printf('The default value of parking space is 5, Press key1 to apply for parking space, and press key2 to release parking space!nn');
/* USER CODE END 2 */
/* Create the mutex(es) */
/* definition and creation of MuxSem */
osMutexDef(MuxSem);
MuxSemHandle = osMutexCreate(osMutex(MuxSem));
/* USER CODE BEGIN RTOS_MUTEX */
/* add mutexes, ... */
/* USER CODE END RTOS_MUTEX */
/* USER CODE BEGIN RTOS_SEMAPHORES */
/* add semaphores, ... */
/* USER CODE END RTOS_SEMAPHORES */
/* USER CODE BEGIN RTOS_TIMERS */
/* start timers, add new ones, ... */
/* USER CODE END RTOS_TIMERS */
/* USER CODE BEGIN RTOS_QUEUES */
/* add queues, ... */
/* USER CODE END RTOS_QUEUES */
/* Create the thread(s) */
/* definition and creation of defaultTask */
osThreadDef(defaultTask, StartDefaultTask, osPriorityNormal, 0, 128);
defaultTaskHandle = osThreadCreate(osThread(defaultTask), NULL);
/* definition and creation of LowPriority */
osThreadDef(LowPriority, LowPriorityTask, osPriorityIdle, 0, 128);
LowPriorityHandle = osThreadCreate(osThread(LowPriority), NULL);
/* definition and creation of MidPriority */
osThreadDef(MidPriority, MidPriorityTask, osPriorityIdle, 0, 128);
MidPriorityHandle = osThreadCreate(osThread(MidPriority), NULL);
/* definition and creation of HighPriority */
osThreadDef(HighPriority, HighPriorityTask, osPriorityIdle, 0, 128);
HighPriorityHandle = osThreadCreate(osThread(HighPriority), NULL);
/* USER CODE BEGIN RTOS_THREADS */
/* add threads, ... */
/* USER CODE END RTOS_THREADS */
/* Start scheduler */
osKernelStart();
/* We should never get here as control is now taken by the scheduler */
/* Infinite loop */
/* USER CODE BEGIN WHILE */
while (1)
/* USER CODE END WHILE */
/* USER CODE BEGIN 3 */
/* USER CODE END 3 */
* @brief System Clock Configuration
* @retval None
void SystemClock_Config(void)
RCC_OscInitTypeDef RCC_OscInitStruct = {0};
RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
/** Initializes the RCC Oscillators according to the specified parameters
* in the RCC_OscInitTypeDef structure.
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
RCC_OscInitStruct.HSIState = RCC_HSI_ON;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
Error_Handler();
/** Initializes the CPU, AHB and APB buses clocks
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
* @brief USART1 Initialization Function
* @param None
* @retval None
static void MX_USART1_UART_Init(void)
/* USER CODE BEGIN USART1_Init 0 */
/* USER CODE END USART1_Init 0 */
/* USER CODE BEGIN USART1_Init 1 */
/* USER CODE END USART1_Init 1 */
huart1.Instance = USART1;
huart1.Init.BaudRate = 115200;
huart1.Init.WordLength = UART_WORDLENGTH_8B;
huart1.Init.StopBits = UART_STOPBITS_1;
huart1.Init.Parity = UART_PARITY_NONE;
huart1.Init.Mode = UART_MODE_TX_RX;
huart1.Init.HwFlowCtl = UART_HWCONTROL_NONE;
huart1.Init.OverSampling = UART_OVERSAMPLING_16;
if (HAL_UART_Init(&huart1) != HAL_OK)
Error_Handler();
/* USER CODE BEGIN USART1_Init 2 */
/* USER CODE END USART1_Init 2 */
* Enable DMA controller clock
static void MX_DMA_Init(void)
/* DMA controller clock enable */
__HAL_RCC_DMA1_CLK_ENABLE();
/* DMA interrupt init */
/* DMA1_Channel4_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA1_Channel4_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(DMA1_Channel4_IRQn);
/* DMA1_Channel5_IRQn interrupt configuration */
HAL_NVIC_SetPriority(DMA1_Channel5_IRQn, 5, 0);
HAL_NVIC_EnableIRQ(DMA1_Channel5_IRQn);
* @brief GPIO Initialization Function
* @param None
* @retval None
static void MX_GPIO_Init(void)
GPIO_InitTypeDef GPIO_InitStruct = {0};
/* GPIO Ports Clock Enable */
__HAL_RCC_GPIOC_CLK_ENABLE();
__HAL_RCC_GPIOA_CLK_ENABLE();
__HAL_RCC_GPIOB_CLK_ENABLE();
/*Configure GPIO pin Output Level */
HAL_GPIO_WritePin(GPIOB, LED_G_Pin|LED_B_Pin|LED_R_Pin, GPIO_PIN_SET);
/*Configure GPIO pin : KEY2_Pin */
GPIO_InitStruct.Pin = KEY2_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
GPIO_InitStruct.Pull = GPIO_NOPULL;
HAL_GPIO_Init(KEY2_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pin : KEY1_Pin */
GPIO_InitStruct.Pin = KEY1_Pin;
HAL_GPIO_Init(KEY1_GPIO_Port, &GPIO_InitStruct);
/*Configure GPIO pins : LED_G_Pin LED_B_Pin LED_R_Pin */
GPIO_InitStruct.Pin = LED_G_Pin|LED_B_Pin|LED_R_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOB, &GPIO_InitStruct);
/* USER CODE BEGIN 4 */
* @brief 重定向c库函数printf到USARTx
* @retval None
int fputc(int ch, FILE *f)
HAL_UART_Transmit(&huart1, (uint8_t *)&ch, 1, 0xffff);
return ch;
* @brief 重定向c库函数getchar,scanf到USARTx
* @retval None
int fgetc(FILE *f)
uint8_t ch = 0;
HAL_UART_Receive(&huart1, &ch, 1, 0xffff);
return ch;
/* USER CODE END 4 */
/* USER CODE BEGIN Header_StartDefaultTask */
* @brief Function implementing the defaultTask thread.
