STM32: gcc下printf重定向
发布者:幸福的家园最新更新时间:2025-02-07 来源: jianshu关键字:STM32  gcc  printf重定向 手机看文章 扫描二维码
随时随地手机看文章
1. 创建工程
用cubemx创建一个工程makefile工程。记得开串口
2. 重定向
在main.c对printf重定向,增加如下代码
#ifdef __GNUC__
/* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
   set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
 * @brief  Retargets the C library printf function to the USART.
 * @param  None
 * @retval None
PUTCHAR_PROTOTYPE
    /* Place your implementation of fputc here */
    /* e.g. write a character to the USART1 and Loop until the end of transmission */
    HAL_UART_Transmit(&huart1, (uint8_t *)&ch, 1, 0xFFFF);
    return ch;
3. syscalls.c
很多网上的资料只提到了上一步,忽视了需要加入syscalls.c文件。
在cubemx的仓库目录下找到文件'C:UsersxxxSTM32CubeRepositorySTM32Cube_FW_H7_V1.11.1ProjectsSTM32H743I-EVALExamplesUARTUART_PrintfSTM32CubeIDEExampleUsersyscalls.c'
复制syscalls.c到工程中,并在makefile中加入syscalls.c。
/* Support files for GNU libc.  Files in the system namespace go here.
   Files in the C namespace (ie those that do not start with an
   underscore) go in .c.  */
#include <_ansi.h>
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#include
#define FreeRTOS
#define MAX_STACK_SIZE 0x200
extern int __io_putchar(int ch) __attribute__((weak));
extern int __io_getchar(void) __attribute__((weak));
#ifndef FreeRTOS
register char *stack_ptr asm('sp');
#endif
caddr_t _sbrk(int incr)
    extern char end asm('end');
    static char *heap_end;
    char *prev_heap_end, *min_stack_ptr;
    if (heap_end == 0)
        heap_end = &end;
    prev_heap_end = heap_end;
#ifdef FreeRTOS
    /* Use the NVIC offset register to locate the main stack pointer. */
    min_stack_ptr = (char *)(*(unsigned int *)*(unsigned int *)0xE000ED08);
    /* Locate the STACK bottom address */
    min_stack_ptr -= MAX_STACK_SIZE;
    if (heap_end + incr > min_stack_ptr)
#else
    if (heap_end + incr > stack_ptr)
#endif
        //      write(1, 'Heap and stack collisionn', 25);
        //      abort();
        errno = ENOMEM;
        return (caddr_t)-1;
    heap_end += incr;
    return (caddr_t)prev_heap_end;
 * _gettimeofday primitive (Stub function)
int _gettimeofday(struct timeval *tp, struct timezone *tzp)
    /* Return fixed data for the timezone.  */
    if (tzp)
        tzp->tz_minuteswest = 0;
        tzp->tz_dsttime = 0;
    return 0;
void initialise_monitor_handles()
int _getpid(void)
    return 1;
int _kill(int pid, int sig)
    errno = EINVAL;
    return -1;
void _exit(int status)
    _kill(status, -1);
    while (1)
int _write(int file, char *ptr, int len)
    int DataIdx;
    for (DataIdx = 0; DataIdx < len; DataIdx++)
        __io_putchar(*ptr++);
    return len;
int _close(int file)
    return -1;
int _fstat(int file, struct stat *st)
    st->st_mode = S_IFCHR;
    return 0;
int _isatty(int file)
    return 1;
int _lseek(int file, int ptr, int dir)
    return 0;
int _read(int file, char *ptr, int len)
    int DataIdx;
        *ptr++ = __io_getchar();
    return len;
int _open(char *path, int flags, ...)
    /* Pretend like we always fail */
    return -1;
int _wait(int *status)
    errno = ECHILD;
    return -1;
int _unlink(char *name)
    errno = ENOENT;
    return -1;
int _times(struct tms *buf)
    return -1;
int _stat(char *file, struct stat *st)
    return 0;
int _link(char *old, char *new)
    errno = EMLINK;
    return -1;
int _fork(void)
    errno = EAGAIN;
    return -1;
int _execve(char *name, char **argv, char **env)
    errno = ENOMEM;
    return -1;
我们需要syscalls.c,是因为syscalls.c中实现了int _write(int file, char *ptr, int len)。
4. 补充
如果需要打印浮点型数据,需要在makefile文件中加入-u_printf_float编译参数。
# LDFLAGS
# link script
LDSCRIPT = STM32H743IITx_FLASH.ld
# libraries
LIBS = -lc -lm -lnosys
LIBDIR =
LDFLAGS = $(MCU) -specs=nano.specs -T$(LDSCRIPT) $(LIBDIR) $(LIBS) -Wl,-Map=$(BUILD_DIR)/$(TARGET).map,--cref -Wl,--gc-sections -u_printf_float
# default action: build all
all: $(BUILD_DIR)/$(TARGET).elf $(BUILD_DIR)/$(TARGET).hex $(BUILD_DIR)/$(TARGET).bin
关键字:STM32  gcc  printf重定向 引用地址:STM32: gcc下printf重定向
上一篇:stm32设置读保护后不运行问题
下一篇:手把手教你玩转蓝牙模块(原理+驱动)
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
