先来看一段STM32外设初始化代码:代码内容为初始化两个外设,在这里把他们都写到同一个函数里面了
static void ADC1_Mode_Config(void)
ADC_InitTypeDef ADC_InitStructure;
DMA_InitTypeDef DMA_InitStructure;
DMA_DeInit(DMA1_Channel1);
DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
//内存地址(要传输的变量的指针)
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;
//传输方向:从内存到外设
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;//设置外设为数据源,从外设读取数据到内存
DMA_InitStructure.DMA_BufferSize = 1;
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址固定
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;//内存地址固定
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;//接收模式,正常还是循环
DMA_InitStructure.DMA_Priority = DMA_Priority_High;
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
DMA_Init(DMA1_Channel1, &DMA_InitStructure);
DMA_Cmd(DMA1_Channel1, ENABLE);
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;//独立模式
ADC_InitStructure.ADC_ScanConvMode = DISABLE;
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel = 1;//要转换的通道数目
ADC_Init(ADC1, &ADC_InitStructure);
//配置ADC的时钟
RCC_ADCCLKConfig(RCC_PCLK2_Div8);
//配置采样周期
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5);
//设置ADC与DMA联通
ADC_DMACmd(ADC1, ENABLE);
//使能ADC
ADC_Cmd(ADC1, ENABLE);
//先复位校准,再ADC校准,顺序不要不能调换
ADC_ResetCalibration(ADC1);
while(ADC_GetResetCalibrationStatus(ADC1))
ADC_StartCalibration(ADC1);
while(ADC_GetCalibrationStatus(ADC1))
//设置为软件触发
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
这段代码是可以正确编译通过的,这里想引出的问题就在红色代码部分,注意,两个不同模块的结构体变量的声明放在一起了,按正常的思维逻辑是用到哪个结构体就声明哪一个。但是这里不能分开声明!也就是不能将ADC_InitTypeDef ADC_InitStructure;这一句放到DMA初始化语句的后面,也就是绿色字体部分,会报错!
adc.c(127): error: #268: declaration may not appear after executable statement in block
也就是不能将变量的声明放在语句之后,这是早期的C语言规定的,要求所有变量必须在函数开头声明。但是C++可以这么做,现在很多C编译器也允许变量的声明在语句后面。这里的MDK5.10不允许这么做,这个现象比较奇怪,不知道是不是为了优化内存分配才规定的
上一篇:STM32高级开发(18)-使用VS Code搭建STM32开发环境
下一篇:STM32之三标准外设版USB驱动库详解(架构+文件+函数+使用说明
- 【TI 教室】学电源,晒成绩,挖楼有礼!
- Dig八月 EEWORLD为你做专题!
- 有奖直播 | 安富利、Nordic、TDK | AIoT“ 算法+芯片+终端 ”边缘计算解决方案
- 相约秋色~相约北京~恩智浦工业和物联网技术峰会 约起来!
- 【评论有礼!】Sleepace RestOn 智能睡眠监测仪拆解
- EEWorld十五周年,感恩同行!盘点那些难忘的小确幸~
- 2016 TI嵌入式产品研讨会全网首映,下载有好礼!
- 月度原创精选评选2018年2月(总第2期)
- 电感知识大考:遇到这些问题怎么办?|“MPS电感探索季:发现小且不凡的秘密!”第一站
- 有奖直播|安森美高能效产品在 EV-Charger 市场的应用
ASM10DTBD-S664
京公网安备 11010802033920号