* @param argument: Not used
* @retval None
/* USER CODE END Header_StartDefaultTask */
void StartDefaultTask(void const * argument)
/* USER CODE BEGIN 5 */
/* Infinite loop */
for(;;)
osDelay(1);
/* USER CODE END 5 */
/* USER CODE BEGIN Header_LowPriorityTask */
* @brief Function implementing the LowPriority thread.
* @retval None
/* USER CODE END Header_LowPriorityTask */
void LowPriorityTask(void const * argument)
/* USER CODE BEGIN LowPriorityTask */
static uint32_t i;
osStatus xReturn;
/* Infinite loop */
for(;;)
printf('LowPriority_Task Get Mutexn');
//获取互斥量 MuxSem,没获取到则一直等待
xReturn = osMutexWait(MuxSemHandle, /* 互斥量句柄 */
osWaitForever); /* 等待时间 */
if(osOK == xReturn)
printf('LowPriority_Task Runingnn');
for(i = 0; i < 2000000; i++)
{ //模拟低优先级任务占用互斥量
taskYIELD();//发起任务调度
printf('LowPriority_Task Release Mutexrn');
xReturn = osMutexRelease(MuxSemHandle);//给出互斥量
osDelay(1000);
/* USER CODE END LowPriorityTask */
/* USER CODE BEGIN Header_MidPriorityTask */
* @brief Function implementing the MidPriority thread.
* @retval None
/* USER CODE END Header_MidPriorityTask */
void MidPriorityTask(void const * argument)
/* USER CODE BEGIN MidPriorityTask */
/* Infinite loop */
for(;;)
printf('MidPriority_Task Runingn');
osDelay(1000);
/* USER CODE END MidPriorityTask */
/* USER CODE BEGIN Header_HighPriorityTask */
* @brief Function implementing the HighPriority thread.
* @retval None
/* USER CODE END Header_HighPriorityTask */
void HighPriorityTask(void const * argument)
/* USER CODE BEGIN HighPriorityTask */
osStatus xReturn;
/* Infinite loop */
for(;;)
printf('HighPriority_Task Get Mutexn');
if(osOK == xReturn)
printf('HighPriority_Task Runingn');
printf('HighPriority_Task Release Mutexrn');
osDelay(1000);
/* USER CODE END HighPriorityTask */
* @brief Period elapsed callback in non blocking mode
* @note This function is called when TIM1 interrupt took place, inside
* HAL_TIM_IRQHandler(). It makes a direct call to HAL_IncTick() to increment
* a global variable 'uwTick' used as application time base.
* @param htim : TIM handle
* @retval None
上一篇:STM32CubeMX学习笔记(33)——FreeRTOS实时操作系统使用(软件定时器)
下一篇:STM32CubeMX学习笔记(30)——FreeRTOS实时操作系统使用(信号量)
推荐阅读最新更新时间:2026-03-06 09:24
- LT3973HDD-5 5V、2MHz 降压转换器的典型应用
- 具有抑制功能的TS2938 500mA超低压差稳压器典型应用
- R_53_V10基于IPS2电机换向传感器的设计
- 使用 Analog Devices 的 LTC7851EUHH 的参考设计
- 使用 ON Semiconductor 的 CAT871-05ULGT3 的参考设计
- 用于开/关控制应用的 AM2G-2403SZ 3.3V 2 瓦 DC-DC 转换器的典型应用
- 使用 Analog Devices 的 LT3470HDDB 的参考设计
- LT3088EST 宽安全工作区电源的典型应用
- 简单的 78K/V850/LPC 编程器
- LT1949 的典型应用 - 600kHz、1A 开关 PWM DC/DC 转换器
Azure RTOS ThreadX内核用户手册,含SMP多核(中文版)
基于开发板frdmmcxn947利用lwip_httpsrv_freertos程序开发
非常经典的关于LLC的杨波博士论文
XC6406PP60DL
京公网安备 11010802033920号
