STM32启动文件
发布者:幸福如愿最新更新时间:2024-10-12 来源: cnblogs关键字:STM32  启动文件 手机看文章 扫描二维码
随时随地手机看文章
;******************** (C) COPYRIGHT 2014 STMicroelectronics ********************
;* File Name          : startup_stm32f40_41xxx.s
;* Author             : MCD Application Team
;* @version           : V1.4.0
;* @date              : 04-August-2014
;* Description        : STM32F40xxx/41xxx devices vector table for MDK-ARM toolchain.
;*                      This module performs:
;*                      - Set the initial SP
;*                      - Set the initial PC == Reset_Handler
;*                      - Set the vector table entries with the exceptions ISR address
;*                      - Configure the system clock and the external SRAM mounted on
;*                        STM324xG-EVAL board to be used as data memory (optional,
;*                        to be enabled by user)
;*                      - Branches to __main in the C library (which eventually
;*                        calls main()).
;*                      After Reset the CortexM4 processor is in Thread mode,
;*                      priority is Privileged, and the Stack is set to Main.
;* <<< Use Configuration Wizard in Context Menu >>>
; Licensed under MCD-ST Liberty SW License Agreement V2, (the 'License');
; You may not use this file except in compliance with the License.
; You may obtain a copy of the License at:
; Unless required by applicable law or agreed to in writing, software
; distributed under the License is distributed on an 'AS IS' BASIS,
; WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
; See the License for the specific language governing permissions and
; limitations under the License.
; Amount of memory (in bytes) allocated for Stack
; Tailor this value to your application needs
; Stack Configuration
;   Stack Size (in Bytes) <0x0-0xFFFFFFFF:8>
Stack_Size      EQU     0x00000400
                AREA    STACK, NOINIT, READWRITE, ALIGN=3
Stack_Mem       SPACE   Stack_Size
__initial_sp
; Heap Configuration
;    Heap Size (in Bytes) <0x0-0xFFFFFFFF:8>
Heap_Size       EQU     0x00000000 ;我们不使用MDK自带的malloc和free函数,所以设置这里为0.
                AREA    HEAP, NOINIT, READWRITE, ALIGN=3
__heap_base
Heap_Mem        SPACE   Heap_Size
__heap_limit
                PRESERVE8
                THUMB
; Vector Table Mapped to Address 0 at Reset
                AREA    RESET, DATA, READONLY
                EXPORT  __Vectors
                EXPORT  __Vectors_End
                EXPORT  __Vectors_Size
__Vectors       DCD     __initial_sp               ; Top of Stack
                DCD     Reset_Handler              ; Reset Handler
                DCD     NMI_Handler                ; NMI Handler
                DCD     HardFault_Handler          ; Hard Fault Handler
                DCD     MemManage_Handler          ; MPU Fault Handler
                DCD     BusFault_Handler           ; Bus Fault Handler
                DCD     UsageFault_Handler         ; Usage Fault Handler
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     0                          ; Reserved
                DCD     SVC_Handler                ; SVCall Handler
                DCD     DebugMon_Handler           ; Debug Monitor Handler
                DCD     0                          ; Reserved
                DCD     PendSV_Handler             ; PendSV Handler
                DCD     SysTick_Handler            ; SysTick Handler
                ; External Interrupts
                DCD     WWDG_IRQHandler                   ; Window WatchDog
                DCD     PVD_IRQHandler                    ; PVD through EXTI Line detection
