今天我们要学习的是使用gdb和gdbserver来远程调试开发板程序.
下面是本人的一些具体步骤:
下载gdb-7.9.tar.gz地址:
http://ftp.gnu.org/gnu/gdb/gdb-7.9.tar.gz
安装gdb
tar -jxvf gdb-7.9.tar.bz2
./configure -target=arm-none-linux-gnueabi --prefix=/home/study/nfs_home/rootfs_imx257/arm-linux-gdb –program-prefix=arm-none-linux-gnueabi-
make
make install
安装gdbserver
./configure -target=arm-none-linux-gnueabi --prefix=/home/study/nfs_home/rootfs_imx257/arm-linux-gdbserver --host=arm-none-linux-gnueabi
make
make install
具体安装步骤如下:
编译安装gdb
root@Lover雪:/home/study/nfs_home/system# tar -jxvf gdb-7.9.tar.bz2
root@Lover雪:/home/study/nfs_home/system# cd gdb-7.9
root@Lover雪:/home/study/nfs_home/system/gdb-7.9# mkdir ../../rootfs_imx257/arm-linux-gdb
./configure -target=arm-none-linux-gnueabi --prefix=/home/study/nfs_home/rootfs_imx257/arm-linux-gdb --program-prefix=arm-none-linux-gnueabi-
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking target system type... arm-none-linux-gnueabi
root@Lover雪:/home/study/nfs_home/system/gdb-7.9# make
root@Lover雪:/home/study/nfs_home/system/gdb-7.9# make install
安装完毕发现多了一些文件夹
root@Lover雪:/home/study/nfs_home/system/gdb-7.9# ll ../../rootfs_imx257/arm-linux-gdb/
总用量 24
drwxr-xr-x 6 root root 4096 5月 2 06:34 ./
drwxrwxrwx 14 root root 4096 5月 2 06:11 ../
drwxr-xr-x 2 root root 4096 5月 2 06:34 bin/
drwxr-xr-x 3 root root 4096 5月 2 06:34 include/
drwxr-xr-x 2 root root 4096 5月 2 06:34 lib/
drwxr-xr-x 5 root root 4096 5月 2 06:34 share/
root@Lover雪:/home/study/nfs_home/system/gdb-7.9# cd gdb
编译安装gdbserver
root@Lover雪:/home/study/nfs_home/system/gdb-7.9/gdb# cd gdbserver/
root@Lover雪:/home/study/nfs_home/system/gdb-7.9/gdb/gdbserver#
mkdir /home/study/nfs_home/rootfs_imx257/arm-linux-gdbserver
configure: WARNING: If you wanted to set the --build type, don't use --host.
If a cross compiler is detected then cross compile mode will be used.
checking whether to enable maintainer-specific portions of Makefiles... no
checking for arm-none-linux-gnueabi-gcc... arm-none-linux-gnueabi-gcc
checking for C compiler default output file name... a.out
进入安装目录运行gdb查看版本
loverxueer@Lover雪:/home/study/nfs_home/rootfs_imx257$ ./arm-linux-gdb/bin/arm-none-linux-gnueabi-gdb
GNU gdb (GDB) 7.9
Copyright (C) 2015 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type 'show copying'
and 'show warranty' for details.
This GDB was configured as '--host=x86_64-unknown-linux-gnu --target=arm-none-linux-gnueabi'.
Type 'show configuration' for configuration details.
For bug reporting instructions, please see:
Find the GDB manual and other documentation resources online at:
For help, type 'help'.
Type 'apropos word' to search for commands related to 'word'.
(gdb) q
进入开发板目录,再开发板上运行gdbserver查看版本
root@EasyARM-iMX257 /mnt/nfs/rootfs_imx257# ./arm-linux-gdbserver/bin/arm-none-l
inux-gnueabi-gdbserver --version
GNU gdbserver (GDB) 7.9
gdbserver is free software, covered by the GNU General Public License.
This gdbserver was configured as 'arm-none-linux-gnueabi'
使用gdb和gdbserver远程调试程序
附上应用程序gdb_test.c
1 #include
3 char *p = 'hello,this is test gdb & gdbserver ';
5 void delay(int m)
6 {
7 int n;
8 while(m--)
9 for(n =0; n<100; n++);
10 }
12 void print(char *p, int cnt)
13 {
14 printf('%s cnt=%dn',p,cnt);
15 }
17 int main(void)
18 {
19 int cnt = 0;
20 while(1)
21 {
22 cnt++;
23 print(p,cnt);
24 delay(100000);
25 }
26 return 0;
27 }
首先再开发板写好写程序.编译
root@Lover雪:/home/study/nfs_home/module/40_gdb_gdbserver_test# vi gdb_test.c
arm-none-linux-gnueabi-gcc -g gdb_test.c -o gdb_test
这里注意一定要加 -g 选项
进入我们安装的gdb的目录
cd /home/study/nfs_home/rootfs_imx257/arm-linux-gdb/bin/
root@Lover雪:/home/study/nfs_home/rootfs_imx257/arm-linux-gdb/bin# ./arm-none-linux-gnueabi-gdb
连接开发板,在开发板操作步骤如下:
cp arm-linux-gdbserver/bin/arm-none-linux-gnueabi-gdbserver /bin/
进入要运行的程序的目录
root@EasyARM-iMX257 /mnt/nfs/rootfs_imx257# cd ../module/40_gdb_gdbserver_test/
root@EasyARM-iMX257 /mnt/nfs/module/40_gdb_gdbserver_test# ls
gdb_test gdb_test.c make.sh
获取开发板当前的ip
root@EasyARM-iMX257 /mnt/nfs/module/40_gdb_gdbserver_test# ifconfig
eth0 Link encap:Ethernet H
inet addr:192.168.31.181
Bcast:192.168.31.255 Mask:255.255.255.0
UP BROADCAST ric:1
RX packets:720 errors:0 dropped:0 overruns:0 frame:0
TX packets:105 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:950466 (928.1 KiB) TX bytes:18426 (17.9 KiB)
Base address:0x2000
开始运行gdbserver监控,监控端口随便写,此处为1234
root@EasyARM-iMX257 /mnt/nfs/module/40_gdb_gdbserver_test# arm-none-linux-gnueab
i-gdbserver 192.168.31.181:1234 ./gdb_test
Process ./gdb_test created; pid = 1816
Listening on port 1234
当宿主机连接成功后
Remote debugging from host 192.168.31.179 远程连接来自 192.168.31.179
当宿主机敲完命令后
hello,this is test gdb & gdbserver cnt=1
hello,this is test gdb & gdbserver cnt=2
hello,this is test gdb & gdbserver cnt=3
接着在 宿主机上运行gdb来连接gdbserver,进行调试.
