, stacked_pc, stacked_psr);
  UARTprintf ('BFAR = %xn', (*((volatile unsigned long *)(0xE000ED38))));
  UARTprintf ('CFSR = %xn', (*((volatile unsigned long *)(0xE000ED28))));
  UARTprintf ('HFSR = %xn', (*((volatile unsigned long *)(0xE000ED2C))));
  UARTprintf ('DFSR = %xn', (*((volatile unsigned long *)(0xE000ED30))));
  UARTprintf ('AFSR = %xn', (*((volatile unsigned long *)(0xE000ED3C))));
#if 0
    Debug ('Now Task : %snr',OSTCBPrioTbl[OSTCBCur->OSTCBPrio]->OSTCBTaskName);
    OS_TaskStkCheck(TRUE);
    OS_DebugHeap();
    Q_ErrorStopScreen('HardFaultException');
#endif
  while(1) { }
void GetSerialNO(void)
    u32 Dev_Serial0, Dev_Serial1, Dev_Serial2;
    Dev_Serial0 = HWREG(0x1FFFF7E8);
  Dev_Serial1 = HWREG(0x1FFFF7EC);
  Dev_Serial2 = *(vu32*)(0x1FFFF7F0);
  DEBUG_PRINT('SerialNO = %08X %08X %08Xn', Dev_Serial0, Dev_Serial1, Dev_Serial2);
  //SerialNO = 066C0036 33315330 43184129
//本函数名不可改, uCOS中应用到
u32 GetClocksFreq(void)
    RCC_ClocksTypeDef rcc_clocks;
  RCC_GetClocksFreq(&rcc_clocks);    //获取系统频率
  return(rcc_clocks.HCLK_Frequency);
//--- 独立看门狗
void IWDG_Init(unsigned char ucSecond)
    IWDG->KR = 0X5555;                //使能对IWDG->PR和IWDG->RLR的写
  IWDG->PR = IWDG_Prescaler_64; //设置分频系数
  IWDG->RLR = 625*ucSecond;         //从加载寄存器 IWDG->RLR
    IWDG->KR = 0XAAAA;                //reload
  IWDG->KR = 0XCCCC;                //使能看门狗
//THUMB指令不支持汇编内联, 采用如下方法实现执行汇编指令WFI
__asm void WFI_SET(void)
    WFI;
//进入待机模式
void SystemStandby(void)
    SCB->SCR      |= 1<<2;        //使能SLEEPDEEP位 (SYS->CTRL)
  RCC->APB1ENR |= 1<<28;     //使能电源时钟
    RCC->APB1ENR |= 1<<27;     //使能备份时钟
    PWR->CSR      |= 1<<8; //设置WKUP用于唤醒
    PWR->CR      |= 1<<2; //清除Wake-up 标志
    PWR->CR      |= 1<<1; //PDDS置位
    WFI_SET();                     //执行WFI指令
//--------------------- UART Begin -----------------------------------------------------
extern COM_TypeDef g_DebugComNo;
#define EVAL_COM1 USART1
#define EVAL_COM1_GPIO GPIOA
#define EVAL_COM1_CLK RCC_APB2Periph_USART1
#define EVAL_COM1_GPIO_CLK RCC_APB2Periph_GPIOA
#define EVAL_COM1_RxPin GPIO_Pin_10
#define EVAL_COM1_TxPin GPIO_Pin_9
#define EVAL_COM2 USART2
#define EVAL_COM2_GPIO GPIOA
#define EVAL_COM2_CLK RCC_APB1Periph_USART2
#define EVAL_COM2_GPIO_CLK RCC_APB2Periph_GPIOA
#define EVAL_COM2_RxPin GPIO_Pin_3
#define EVAL_COM2_TxPin GPIO_Pin_2
#define COMn 2
USART_TypeDef* COM_USART[COMn] = {EVAL_COM1, EVAL_COM2};
GPIO_TypeDef* COM_PORT[COMn] = {EVAL_COM1_GPIO, EVAL_COM2_GPIO};
const uint32_t COM_USART_CLK[COMn] = {EVAL_COM1_CLK, EVAL_COM2_CLK};
const uint32_t COM_POR_CLK[COMn] = {EVAL_COM1_GPIO_CLK, EVAL_COM2_GPIO_CLK};
const uint16_t COM_TX_PIN[COMn] = {EVAL_COM1_TxPin, EVAL_COM2_TxPin};
const uint16_t COM_RX_PIN[COMn] = {EVAL_COM1_RxPin, EVAL_COM2_RxPin};
/*typedef enum {
    GPIO_Mode_AIN = 0x0,         //模拟输入
    GPIO_Mode_IN_FLOATING = 0x04,     //浮空输入模式, 默认
    GPIO_Mode_IPD = 0x28,     //上拉/下拉输入模式
    GPIO_Mode_IPU = 0x48,             //保留
    GPIO_Mode_Out_OD = 0x14,         //通用开漏输出
    GPIO_Mode_Out_PP = 0x10,         //通用推挽输出,     无输出.
