《Linux驱动:s3c2440 lcd 驱动分析--终结篇》
发布者:Heavenly999最新更新时间:2024-07-09 来源: elecfans关键字:Linux驱动  s3c2440  lcd  驱动 手机看文章 扫描二维码
随时随地手机看文章
// HSPW: 一个HSYNC信号的时间宽度
fbinfo->var.left_margin     = S3C2410_LCDCON3_GET_HFPD(mregs->lcdcon3) + 1;
fbinfo->var.right_margin    = S3C2410_LCDCON3_GET_HBPD(mregs->lcdcon3) + 1;
fbinfo->var.hsync_len       = S3C2410_LCDCON4_GET_HSPW(mregs->lcdcon4) + 1;
4.2.3 其他参数设置
fbinfo->fbops           = &s3c2410fb_ops;
fbinfo->flags           = FBINFO_FLAG_DEFAULT;
// 设置调色板
fbinfo->pseudo_palette      = &info->pseudo_pal;
s3c2410fb_ops:
static struct fb_ops s3c2410fb_ops = {
    .owner      = THIS_MODULE,
    .fb_check_var   = s3c2410fb_check_var,
    .fb_set_par = s3c2410fb_set_par,
    .fb_blank   = s3c2410fb_blank,
    .fb_setcolreg   = s3c2410fb_setcolreg,
    .fb_fillrect    = cfb_fillrect,
    .fb_copyarea    = cfb_copyarea,
    .fb_imageblit   = cfb_imageblit,
4.2.4 硬件相关设置(相关寄存器和引脚)
/* Stop the video and unset ENVID if set */
// 设置LCD控制器的lcdcon1寄存器,第0位为0,先失能lcd等设置完其他参数后,需要开启LCD,再使能该位
info->regs.lcdcon1 &= ~S3C2410_LCDCON1_ENVID;
lcdcon1 = readl(S3C2410_LCDCON1);
writel(lcdcon1 & ~S3C2410_LCDCON1_ENVID, S3C2410_LCDCON1);
// 设置GPB0 低电平,即关闭LCD背光,后面需要开启背光
// add by thisway.diy@163.com, for eBlocks
s3c2410_gpio_setpin(S3C2410_GPB0, 0);   // back light control
// 设置调色板数据
for (i = 0; i < 256; i++)
    info->palette_buffer[i] = PALETTE_BUFF_CLEAR;
if (!request_mem_region((unsigned long)S3C24XX_VA_LCD, SZ_1M, 's3c2410-lcd')) {
    ret = -EBUSY;
    goto dealloc_fb;
dprintk('got LCD regionn');
// 设置LCD中断
ret = request_irq(irq, s3c2410fb_irq, IRQF_DISABLED, pdev->name, info);
if (ret) {
    dev_err(&pdev->dev, 'cannot get irq %d - err %dn', irq, ret);
    ret = -EBUSY;
    goto release_mem;
// 使能LCD clk
info->clk = clk_get(NULL, 'lcd');
if (!info->clk || IS_ERR(info->clk)) {
    printk(KERN_ERR 'failed to get lcd clock sourcen');
    ret = -ENOENT;
    goto release_irq;
clk_enable(info->clk);
dprintk('got and enabled clockn');
msleep(1);
/* Initialize video memory */
// 申请frame buff内存并初始化
ret = s3c2410fb_map_video_memory(info);
if (ret) {
    printk( KERN_ERR 'Failed to allocate video RAM: %dn', ret);
    ret = -ENOMEM;
    goto release_clock;
dprintk('got video memoryn');
// 根据s3c2440芯片手册和使用的屏的规格书设置相关寄存器和引脚
ret = s3c2410fb_init_registers(info);
ret = s3c2410fb_check_var(&fbinfo->var, fbinfo);
static int s3c2410fb_init_registers(struct s3c2410fb_info *fbi)
    unsigned long flags;
    /* Initialise LCD with values from haret */
    local_irq_save(flags);
    /* modify the gpio(s) with interrupts set (bjd) */
    // 根据s3c2440芯片手册设置
    // 设置GPC引脚上拉使能 mach_info->gpcup 0xffffffff