                DCD     TAMP_STAMP_IRQHandler             ; Tamper and TimeStamps through the EXTI line
                DCD     RTC_WKUP_IRQHandler               ; RTC Wakeup through the EXTI line
                DCD     FLASH_IRQHandler                  ; FLASH
                DCD     RCC_IRQHandler                    ; RCC
                DCD     EXTI0_IRQHandler                  ; EXTI Line0
                DCD     EXTI1_IRQHandler                  ; EXTI Line1
                DCD     EXTI2_IRQHandler                  ; EXTI Line2
                DCD     EXTI3_IRQHandler                  ; EXTI Line3
                DCD     EXTI4_IRQHandler                  ; EXTI Line4
                DCD     DMA1_Stream0_IRQHandler           ; DMA1 Stream 0
                DCD     DMA1_Stream1_IRQHandler           ; DMA1 Stream 1
                DCD     DMA1_Stream2_IRQHandler           ; DMA1 Stream 2
                DCD     DMA1_Stream3_IRQHandler           ; DMA1 Stream 3
                DCD     DMA1_Stream4_IRQHandler           ; DMA1 Stream 4
                DCD     DMA1_Stream5_IRQHandler           ; DMA1 Stream 5
                DCD     DMA1_Stream6_IRQHandler           ; DMA1 Stream 6
                DCD     ADC_IRQHandler                    ; ADC1, ADC2 and ADC3s
                DCD     CAN1_TX_IRQHandler                ; CAN1 TX
                DCD     CAN1_RX0_IRQHandler               ; CAN1 RX0
                DCD     CAN1_RX1_IRQHandler               ; CAN1 RX1
                DCD     CAN1_SCE_IRQHandler               ; CAN1 SCE
                DCD     EXTI9_5_IRQHandler                ; External Line[9:5]s
                DCD     TIM1_BRK_TIM9_IRQHandler          ; TIM1 Break and TIM9
                DCD     TIM1_UP_TIM10_IRQHandler          ; TIM1 Update and TIM10
                DCD     TIM1_TRG_COM_TIM11_IRQHandler     ; TIM1 Trigger and Commutation and TIM11
                DCD     TIM1_CC_IRQHandler                ; TIM1 Capture Compare
                DCD     TIM2_IRQHandler                   ; TIM2
                DCD     TIM3_IRQHandler                   ; TIM3
                DCD     TIM4_IRQHandler                   ; TIM4
                DCD     I2C1_EV_IRQHandler                ; I2C1 Event
                DCD     I2C1_ER_IRQHandler                ; I2C1 Error
                DCD     I2C2_EV_IRQHandler                ; I2C2 Event
                DCD     I2C2_ER_IRQHandler                ; I2C2 Error
                DCD     SPI1_IRQHandler                   ; SPI1
                DCD     SPI2_IRQHandler                   ; SPI2
                DCD     USART1_IRQHandler                 ; USART1
                DCD     USART2_IRQHandler                 ; USART2
                DCD     USART3_IRQHandler                 ; USART3
                DCD     EXTI15_10_IRQHandler              ; External Line[15:10]s
                DCD     RTC_Alarm_IRQHandler              ; RTC Alarm (A and B) through EXTI Line
                DCD     OTG_FS_WKUP_IRQHandler            ; USB OTG FS Wakeup through EXTI line
                DCD     TIM8_BRK_TIM12_IRQHandler         ; TIM8 Break and TIM12
                DCD     TIM8_UP_TIM13_IRQHandler          ; TIM8 Update and TIM13
                DCD     TIM8_TRG_COM_TIM14_IRQHandler     ; TIM8 Trigger and Commutation and TIM14
                DCD     TIM8_CC_IRQHandler                ; TIM8 Capture Compare
                DCD     DMA1_Stream7_IRQHandler           ; DMA1 Stream7
                DCD     FSMC_IRQHandler                   ; FSMC