    GPIO_Mode_AF_OD = 0x1C,                 //复用(开漏)输出
    GPIO_Mode_AF_PP = 0x18                 //复用(推挽)输出. 乱码
} GPIOMode_TypeDef; */
void USART_Set(COM_TypeDef COM, uint32 BaudRate)
    USART_InitTypeDef USART_InitStructure;
    GPIO_InitTypeDef GPIO_InitStructure;
    USART_InitStructure.USART_BaudRate = BaudRate;
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits = USART_StopBits_1;
    USART_InitStructure.USART_Parity = USART_Parity_No;
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
    /* Enable GPIO clock */
    RCC_APB2PeriphClockCmd(COM_POR_CLK[COM] | RCC_APB2Periph_AFIO, ENABLE);    //使能串口所有GPIO模块时钟,并使能AFIO模块时钟
    /* Enable UART clock */
    if (COM == COM1) {
        RCC_APB2PeriphClockCmd(COM_USART_CLK[COM], ENABLE);     //使能串口模块时钟
    else {
        RCC_APB1PeriphClockCmd(COM_USART_CLK[COM], ENABLE);        //使能串口模块时钟
    /* Configure USART Tx as alternate function push-pull */
    GPIO_InitStructure.GPIO_Pin = COM_TX_PIN[COM];        //设置TX引脚
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //复用推挽输出
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(COM_PORT[COM], &GPIO_InitStructure);
    /* Configure USART Rx as input floating */
    GPIO_InitStructure.GPIO_Pin = COM_RX_PIN[COM];            //设置RX引脚
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;    //浮空输入
    /* USART configuration */
    USART_Init(COM_USART[COM], &USART_InitStructure);        //初始化USART
    /* Enable USART Receive and Transmit interrupts */
    USART_ITConfig(COM_USART[COM], USART_IT_RXNE, ENABLE);
    //USART_ITConfig(COM_USART[COM], USART_IT_TXE, ENABLE);
    /* Enable USART */
    USART_Cmd(COM_USART[COM], ENABLE);        //使能串口模块
    //USART_DMACmd(COM, USART_DMAReq_Rx, ENABLE); //使能UART DAM传输
void UARTSendChar(COM_TypeDef COM, uint8_t ch)
    /* Loop until the end of transmission */
    //USART_SendData(COM_USART[COM], ch);
    while (USART_GetFlagStatus(COM_USART[COM], USART_FLAG_TC) == RESET);
void UARTOut(COM_TypeDef COM, uint8_t *Data, uint16_t Len)
    uint16_t i;
    for(i=0; i        UARTSendChar(COM, Data[i]);
//--- used by UARTprintf
void UARTwrite(const char *pucBuffer, unsigned long ulCount)
    // Loop while there are more characters to send, Write the next character to the UART.
