Regulator相关GPIO控制使用流程简析
发布者:BlissfulSpirit最新更新时间:2025-02-18 来源: cnblogs关键字:Regulator  GPIO控制  使用流程 手机看文章 扫描二维码
随时随地手机看文章
1,注册到平台 举例:
extern struct gpio_regulator_platform_data v210_gpio_regs_platform_data;
static struct platform_device v210_gpio_regulators_dev = {
    .name        = 'gpio-regulators',
    .id        = -1,
    .dev = { .platform_data = &v210_gpio_regs_platform_data },
2,注册设备初始化接口
static struct regulator_consumer_supply gpio_reg_gpa07_consumers[] = {
        .supply        = 'vdd_gps',
static struct regulator_init_data gpio_reg_gpa07 = {
    .constraints    = {
        .name        = 'VDD_GPS12/VDD_GPS28',
        .valid_ops_mask = REGULATOR_CHANGE_STATUS,
        .state_mem    = {
            .mode    = REGULATOR_MODE_NORMAL,
            .enabled = 0,
    .num_consumer_supplies    = ARRAY_SIZE(gpio_reg_gpa07_consumers),
    .consumer_supplies    = gpio_reg_gpa07_consumers,
static struct regulator_consumer_supply gpio_reg_gpb3_consumers[] = {
        .supply        = 'vdd_camb',
static struct gpio_regulator v210_gpio_regulators [] = {
    [0] = {  /*'VDD_GPS',*/
        .gpio =  S5PV210_GPA0(7),
        .name = 'LDO_GPA0(7)',
        .type = GPIO_REGULATOR_VOLTAGE,
        .initdata = &gpio_reg_gpa07,
    [1] = { /*'VDD_CAMA',*/
        .gpio =  S5PV210_GPB(0),
        .name = 'LDO_GPB(0)',
        .initdata = &gpio_reg_gpb0,
    [2] = { /*'VDD_CAMB',*/
        .gpio =  S5PV210_GPB(3),
        .name = 'LDO_GPB(3)',
        .initdata = &gpio_reg_gpb3,
struct gpio_regulator_platform_data v210_gpio_regs_platform_data  = {
    .num_regulators = ARRAY_SIZE(v210_gpio_regulators),
    .regulators = v210_gpio_regulators,
3,Regulator设备驱动加载的时候初始化,下面的驱动的一般流程和LINUX下的流驱动   字符设备等基本没区别
#include <linux/module.h>
#include
#include
#include
#include
#include
#include
#include
#include
struct gpio_regulator_device_data {
    struct device        *dev;
    struct gpio_regulator_platform_data *pdata;
    int    num_regulators;
    struct regulator_dev    **rdev;
    struct XXX_gpio_regulator_data *pregdata;
struct XXX_gpio_regulator_data{
    struct regulator_desc reg_desc;
    int gpio_pin;
    int active_low;
    enum gpio_pull_mode pull;
    int gpio_sleep;    /*sleep mode. */
static int XXX_gpio_reg_is_enabled(struct regulator_dev *rdev)
    struct gpio_regulator_device_data *pddata = rdev_get_drvdata(rdev);
    int id, ret;
    id = rdev_get_id(rdev);
    pregdata = &pddata->pregdata[id];
    ret = (gpio_get_value(pregdata->gpio_pin))?1:0;
    if(pregdata->active_low)
        ret = !ret;
    printk('XXX_gpio_reg_is_enabled, regulator:[%s] is %dn', pregdata->reg_desc.name, ret);
    printk('gpio_pin: 0x%0xn', pregdata->gpio_pin);
    return ret;
static int XXX_gpio_reg_enable(struct regulator_dev *rdev)
    int id, value, ret;
    printk('XXX_gpio_reg_enable, regulator: %sn', pregdata->reg_desc.name);
    s3c_gpio_cfgpin(pregdata->gpio_pin,S3C_GPIO_OUTPUT);
    s3c_gpio_setpull(pregdata->gpio_pin,((__force s3c_gpio_pull_t)pregdata->pull));
    gpio_set_value(pregdata->gpio_pin, (pregdata->active_low?0:1));
    return 0;
static int XXX_gpio_reg_disable(struct regulator_dev *rdev)
    int id, value, ret;
    printk('XXX_gpio_reg_disable, regulator: %sn', pregdata->reg_desc.name );
