#define HCSR04_PORT   GPIOB
#define HCSR04_CLK    RCC_APB2Periph_GPIOB
#define HCSR04_TRIG   GPIO_Pin_8
#define HCSR04_ECHO   GPIO_Pin_9
#define TRIG_Send(n)  do{
if(n == 0)
GPIO_ResetBits(HCSR04_PORT,HCSR04_TRIG);
else if(n == 1)
GPIO_SetBits(HCSR04_PORT,HCSR04_TRIG);
}while(0)
#define ECHO_Reci     GPIO_ReadInputDataBit(GPIOB,HCSR04_ECHO)
void UltrasonicInit(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(HCSR04_CLK, ENABLE);
//IO初始化
GPIO_InitStructure.GPIO_Pin   = HCSR04_TRIG;       //发送电平引脚
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_Out_PP;//推挽输出
GPIO_Init(HCSR04_PORT, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin  = HCSR04_ECHO;     //返回电平引脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
GPIO_ResetBits(HCSR04_PORT,HCSR04_ECHO);
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;     //生成用于定时器设置的结构体
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM6, ENABLE);   //使能对应RCC时钟
//配置定时器基础结构体
TIM_DeInit(TIM6);
TIM_TimeBaseStructure.TIM_Period = (1000-1);          //设置在下一个更新事件装入活动的自动重装载寄存器周期的值         计数到1000为1ms
TIM_TimeBaseStructure.TIM_Prescaler =(72-1);          //设置用来作为TIMx时钟频率除数的预分频值  1M的计数频率 1US计数
TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;//不分频
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
TIM_TimeBaseInit(TIM6, &TIM_TimeBaseStructure);       //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
TIM_ClearFlag(TIM6, TIM_FLAG_Update);                 //清除更新中断,免得一打开中断立即产生中断
TIM_ITConfig(TIM6,TIM_IT_Update,ENABLE);              //打开定时器更新中断
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
NVIC_InitStructure.NVIC_IRQChannel = TIM6_IRQn;            //选择串口1中断
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;  //抢占式中断优先级设置为1
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;         //响应式中断优先级设置为1
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;            //使能中断
NVIC_Init(&NVIC_InitStructure);
TIM_Cmd(TIM6,DISABLE);
//定时器6中断服务程序
u32 msHcCount = 0;
void TIM6_IRQHandler(void)   //TIM6中断
if (TIM_GetITStatus(TIM6, TIM_IT_Update) != RESET)  //检查TIM3更新中断发生与否
TIM_ClearITPendingBit(TIM6, TIM_IT_Update);       //清除TIMx更新中断标志
msHcCount++;
static void OpenTimerForHc()    //打开定时器
TIM_SetCounter(TIM6,0);      //清除计数
msHcCount = 0;
TIM_Cmd(TIM6, ENABLE);       //使能TIMx外设
static void CloseTimerForHc()  //关闭定时器
TIM_Cmd(TIM6, DISABLE);      //使能TIMx外设
//获取定时器时间
u32 GetEchoTimer(void)
u32 t = 0;
t = msHcCount*1000;                  //将MS转换成US
t += TIM_GetCounter(TIM6);           //得到总的US
TIM6->CNT = 0;                       //将TIM6计数寄存器的计数值清零
return t;
//一次获取超声波测距数据 两次测距之间需要相隔一段时间,隔断回响信号
//为了消除余震的影响,取五次数据的平均值进行加权滤波。
float Hcsr04GetLength(void )
u32 t = 0;
int i = 0;
float lengthTemp = 0;
float sum = 0;
while(i!=5)
/*发送一个20ms的脉冲*/
TRIG_Send(1);
osDelay(20);
TRIG_Send(0);
while(ECHO_Reci == 0);     //等待接收口高电平输出(超声波发出)
OpenTimerForHc();          //打开定时器
while(ECHO_Reci == 1);     //等待超声波返回
CloseTimerForHc();         //关闭定时器
t = GetEchoTimer();        //获取时间,分辨率为1US
lengthTemp = ((float)t*17/1000.0);//cm
sum = lengthTemp + sum ;
 i = i + 1;
lengthTemp = sum/5.0;
return lengthTemp;
关键字:stm32驱动  超声波模块  中断服务 引用地址:stm32驱动超声波模块
上一篇:STM32单片机连接HC_SR04超声波模块测距
下一篇:基于STM32F103循迹小车
   鸿海已经是全球电子代工带头大哥,对于跨足半导体领域一直兴趣浓厚,先前积极投入竞标收购东芝半导体部门,可惜最后功败垂成,但郭台铭并不气馁,5月中前往清华大学演讲时就预告“半导体我们(鸿海集团)一定会自己做”,展现十足企图心。业界人士分析,鸿海积极转型发展工业互联网,需要大量芯片;加上并购夏普后,对半导体需求增加,要提高对产品...
新能源汽车的电池寿命一般仅为5年,我国第一批新能源汽车目前已经迎来了电池退役潮,而根据彭博社的新能源财经分析,我国的电池产能已经占了全球的73%。 根据BloombergNEF(彭博社新能源财经)的一项分析,2019年初全球锂电池产能为316亿千兆瓦时(GWh)。其中73%的产能来自中国,其次是美国以12%的全球产能远远落于其后。 到2025年,全球锂电池产能预计将...
  本文介绍的是一种新的检测系统,选用红外CO传感器和MSP430单片机作为核心信号处理电路,结合数字滤波、温度补偿运算.具有检测浓度范围宽、使用寿命长等优点。  系统组成及硬件设计  该系统由红外CO气体传感器、MSP430单片机、CAN总线接口及远程监控系统组成。该系统在检测现场通过单片机处理检测的数据、控制 LCD显示、声光报警,同时还配备CAN...
在了解探头的结构之前,需要先了解一下示波器输入接口的结构,因为这里是连接探头的地方,示波器的输入接口电路和探头共同组成了我们的探测系统。大部分的示波器输入接口采用的是BNC或兼容BNC的形式。示波器的输入端有1M欧姆或50欧姆的匹配电阻。示波器的探头种类很多,但是示波器的的匹配永远只有1M欧姆或50欧姆两种选择,不同种类的探头需要不同的匹配电...
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