    modify_gpio(S3C2410_GPCUP,  mach_info->gpcup,  mach_info->gpcup_mask);
    // 设置GPC引脚为LCD功能 mach_info->gpccon 0xaaaaaaaa -> 1010 1010 1010 1010 1010 1010 1010 1010
    modify_gpio(S3C2410_GPCCON, mach_info->gpccon, mach_info->gpccon_mask);
    // 设置GPD引脚上拉使能  mach_info->gpdup  0xffffffff
    modify_gpio(S3C2410_GPDUP,  mach_info->gpdup,  mach_info->gpdup_mask);
    // 设置GPD引脚为LCD功能 mach_info->gpdcon 0xaaaaaaaa
    modify_gpio(S3C2410_GPDCON, mach_info->gpdcon, mach_info->gpdcon_mask);
    local_irq_restore(flags);
    // 根据s3c2440芯片手册设置
    // lcdcon1: S3C2410_LCDCON1_TFT16BPP | S3C2410_LCDCON1_TFT | S3C2410_LCDCON1_CLKVAL(0x04),
    writel(fbi->regs.lcdcon1, S3C2410_LCDCON1);
    // lcdcon2: S3C2410_LCDCON2_VBPD(1) | S3C2410_LCDCON2_LINEVAL(271) | S3C2410_LCDCON2_VFPD(1) | S3C2410_LCDCON2_VSPW(9)
    writel(fbi->regs.lcdcon2, S3C2410_LCDCON2);
    // lcdcon3: S3C2410_LCDCON3_HBPD(1) |  S3C2410_LCDCON3_HOZVAL(479) |  S3C2410_LCDCON3_HFPD(1)
    writel(fbi->regs.lcdcon3, S3C2410_LCDCON3);
    // lcdcon4: S3C2410_LCDCON4_HSPW(40)
    writel(fbi->regs.lcdcon4, S3C2410_LCDCON4);
    // lcdcon5: S3C2410_LCDCON5_FRM565 | S3C2410_LCDCON5_INVVLINE | S3C2410_LCDCON5_INVVFRAME | S3C2410_LCDCON5_PWREN | S3C2410_LCDCON5_HWSWP,
    writel(fbi->regs.lcdcon5, S3C2410_LCDCON5);
    // 根据s3c2440芯片手册设置
    // 设置地址相关寄存器 LCDSADDR1、LCDSADDR2、LCDSADDR3
    s3c2410fb_set_lcdaddr(fbi);
    dprintk('LPCSEL    = 0x%08lxn', mach_info->lpcsel);
    writel(mach_info->lpcsel, S3C2410_LPCSEL);
    dprintk('replacing TPAL %08xn', readl(S3C2410_TPAL));
    // 不使用调色板
    /* ensure temporary palette disabled */
    writel(0x00, S3C2410_TPAL);
#if 0
    /* ghcstop modified */
    s3c2410_gpio_cfgpin(S3C2410_GPC5, S3C2410_GPC5_OUTP); // lcd display enable/disable
    s3c2410_gpio_cfgpin(S3C2410_GPB1, S3C2410_GPB1_OUTP); // back light control
    s3c2410_gpio_cfgpin(S3C2410_GPH6, S3C2410_GPH6_OUTP);
    s3c2410_gpio_pullup(S3C2410_GPC5, 0);
    s3c2410_gpio_pullup(S3C2410_GPB1, 0);
    s3c2410_gpio_pullup(S3C2410_GPH6, 0);
    s3c2410_gpio_setpin(S3C2410_GPC5, 1);
    s3c2410_gpio_setpin(S3C2410_GPH6, 1);
    s3c2410_gpio_setpin(S3C2410_GPB1, 1);
#else
    /* thisway.diy@163.com modify again, for eBlocks */
    s3c2410_gpio_cfgpin(S3C2410_GPB0, S3C2410_GPB0_OUTP); // back light control
    s3c2410_gpio_pullup(S3C2410_GPB0, 0);
    s3c2410_gpio_setpin(S3C2410_GPB0, 1);   // back light control, enable
#endif
    /* probably not required */
    msleep(10);
    // 使能lcd
    /* Enable video by setting the ENVID bit to 1 */
    fbi->regs.lcdcon1 |= S3C2410_LCDCON1_ENVID;
    // 开启背光