    while(ulCount--) {
        if(*pucBuffer == 'n') {
            UARTSendChar(g_DebugComNo, 'r');
        UARTSendChar(g_DebugComNo, *pucBuffer++);
#if 0
#define UARTSOF '$'
#define UARTEOF 0x0d
unsigned char RxBuffer1[100];
unsigned short RxCounter1;
void USART1_IRQHandler(void)
  unsigned char ucTmp;
#ifdef RTX_KERNEL
  void *msg;
#endif
#ifdef UCOS_KERNEL
    INPUT_EVENT IE;
    OS_IntEnter();
#endif
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
    /* Read one byte from the receive data register */
    ucTmp = USART_ReceiveData(USART1);
    if (ucTmp == UARTSOF) {
        RxCounter1 = 1;
        RxBuffer1[0] = ucTmp;
    else if(ucTmp == UARTEOF) {
      /* Disable the USART1 Receive interrupt */
      //USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
      RxBuffer1[RxCounter1] = '';        //结束符.
#ifdef RTX_KERNEL
        msg = malloc(RxCounter1);
[1] [2]
关键字:STM32 引用地址:STM32 通用底层函数集锦, 自用
上一篇:STM32的三种延时方法的代码实现_纯软件延时, 系统定时器延时, 定时器延时
下一篇:UCGUI在STM32平台移植经验(无操作系统)
推荐阅读最新更新时间:2026-03-24 00:20
STM32 通用底层函数集锦, 自用
#include xustm32.h #include xucommon.h //#define COM_DEBUG #include xudebug.h //-------------------- STM32通用函数集锦 --------------------------------------------------- #if 0 HardFault_Handler PROC ; EXPORT HardFault_Handler ; B . IMPORT hard_fault_handler_c TST LR, #4 ITE EQ
[单片机]
基于机智云与STM32的智能拐杖安全监测系统在养老物联网中的应用
随着老龄化加剧与科技进步,“ + 养老” 成为智慧养老核心方向,老年人出行安全与健康监测需求日益迫切。针对传统拐杖智能化不足、功能单一的痛点,本文提出一种融合多与物联网平台的智能拐杖系统,以 为核心主控,集成 GPS、姿态检测、超声波等传感模块,搭配 本地显示与机智云 App,实现定位、防摔、报警及云端监测一体化功能,为老年人安全出行与家庭照护提供技术支撑。 01系统总体设计 拐杖系统主要能实现GPS定位、防摔倒、障碍物检测、液晶显示、短信报警、语音提示、联网App等功能。系统总体设计结构如图1所示。 图1智能拐杖系统总体设计结构 02硬件设计 智能拐杖系统通过STM32主控芯片来传输和处理各传感设
[单片机]
基于机智云与<font color='red'>STM32</font>的智能拐杖安全监测系统在养老物联网中的应用
让人神往的STM32经验大抵如此
单片机用处这么广,尤其是STM32生态这么火!如何快速上手学习呢? 你要考虑的是,要用STM32实现什么? 为什么使用STM32而不是用8051?是因为51的频率太低,无法满足计算需求?是51的管脚太少,无法满足众多外设的IO?是51的功耗太大,电池挺不住?是51的内存太小而你要存储的东西太多?还是51的功能太弱,而你要使用SPI、I2C、ADC、DMA? 当你需要使用STM32某些功能,而51实现不了的时候,那STM32自然不需要学习,你会直接去寻找STM32某方面的使用方法。比如要用spi协议的网卡、要使用串口通信、要使用rtos等等。 寄存器vs库函数 我的观点是:当你debug的时候寄存器很重要,当你需要理解芯片工作
