用rpm -qa | grep tftp 检查是否安装tftp服务器
如果没有。tftp:yum install tftp*(yum install xinetd tftp tftp-server)
Tftp的配置文件在 vi /etc/xinetd.d/tftp
修改tftpboot 的属性 chmod 777 -R tftpboot
修改下载路径;
重启:/etc/init.d/xinetd restart
检查tftp是否启动成功:netstat -a | grep tftp
在光盘上安装tftp服务器:
在centos的安装光盘中有RPM安装包,挂在光盘后进入到文件夹,找到相应的安装包。
]# cd /media/
[root@localhost media]# cd centos5-4 i386 DVD/
[root@localhost RHEL_5.1 i386 DVD]# ls
[root@localhost RHEL_5.1 i386 DVD]# cd Centos/
[root@localhost Server]# ls tftp*
tftp-0.42-3.1.i386.rpm tftp-server-0.42-3.1.i386.rpm
执行安装命令
[root@localhost Server]# rpm -ivh tftp-server-0.42-3.1.i386.rpm
warning: tftp-server-0.42-3.1.i386.rpm: Header V3 DSA signature: NOKEY, key ID 37017186
error: Failed dependencies:
xinetd is needed by tftp-server-0.42-3.1.i386
提示需要安装xinetd,找到安装包并安装
[root@localhost Server]# ls xinet*
xinetd-2.3.14-10.el5.i386.rpm
[root@localhost Server]# rpm -ivh xinetd-2.3.14-10.el5.i386.rpm
warning: xinetd-2.3.14-10.el5.i386.rpm: Header V3 DSA signature: NOKEY, key ID 37017186
Preparing... ########################################### [100%]
1:xinetd ########################################### [100%]
再执行安装TFTP命令
1:tftp-server ########################################### [100%]
建立tftp的主工作目录
[root@localhost Server]# mkdir /tftpboot
修改配置文件
[root@localhost Server]# vi /etc/xinetd.d/tftp
主要注意修改的两个地方:
# default: off
# description: The tftp server serves files using the trivial file transfer
# protocol. The tftp protocol is often used to boot diskless
# workstations, download configuration files to network-aware printers,
# and to start the installation process for some operating systems.
service tftp
socket_type = dgram
protocol = udp
wait = yes
user = root
server = /usr/sbin/in.tftpd
server_args = -s /tftpboot
disable = no
per_source = 11
cps = 100 2
flags = IPv4
重启服务
[root@localhost Server]# /etc/init.d/xinetd restart
Stopping xinetd: [FAILED]
Starting xinetd: [ OK ]
查看是否启动
[root@localhost Server]# netstat -a |grep tftp
udp 0 0 *:tftp
上一篇:基于ok6410的韦东山驱动视频简要分析--lcd驱动
下一篇:Centos 上搭建nfs且可挂载到6410开发板
推荐阅读最新更新时间:2026-03-25 13:30
- 用于 7VIN 至 16VIN、1.5V 和 1.2V 输出的 LTM4628EV DC/DC 模块稳压器的典型应用电路
- 使用 Analog Devices 的 LTC3728LIGN 的参考设计
- DER-406 - 适用于 A19 灯的 5.76 W 高 PF 非隔离降压-升压型 TRIAC 调光 LED 驱动器
- ADR5045B 5V 输出精密微功率并联模式电压基准的典型应用
- LT3970EDDB-3.42 2.5V 降压转换器的典型应用
- MC78M08BDTG 8V 电流调节器的典型应用
- LT1021DCN8-5 精密电压基准的典型应用
- DER-282 - 100W, 扁平(11 mm), LLC DC-DC转换器
- REF193 低压差开尔文连接电压基准的典型应用电路
- LT3088EM 线性稳压器用于添加软启动的典型应用
Linux p7zip源码安装包
网络可编程性与自动化_第二版(英文版)
现代雷达系统的信号设计
BFR340T
京公网安备 11010802033920号
