static irqreturn_t pm_interrupt(struct serio *serio,
unsigned char data, unsigned int flags)
struct pm *pm = serio_get_drvdata(serio);
struct input_dev *dev = pm->dev;
pm->data[pm->idx] = data;
if (pm->data[0] & 0x80) {
if (PM_MAX_LENGTH == ++pm->idx) {
//input_report_abs(dev, ABS_X, pm->data[2] * 128 + pm->data[1]);
//input_report_abs(dev, ABS_Y, pm->data[4] * 128 + pm->data[3]);
input_report_abs(dev, ABS_Y, pm->data[1] * 128 + pm->data[2]);
input_report_abs(dev, ABS_X, pm->data[3] * 128 + pm->data[4]);
input_report_key(dev, BTN_TOUCH, !!(pm->data[0] & 0x40));
input_sync(dev);
pm->idx = 0;
return IRQ_HANDLED;
在驱动中如做上修改。
并在应用中加入如下文件:
Copyright: 2013, Tkai
File name: penmount_init.c
Description: 将串口属性由TTY改为M_MOUSE
Author: 陆晓来
Version: v1.0
Date: 2013.3.15
History: 无
#include 'stdio.h'
#include 'stdlib.h'
#include 'sys/ioctl.h'
#include 'sys/stat.h'
#include 'unistd.h'
#include 'fcntl.h'
#include 'termios.h'
#include 'errno.h'
#include '/opt/OMAP3530/linux-03.00.01.06/include/linux/tty.h' //根据内核目录修改
#include '/opt/OMAP3530/linux-03.00.01.06/include/linux/serio.h'//根据内核目录修改
#define SERIO_ANY 0xff
#define device '/dev/ttyS0' //根据实际使用串口资源修改
Function: setLine()
Description: 设置串口参数
Calls: NULL
Called By: main()
Input: fd->串口文件操作符,flags->数据位数,speed->波特率
Output: NULL
Return: void
Others: NULL
static void setLine(int fd, int flags, int speed)
struct termios t;
tcgetattr(fd, &t);
t.c_cflag = flags | CREAD | HUPCL | CLOCAL;
t.c_iflag = IGNBRK | IGNPAR;
t.c_oflag = 0;
t.c_lflag = 0;
t.c_cc[VMIN ] = 1;
t.c_cc[VTIME] = 0;
cfsetispeed(&t, speed);
cfsetospeed(&t, speed);
tcsetattr(fd, TCSANOW, &t);
Function: main()
Description: 主函数,打开串口设置参数并改变属性
Calls: setLine()
Called By: NULL
Input: void
Output: NULL
Return: 执行成功返回整数0,其它返回-1
Others: NULL
int main(void)
int fd;
fd = open(device, O_RDWR | O_NOCTTY | O_NONBLOCK);
if (fd < 0)
fprintf(stderr, 'inputattach: '%s' - %sn',
device, strerror(errno));
return -1;
setLine(fd, CS8, B9600);
int ldisc = N_MOUSE;
if (ioctl(fd, TIOCSETD, &ldisc))
fprintf(stderr, 'inputattach: can't set line disciplinen');
return -1;
unsigned long devt = SERIO_PENMOUNT|(SERIO_ANY << 8)|(SERIO_ANY << 16);
if (ioctl(fd, SPIOCSTYPE, &devt))
fprintf(stderr, 'inputattach: can't set device typen');
return -1;
read(fd,NULL,0);
return 0;
上一篇:linux 简单的DMA例程
下一篇:ioctl和unlock_ioctl的区别
- 热门资源推荐
- 热门放大器推荐
- LT3467AIS6 5V 至 40V 升压转换器的典型应用
- LT6654AHS6-1.25 八路 DAC 电压基准的典型应用
- EVAL-CN0272-SDPZ、2MHz 带宽 PIN 光电二极管前置放大器,具有基于 AD8065 的暗电流补偿评估板
- 使用 Analog Devices 的 LT1109CN8 的参考设计
- 使用 ROHM Semiconductor 的 BD48L48G-TL 的参考设计
- LTC3220 演示板、360mA 通用 18 通道 LED 驱动器
- AD8556CP-EBZ,用于 AD8556 零漂移、数字可编程传感器信号放大器的评估板
- LTC3633AIFE-1 同步降压型稳压器的典型应用电路
- LT1086IT 电池后备稳压电源的典型应用
- 使用 NXP Semiconductors 的 TDA8932B 的参考设计
现代雷达系统的信号设计
MAX4237EUT+
BFR340T
京公网安备 11010802033920号