步骤如下:
注意gdb的目录
运行gdb
GNU gdb (GDB) 7.9
(gdb)
开始连接gdbserver,IP:端口号
(gdb) target remote 192.168.31.181:1234
Remote debugging using 192.168.31.181:1234
0x400007e0 in ?? ()
(gdb) l
没有符号表被读取。请使用 'file' 命令。
(gdb) c
大家有没有发现,这样是连通了,也可以使用C命令运行,但是却无法使用list和break命令
答案:
因为调试的信息是从本地的文件中读取的,所以,宿主目录和开发板要进入同一个程序目录下,进行调试
所以再开发部上进入我的程序目录
cd /home/study/nfs_home/module/40_gdb_gdbserver_test/
注意gdb的目录
loverxueer@Lover雪:/home/study/nfs_home/module/40_gdb_gdbserver_test$
/home/study/nfs_home/rootfs_imx257/arm-linux-gdb/bin/arm-none-linux-gnueabi-gdb
GNU gdb (GDB) 7.9
0x400007e0 in ?? ()
(gdb) l
(gdb) symbol-file ./gdb_test
加载本地目录下的文件的信号表
Reading symbols from ./gdb_test...done.
(gdb) l
5 void delay(int m)
6 {
7 int n;
8 while(m--)
10 }
13 {
(gdb) b 22
Breakpoint 1 at 0x83fc: file gdb_test.c, line 22.
(gdb)
(gdb) c
Continuing.
Breakpoint 1, main () at gdb_test.c:22
22 cnt++;
(gdb) c
Continuing.
22 cnt++;
(gdb) c
Continuing.
22 cnt++;
(gdb) c
Continuing.
22 cnt++;
(gdb) print cnt
$1 = 3
(gdb) target exec
A program is being debugged already. Kill it? (y or n) y
No executable file now.
(gdb)
此时再看我们的开发板的串口窗口
如下所示:
Killing all inferiors
总结命令:
开发板的命令:
arm-none-linux-gnueabi-gdbserver 192.168.31.181:1234 ./gdb_test
宿主机的命令:
(gdb) symbol-file ./gdb_test 注意这个是调试程序的文件所在
(gdb) l
(gdb) b 20
(gdb) c
(gdb) target exec
配置内核输出应用程序的段错误信息
1 arch/arm/mm/fault.c
3 static void
4 __do_user_fault(struct task_struct *tsk, unsigned long addr,
上一篇:imx257下实现I2C驱动的四种方法
下一篇:调试分析之 修改内核来定位系统僵死问题
推荐阅读最新更新时间:2026-03-22 11:11
- RDR-142 - 35W电源
- i.MX RT1060 Evaluation Kit
- 使用 Embedded Planet 的 5CEFA9U27 的参考设计
- DC1369A-D、LTC2258-14 演示板、14 位 65 Msps ADC、LVDS 输出、5-170MHz
- LT3990EMSE-5 12V 降压转换器的典型应用
- 使用 Analog Devices 的 LTC1148 的参考设计
- LT1377IS8 具有直接反馈的正负转换器的典型应用
- 使用 NXP Semiconductors 的 TL431AI 的参考设计
- LT8304IS8E 18V 至 80Vin、5Vout 隔离反激式转换器的典型应用电路
- LT3512EMS 演示板,单片式高压隔离反激式转换器 36V VIN 75V,VOUT = 5V @ 500mA
- MTBF突破4万小时!这家工业级3D相机品牌产品稳定性获权威机构认可
- 英特尔创始人、“摩尔定律”提出者戈登·摩尔去世
- 本周机器人行业大事件TOP5
- G20周刊|埃斯顿与北自所达成战略合作、海康机器人发布光伏组件汇流带视觉检测解决方案
- 14家工业智能企业入选《上海市智能机器人标杆企业与应用场景推荐目录》
- Excelitas Technologies在德国斯图加特机器视觉展览会推出LINOS d.fine HR-M镜头系列
- 贸泽新一期EIT计划带您走近自主移动机器人
- 陕鼓签约世界首台(套)300MW级压缩空气储能电站示范工程项目
- 永清环保与普路通签约 开启储能项目合作
- 海辰储能深圳控制技术研究院正式揭牌成立
《无线电入门与晶体管收音机》
【Follow me第三季第2期】FRDM-MCXN947 任务源码汇总帖下载
现代雷达系统的信号设计
BFR340T
京公网安备 11010802033920号