                DCD     SDIO_IRQHandler                   ; SDIO
                DCD     TIM5_IRQHandler                   ; TIM5
                DCD     SPI3_IRQHandler                   ; SPI3
                DCD     UART4_IRQHandler                  ; UART4
                DCD     UART5_IRQHandler                  ; UART5
                DCD     TIM6_DAC_IRQHandler               ; TIM6 and DAC1&2 underrun errors
                DCD     TIM7_IRQHandler                   ; TIM7
                DCD     DMA2_Stream0_IRQHandler           ; DMA2 Stream 0
                DCD     DMA2_Stream1_IRQHandler           ; DMA2 Stream 1
                DCD     DMA2_Stream2_IRQHandler           ; DMA2 Stream 2
                DCD     DMA2_Stream3_IRQHandler           ; DMA2 Stream 3
                DCD     DMA2_Stream4_IRQHandler           ; DMA2 Stream 4
                DCD     ETH_IRQHandler                    ; Ethernet
                DCD     ETH_WKUP_IRQHandler               ; Ethernet Wakeup through EXTI line
                DCD     CAN2_TX_IRQHandler                ; CAN2 TX
                DCD     CAN2_RX0_IRQHandler               ; CAN2 RX0
                DCD     CAN2_RX1_IRQHandler               ; CAN2 RX1
                DCD     CAN2_SCE_IRQHandler               ; CAN2 SCE
                DCD     OTG_FS_IRQHandler                 ; USB OTG FS
                DCD     DMA2_Stream5_IRQHandler           ; DMA2 Stream 5
                DCD     DMA2_Stream6_IRQHandler           ; DMA2 Stream 6
                DCD     DMA2_Stream7_IRQHandler           ; DMA2 Stream 7
                DCD     USART6_IRQHandler                 ; USART6
                DCD     I2C3_EV_IRQHandler                ; I2C3 event
                DCD     I2C3_ER_IRQHandler                ; I2C3 error
                DCD     OTG_HS_EP1_OUT_IRQHandler         ; USB OTG HS End Point 1 Out
                DCD     OTG_HS_EP1_IN_IRQHandler          ; USB OTG HS End Point 1 In
                DCD     OTG_HS_WKUP_IRQHandler            ; USB OTG HS Wakeup through EXTI
                DCD     OTG_HS_IRQHandler                 ; USB OTG HS
                DCD     DCMI_IRQHandler                   ; DCMI
                DCD     CRYP_IRQHandler                   ; CRYP crypto
                DCD     HASH_RNG_IRQHandler               ; Hash and Rng
                DCD     FPU_IRQHandler                    ; FPU
__Vectors_End
__Vectors_Size  EQU  __Vectors_End - __Vectors
                AREA    |.text|, CODE, READONLY
; Reset handler
Reset_Handler    PROC
                 EXPORT  Reset_Handler             [WEAK]
        ;IMPORT  SystemInit ;寄存器代码,不需要在这里调用SystemInit函数,故屏蔽掉,库函数版本代码,可以留下
;不过需要在外部实现SystemInit函数,否则会报错.
        IMPORT  __main
                 LDR     R0, =0xE000ED88    ; 使能浮点运算 CP10,CP11
                 LDR     R1,[R0]
                 ORR     R1,R1,#(0xF << 20)
                 STR     R1,[R0]
                 ;LDR     R0, =SystemInit ;寄存器代码,未用到,屏蔽
                 ;BLX     R0 ;寄存器代码,未用到,屏蔽
                 LDR     R0, =__main
                 BX      R0
                 ENDP
; Dummy Exception Handlers (infinite loops which can be modified)
NMI_Handler     PROC
                EXPORT  NMI_Handler                [WEAK]
                B       .
                ENDP
HardFault_Handler
                PROC
                EXPORT  HardFault_Handler          [WEAK]
                B       .
                ENDP
MemManage_Handler
                PROC
                EXPORT  MemManage_Handler          [WEAK]
                B       .
                ENDP
BusFault_Handler