    return 0;
五,fbmem字符设备驱动
5.1 驱动加载并初始化
编译进内核,加载
linux-2.6.22.6/drivers/video/Makefile
fb-y                              := fbmem.o fbmon.o fbcmap.o fbsysfs.o
                                     modedb.o fbcvt.o
fb-objs                           := $(fb-y)
linux-2.6.22.6/drivers/video/fbmem.c
subsys_initcall(fbmem_init);
static int __init
fbmem_init(void)
    create_proc_read_entry('fb', 0, NULL, fbmem_read_proc, NULL);
    // 注册字符设备
    if (register_chrdev(FB_MAJOR,'fb',&fb_fops))
        printk('unable to get major %d for fb devsn', FB_MAJOR);
    // 创建设备类 /sys/class/graphics
    fb_class = class_create(THIS_MODULE, 'graphics');
    if (IS_ERR(fb_class)) {
        printk(KERN_WARNING 'Unable to create fb class; errno = %ldn', PTR_ERR(fb_class));
        fb_class = NULL;
    return 0;
5.2 register_framebuffer
int
register_framebuffer(struct fb_info *fb_info)
    int i;
    struct fb_event event;
    struct fb_videomode mode;
    // 最多支持32个fb设备
    if (num_registered_fb == FB_MAX)
        return -ENXIO;
    num_registered_fb++;
    // 从registered_fb中找到一项空的位置,存放本次fb。下标作为次设备号,创建设备节点,以供应用程序使用
    for (i = 0 ; i < FB_MAX; i++)
        if (!registered_fb[i])
            break;
    fb_info->node = i;
    // 创建设备 节点。/dev/fb%d
    fb_info->dev = device_create(fb_class, fb_info->device,
                     MKDEV(FB_MAJOR, i), 'fb%d', i);
    if (IS_ERR(fb_info->dev)) {
        /* Not fatal */
        printk(KERN_WARNING 'Unable to create device for framebuffer %d; errno = %ldn', i, PTR_ERR(fb_info->dev));
        fb_info->dev = NULL;
    } else
        fb_init_device(fb_info);
    if (fb_info->pixmap.addr == NULL) {
        fb_info->pixmap.addr = kmalloc(FBPIXMAPSIZE, GFP_KERNEL);
        if (fb_info->pixmap.addr) {
            fb_info->pixmap.size = FBPIXMAPSIZE;
            fb_info->pixmap.buf_align = 1;
            fb_info->pixmap.scan_align = 1;
            fb_info->pixmap.access_align = 32;
            fb_info->pixmap.flags = FB_PIXMAP_DEFAULT;
    fb_info->pixmap.offset = 0;
    if (!fb_info->pixmap.blit_x)
        fb_info->pixmap.blit_x = ~(u32)0;
    if (!fb_info->pixmap.blit_y)
        fb_info->pixmap.blit_y = ~(u32)0;
    if (!fb_info->modelist.prev || !fb_info->modelist.next)
        INIT_LIST_HEAD(&fb_info->modelist);
    fb_var_to_videomode(&mode, &fb_info->var);
    fb_add_videomode(&mode, &fb_info->modelist);
    registered_fb[i] = fb_info;
    event.info = fb_info;
[1] [2] [3] [4]
关键字:Linux驱动  s3c2440  lcd  驱动 引用地址:《Linux驱动:s3c2440 lcd 驱动分析--终结篇》
上一篇:s3c2440裸机-时钟编程-1-2440时钟体系介绍
下一篇:《Linux驱动:s3c2440 lcd 驱动分析》
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