    gpio_set_value(pregdata->gpio_pin, (pregdata->active_low?1:0));
    return 0;
static int XXX_gpio_reg_set_voltage(struct regulator_dev *rdev,
                int min_uV, int max_uV)
    return 0;
static int XXX_gpio_reg_get_voltage(struct regulator_dev *rdev)
    return 0;
static int XXX_gpio_reg_suspend_enable(struct regulator_dev *rdev)
    return 0;
static int XXX_gpio_reg_suspend_disable(struct regulator_dev *rdev)
    return 0;
static int XXX_gpio_reg_set_suspend_voltage(struct regulator_dev *rdev, int uV)
    return 0;
static struct regulator_ops XXX_gpio_reg_ops = {
    .list_voltage    = NULL, //XXX_gpio_reg_list_voltage,
    .is_enabled    = XXX_gpio_reg_is_enabled,
    .enable        = XXX_gpio_reg_enable,
    .disable    = XXX_gpio_reg_disable,
    .get_voltage    = XXX_gpio_reg_get_voltage,
    .set_voltage    = NULL,
    .set_suspend_enable    = XXX_gpio_reg_suspend_enable,
    .set_suspend_disable    = XXX_gpio_reg_suspend_disable,
    .set_suspend_voltage    = NULL,
static int __devinit XXX_gpio_regulators_probe(struct platform_device *pdev)
    int i, error;
    int id, ret;
    //jeff,
    struct gpio_regulator_platform_data *pdata = pdev->dev.platform_data;
    struct gpio_regulator_device_data *ddata;
    struct regulator_desc *gpio_reg_desc;
    printk('XXX_gpio_regulators_proben');
    ddata = kzalloc(sizeof(struct gpio_regulator_device_data),GFP_KERNEL);
    if (!ddata)
        return -ENOMEM;
    ddata->rdev  = kzalloc(sizeof(struct regulator_dev *) * (pdata->num_regulators + 1), GFP_KERNEL);
    if (!ddata->rdev) {
        kfree(ddata);
        return -ENOMEM;
    ddata->pregdata = kzalloc(sizeof(struct XXX_gpio_regulator_data) * (pdata->num_regulators + 1), GFP_KERNEL);
    if (!ddata->pregdata) {
        kfree(ddata->rdev);
        kfree(ddata);
        return -ENOMEM;
    ddata->num_regulators = pdata->num_regulators;
    for (i = 0; i < ddata->num_regulators; i++) {
        gpio_reg_desc = &(ddata->pregdata[i].reg_desc);
        gpio_reg_desc->id = i;
        gpio_reg_desc->name =  pdata->regulators[i].name;
        gpio_reg_desc->type = pdata->regulators[i].type;
        gpio_reg_desc->ops = &XXX_gpio_reg_ops;
        gpio_reg_desc->n_voltages = 1;
        gpio_reg_desc->owner    = THIS_MODULE,
        /*add regulator pin configure*/
        ddata->pregdata[i].gpio_pin = pdata->regulators[i].gpio;
        ddata->pregdata[i].active_low= pdata->regulators[i].active_low;
        ddata->pregdata[i].pull = pdata->regulators[i].pull;
        ddata->rdev[i] = regulator_register(gpio_reg_desc,
            ddata->dev,pdata->regulators[i].initdata, ddata);
        ret = IS_ERR(ddata->rdev[i]);
        if (ret)
            printk('[gpio_regulator] regulator:'%s' init failedn', gpio_reg_desc->name);
        else
            printk('[gpio_regulator] regulator:'%s' init successn', gpio_reg_desc->name);
    return ret;
static int __devexit XXX_gpio_regulators_remove(struct platform_device *pdev)
    printk('XXX_gpio_regulators_removen');
    return 0;
static struct platform_driver gpio_regulators_driver = {
[1] [2]
关键字:Regulator  GPIO控制  使用流程 引用地址:Regulator相关GPIO控制使用流程简析
上一篇:Realtek 8192cu 驱动移植到 Android 2.2
下一篇:KStudio window上编译uclinux
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