                PROC
                EXPORT  BusFault_Handler           [WEAK]
                B       .
                ENDP
UsageFault_Handler
                PROC
                EXPORT  UsageFault_Handler         [WEAK]
                B       .
                ENDP
SVC_Handler     PROC
                EXPORT  SVC_Handler                [WEAK]
                B       .
                ENDP
DebugMon_Handler
                PROC
                EXPORT  DebugMon_Handler           [WEAK]
                B       .
                ENDP
PendSV_Handler  PROC
                EXPORT  PendSV_Handler             [WEAK]
                B       .
                ENDP
SysTick_Handler PROC
                EXPORT  SysTick_Handler            [WEAK]
                B       .
                ENDP
Default_Handler PROC
                EXPORT  WWDG_IRQHandler                   [WEAK]
                EXPORT  PVD_IRQHandler                    [WEAK]
                EXPORT  TAMP_STAMP_IRQHandler             [WEAK]
                EXPORT  RTC_WKUP_IRQHandler               [WEAK]
                EXPORT  FLASH_IRQHandler                  [WEAK]
                EXPORT  RCC_IRQHandler                    [WEAK]
                EXPORT  EXTI0_IRQHandler                  [WEAK]
                EXPORT  EXTI1_IRQHandler                  [WEAK]
                EXPORT  EXTI2_IRQHandler                  [WEAK]
                EXPORT  EXTI3_IRQHandler                  [WEAK]
                EXPORT  EXTI4_IRQHandler                  [WEAK]
                EXPORT  DMA1_Stream0_IRQHandler           [WEAK]
                EXPORT  DMA1_Stream1_IRQHandler           [WEAK]
                EXPORT  DMA1_Stream2_IRQHandler           [WEAK]
                EXPORT  DMA1_Stream3_IRQHandler           [WEAK]
                EXPORT  DMA1_Stream4_IRQHandler           [WEAK]
                EXPORT  DMA1_Stream5_IRQHandler           [WEAK]
                EXPORT  DMA1_Stream6_IRQHandler           [WEAK]
                EXPORT  ADC_IRQHandler                    [WEAK]
                EXPORT  CAN1_TX_IRQHandler                [WEAK]
                EXPORT  CAN1_RX0_IRQHandler               [WEAK]
                EXPORT  CAN1_RX1_IRQHandler               [WEAK]
                EXPORT  CAN1_SCE_IRQHandler               [WEAK]
                EXPORT  EXTI9_5_IRQHandler                [WEAK]
                EXPORT  TIM1_BRK_TIM9_IRQHandler          [WEAK]
                EXPORT  TIM1_UP_TIM10_IRQHandler          [WEAK]
                EXPORT  TIM1_TRG_COM_TIM11_IRQHandler     [WEAK]
                EXPORT  TIM1_CC_IRQHandler                [WEAK]
                EXPORT  TIM2_IRQHandler                   [WEAK]
                EXPORT  TIM3_IRQHandler                   [WEAK]
                EXPORT  TIM4_IRQHandler                   [WEAK]
                EXPORT  I2C1_EV_IRQHandler                [WEAK]
                EXPORT  I2C1_ER_IRQHandler                [WEAK]
                EXPORT  I2C2_EV_IRQHandler                [WEAK]
                EXPORT  I2C2_ER_IRQHandler                [WEAK]
                EXPORT  SPI1_IRQHandler                   [WEAK]
                EXPORT  SPI2_IRQHandler                   [WEAK]
                EXPORT  USART1_IRQHandler                 [WEAK]
                EXPORT  USART2_IRQHandler                 [WEAK]
                EXPORT  USART3_IRQHandler                 [WEAK]
                EXPORT  EXTI15_10_IRQHandler              [WEAK]
                EXPORT  RTC_Alarm_IRQHandler              [WEAK]
                EXPORT  OTG_FS_WKUP_IRQHandler            [WEAK]