[单片机]
使用Rust开发STM32嵌入式程序入门教程
Why? Rust作为一门新兴语言,其安全、可靠、运行效率高等特点让它成为一门非常适合嵌入式开发的语言。本文主要介绍如何搭建Rust嵌入式开发环境,然后使用stm32h7开发板点个灯。 在嵌入式开发领域,C语言的地位是无法被撼动的(至少在2023年是这样)。用Rust开发嵌入式目前就两个目的: 玩 战未来 :) 适用对象 如果你没有接触过嵌入式编程,或者完全不懂gcc系列的开源工具链,或者完全没有接触过Rust,那么建议先了解一下相关的背景知识。 OK,Let's GO! 搭建Rust开发环境 安装Rust 首先第一步是安装Rust的开发环境。Rust开发环境的安装非常简单,参考https://ru
[单片机]
使用micropython开发STM32
一、前言 MicroPython(官网:https://micropython.org),是Python3编程语言的一个完整软件实现,用C语言编写,被优化于运行在微控制器之上。MicroPython是运行在微控制器硬件之上的完全的Python编译器和运行时系统。提供给用户一个交互式提示符(REPL)来立即执行所支持的命令。除了包括选定的核心Python库,MicroPython还包括了给予编程者访问低层硬件的模块。(摘抄自weact微行工作室)。 用我的理解简单来说,就是使用C语言往单片机里写了一个Python的解释器,再将MicroPython程序脚本保存到单片机(或外部存储器)内,然后由内部的解释器运行脚本代码。优点就是接
[单片机]
基于stm32标准库独立按键的多按键状态机的实现
写在前面 一般引用都写在最后,但是这篇博文(https://www.cnblogs.com/ZzJan/p/11334869.html)对我这个状态机的影响很大,我这里有许多借鉴他的思维。所以写在前面,以表敬意 简单按键检测 一开始学习单片机的时候我接触到按键的时候就知道按键有抖动,记得当初按键消抖分为硬件和软件,硬件上常用于复位按键如下图 硬件消抖 软件上来说,最经典的消抖 if(KEY1 == 0) { delay_ms(20); // 延时消抖 if(KEY1 == 0) { while(KEY1 == 0);//堵塞,等待松开 // 按键按下处理代码 } }
[单片机]
基于<font color='red'>stm32</font>标准库独立按键的多按键状态机的实现
STM32单片机学习】第11章 基础重点—SysTick定时器
本章实验的目的让读者熟悉STM32F103的SysTick定时器,SysTick定时器和NVIC一样,都属于Cortex-M3的内核外设资源。SysTick定时器比较简单,借此机会感受HAL库和寄存器之间调用关系,以及SysTick定时器的中断处理。本章阅读提示:11.1 关于(介绍STM32的SysTick定时器工作方式和寄存器,需要理解)11.2 硬件设计(SysTick定时器不涉及硬件)11.3 软件设计(讲解如何配置SysTick定时器、SysTick定时器的中断函数如何处理,需要理解)11.4 实验效果(展示实验效果,操作即可) 11.1 关于SysTick定时器 SysTick定时器(又名系统滴答定时器)是存在于C
[单片机]
【<font color='red'>STM32</font>单片机学习】第11章 基础重点—SysTick定时器
为什么我学了几天 STM32 感觉一脸茫然?
如果你只有C语言基础就马上学习STM32,你一定会有这些疑惑: 为什么有这么多没见过的API函数?没见过的变量(寄存器)名称? 为什么工程除了main.c,还有这么多其它没见过的文件?它们有什么用? 什么是Flash?什么是RAM?什么是ROM? 什么是寄存器?什么是时钟?什么是中断?什么是定时器?什么是DMA? 什么是端口复用与重映射?什么是ADC?什么是PWM?什么是UART?什么是IIC?什么是SPI? 什么是原理图?什么是PCB?什么是晶振?什么是复位?什么是电平?什么是上拉下拉浮空? 为什么我的helloworld c语言程序不能下载到STM32中运行?为什么下载的固是.hex文件?.hex .bin .exe文件有什么
[单片机]
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