                EXPORT  TIM8_BRK_TIM12_IRQHandler         [WEAK]
                EXPORT  TIM8_UP_TIM13_IRQHandler          [WEAK]
                EXPORT  TIM8_TRG_COM_TIM14_IRQHandler     [WEAK]
                EXPORT  TIM8_CC_IRQHandler                [WEAK]
                EXPORT  DMA1_Stream7_IRQHandler           [WEAK]
                EXPORT  FSMC_IRQHandler                   [WEAK]
                EXPORT  SDIO_IRQHandler                   [WEAK]
                EXPORT  TIM5_IRQHandler                   [WEAK]
                EXPORT  SPI3_IRQHandler                   [WEAK]
                EXPORT  UART4_IRQHandler                  [WEAK]
                EXPORT  UART5_IRQHandler                  [WEAK]
                EXPORT  TIM6_DAC_IRQHandler               [WEAK]
                EXPORT  TIM7_IRQHandler                   [WEAK]
                EXPORT  DMA2_Stream0_IRQHandler           [WEAK]
                EXPORT  DMA2_Stream1_IRQHandler           [WEAK]
                EXPORT  DMA2_Stream2_IRQHandler           [WEAK]
                EXPORT  DMA2_Stream3_IRQHandler           [WEAK]
                EXPORT  DMA2_Stream4_IRQHandler           [WEAK]
                EXPORT  ETH_IRQHandler                    [WEAK]
                EXPORT  ETH_WKUP_IRQHandler               [WEAK]
                EXPORT  CAN2_TX_IRQHandler                [WEAK]
                EXPORT  CAN2_RX0_IRQHandler               [WEAK]
                EXPORT  CAN2_RX1_IRQHandler               [WEAK]
                EXPORT  CAN2_SCE_IRQHandler               [WEAK]
                EXPORT  OTG_FS_IRQHandler                 [WEAK]
                EXPORT  DMA2_Stream5_IRQHandler           [WEAK]
                EXPORT  DMA2_Stream6_IRQHandler           [WEAK]
                EXPORT  DMA2_Stream7_IRQHandler           [WEAK]
                EXPORT  USART6_IRQHandler                 [WEAK]
                EXPORT  I2C3_EV_IRQHandler                [WEAK]
                EXPORT  I2C3_ER_IRQHandler                [WEAK]
                EXPORT  OTG_HS_EP1_OUT_IRQHandler         [WEAK]
                EXPORT  OTG_HS_EP1_IN_IRQHandler          [WEAK]
                EXPORT  OTG_HS_WKUP_IRQHandler            [WEAK]
                EXPORT  OTG_HS_IRQHandler                 [WEAK]
                EXPORT  DCMI_IRQHandler                   [WEAK]
                EXPORT  CRYP_IRQHandler                   [WEAK]
                EXPORT  HASH_RNG_IRQHandler               [WEAK]
                EXPORT  FPU_IRQHandler                    [WEAK]
WWDG_IRQHandler
PVD_IRQHandler
RTC_WKUP_IRQHandler
FLASH_IRQHandler
RCC_IRQHandler
EXTI0_IRQHandler
EXTI1_IRQHandler
EXTI2_IRQHandler
EXTI3_IRQHandler
EXTI4_IRQHandler
ADC_IRQHandler
CAN1_TX_IRQHandler
CAN1_RX0_IRQHandler
CAN1_RX1_IRQHandler
CAN1_SCE_IRQHandler
EXTI9_5_IRQHandler
TIM1_CC_IRQHandler
TIM2_IRQHandler
TIM3_IRQHandler
TIM4_IRQHandler
I2C1_EV_IRQHandler
I2C1_ER_IRQHandler
I2C2_EV_IRQHandler
I2C2_ER_IRQHandler
SPI1_IRQHandler
SPI2_IRQHandler
USART1_IRQHandler
USART2_IRQHandler
USART3_IRQHandler
TIM8_CC_IRQHandler
FSMC_IRQHandler
SDIO_IRQHandler
TIM5_IRQHandler
SPI3_IRQHandler
UART4_IRQHandler
UART5_IRQHandler
TIM6_DAC_IRQHandler
TIM7_IRQHandler
ETH_IRQHandler
ETH_WKUP_IRQHandler
CAN2_TX_IRQHandler
CAN2_RX0_IRQHandler
CAN2_RX1_IRQHandler
CAN2_SCE_IRQHandler
OTG_FS_IRQHandler
USART6_IRQHandler
I2C3_EV_IRQHandler
I2C3_ER_IRQHandler
OTG_HS_IRQHandler
DCMI_IRQHandler
CRYP_IRQHandler
HASH_RNG_IRQHandler
FPU_IRQHandler
                B       .
                ENDP
                ALIGN
; User Stack and Heap initialization
                 IF      :DEF:__MICROLIB
                 EXPORT  __initial_sp
                 EXPORT  __heap_base
                 EXPORT  __heap_limit
                 ELSE
                 IMPORT  __use_two_region_memory
                 EXPORT  __user_initial_stackheap
                 LDR     R0, =  Heap_Mem
                 LDR     R1, =(Stack_Mem + Stack_Size)
                 LDR     R2, = (Heap_Mem +  Heap_Size)
                 LDR     R3, = Stack_Mem
                 BX      LR
                 ALIGN
                 ENDIF
                 END
[1] [2]
关键字:STM32  启动文件 引用地址:STM32启动文件
上一篇:手把手之STM32内核定时器
下一篇:STM32 LwIP测试过程简介
推荐阅读最新更新时间:2026-03-19 16:05
STM32启动文件:startup_stm32f10x_hd.s等启动文件的简单描述
在官方的库文件中,分别有如下文件: startup │ │ │ ├─arm │ │ │ │ startup_stm32f10x_cl.s │ │ │ │ startup_stm32f10x_hd.s │ │ │ │ startup_stm32f10x_hd_vl.s │ │ │ │ startup_stm32f10x_ld.s │ │ │ │ startup_stm32f10x_ld_vl.s │ │ │ │ startup_stm32f10x_md.s │ │ │ │ s
[单片机]
stm32启动文件和汇编指令简析
以stm32fxxxx为例 一、启动文件,startup_stm32f40_41xxx.S 1.定义:启动文件由汇编填写,是系统上电复位后第一个执行的程序。 2.特征 (1)初始化堆栈指针SP=_initial_sp (2)初始化PC指针=Reset_Handler (3)初始化中断向量表。 (4)配置系统时钟。 (5)调用c库函数_main初始化用户堆栈,从而最终调用main函数去到c的内容。 二、汇编指令 启动文件使用ARM汇编指令汇总 EQU 给数字常量取一个符号名,相当于c语言define。 AREA 汇编一个新的代码段或数据段。 SPACE 分配内存空间。 PRESERVE8 当前文件堆栈需按照8字节对齐。 EXP
[单片机]
STM32启动文件startup_stm32f10x_hd.s的代码讲解
本文对STM32启动文件startup_stm32f10x_hd.s的代码进行讲解,此文件的代码在任何一个STM32F10x工程中都可以找到。 启动文件使用的ARM汇编指令汇总 Stack——栈 Stack_Size EQU 0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN= Stack_Mem SPACE Stack_Size __initial_sp 开辟栈的大小为 0X00000400(1KB),名字为 STACK, NOINIT 即不初始化,可读可写, 8(2^3)字节对齐。 栈的作用是用于局部变量,函数调用,函数形参等的开销,栈的大小不能超过内部SRA
[单片机]
<font color='red'>STM32</font><font color='red'>启动文件</font>startup_stm32f10x_hd.s的代码讲解
解析STM32的启动过程及STM32 启动文件选择
STM32 启动文件选择 小容量产品是指闪存存储器容量在16K至32K字节之间的STM32F101xx、STM32F102xx和STM32F103xx微控制器。 中容量产品是指闪存存储器容量在64K至128K字节之间的STM32F101xx、STM32F102xx和STM32F103xx微控制器。 大容量产品是指闪存存储器容量在256K至512K字节之间的STM32F101xx和STM32F103xx微控制器。 互联型产品是指STM32F105xx和STM32F107xx微控制器。 - startup_stm32f10x_ld_vl.s: for STM32 Low density Value line devices - st
[单片机]
详解STM32启动文件
本文对STM32启动文件startup_stm32f10x_hd.s的代码进行讲解,此文件的代码在任何一个STM32F10x工程中都可以找到。可以点击文末阅读原文直接下载此文件,提取码stm3。 启动文件使用的ARM汇编指令汇总 Stack——栈 Stack_Size EQU 0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN= Stack_Mem SPACE Stack_Size __initial_sp 开辟栈的大小为 0X00000400(1KB),名字为 STACK, NOINIT 即不初始化,可读可写, 8(2^3)字节对齐。 栈的作用是用于局部变量,函数调用,函数形
[单片机]
stm32启动文件--startup_stm32f10x_hd.s
在学习stm32 定时器中断时,发现我写的程序进入不了中断服务程序,而且我也没找到定时器服务程序的注册入口,上网查了一下,大家都使用的都是下面这个函数:void TIM3_IRQHandler(void),那为什么其他人的中断程序可以执行,而我的却执行不了呢。 经过请教得知,我的工程中没有包含该一个叫做startup_stm32f10x_hd.s的文件,而我所谓的中断服务程序的注册入口就是包含在这里。startup_stm32f10x_hd.s是用汇编语言编写的STM32处理器的初始化程序,它规定了系统的堆栈大小等系统信息,也包含了一个向量表,这个向量表中对所有的中断入口函数都进行了分配,如TIM3的中断入口是: ……
[单片机]
玩转STM32(5)找到启动文件
前学习了目录分类的重要性,可以看到分为三个目录,那么你选择哪一个目录点击进入去呢?因为我们要打开项目工程,那么就需要找到开发工具的工程文件,因此就需要打开工程的目录Project,就是这个目录命名的原因。在这个目录下面放置所有与目录相关的文件,当你打开这个目录时,就可以看到目录大体如下: 在这里一眼看到最醒目的图标那个就是启动工程文件,只要双击这个文件就可以打开工程了。你也许想问其它文件是做什么作用呢,为什么需要这么多文件呢?现在我们就来详细地看一下工程目录每个文件和目录的大体作用。 到这里已经把Project下的文件和目录搞清楚,因此当你打开工程时,记得找到像project.uvprojx文件结尾的文件,就是工程文件,才
[单片机]
玩转<font color='red'>STM32</font>(5)找到<font color='red'>启动文件</font>
STM32启动文件和链接脚本
铺垫 SP 栈指针,栈由程序分配,函数的参数传递,存储局部变量,在中断等异常产生时保存处理器状态和寄存器数值。都需要 SP 指引,才能从正确的地址空间取出正确的数据来确保程序执行。 在 cortex-M 中R13 为栈指针。物理上存在两个栈指针,分别是主栈指针 MSP,进程栈指针 PSP。在复位后或处理器处于处理模式时,其 MSP 会被处理器选择使用。大多数情况下,若应用程序不需要嵌入式 OS, 那么 PSP 没必要使用。PSP 的初始值未定义,而 MSP 的初始值则需要在复位流程中从存储器第一个字中取出。 cortex-M 处理器使用的栈模型被称作 “满递减”。处理器启动后,SP 被设置为栈存储空间的最后位置。对于每
[单片机]
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
