mini2440_buttons.c驱动程序解读
发布者:GoldenEclipse最新更新时间:2024-06-28 来源: elecfans关键字:驱动程序 手机看文章 扫描二维码
随时随地手机看文章
#include <linux/module.h>
#include
#include
#include
#include
#include
#include
#include
#include             //中断有关的头文件,request_irq()函数定义在此
#include
#include gpio.h>
#include
#include
#include
#include
#define DEVICE_NAME     'buttons'
struct button_irq_desc {                //定义按键中断结构体
    int irq;
    int pin;
    int pin_setting;
    int number;
    char *name;
#if !defined (CONFIG_QQ2440_BUTTONS)
static struct button_irq_desc button_irqs [] = {
    {IRQ_EINT8 , S3C2410_GPG0 ,  S3C2410_GPG0_EINT8  , 0, 'KEY0'},
    {IRQ_EINT11, S3C2410_GPG3 ,  S3C2410_GPG3_EINT11 , 1, 'KEY1'},
    {IRQ_EINT13, S3C2410_GPG5 ,  S3C2410_GPG5_EINT13 , 2, 'KEY2'},
    {IRQ_EINT14, S3C2410_GPG6 ,  S3C2410_GPG6_EINT14 , 3, 'KEY3'},
    {IRQ_EINT15, S3C2410_GPG7 ,  S3C2410_GPG7_EINT15 , 4, 'KEY4'},
    {IRQ_EINT19, S3C2410_GPG11,  S3C2410_GPG11_EINT19, 5, 'KEY5'},
#else /* means QQ */
    {IRQ_EINT19, S3C2410_GPG11, S3C2410_GPG11_EINT19, 0, 'KEY0'},
    {IRQ_EINT11, S3C2410_GPG3,  S3C2410_GPG3_EINT11,  1, 'KEY1'},
    {IRQ_EINT2,  S3C2410_GPF2,  S3C2410_GPF2_EINT2,   2, 'KEY2'},
    {IRQ_EINT0,  S3C2410_GPF0,  S3C2410_GPF0_EINT0,   3, 'KEY3'},
    {       -1,            -1,                 -1,    4, 'KEY4'},
    {       -1,            -1,                 -1,    5, 'KEY5'},
#endif
static volatile char key_values [] = {'0', '0', '0', '0', '0', '0'};
static DECLARE_WAIT_QUEUE_HEAD(button_waitq);  //声明一个名为button_waitq的等待队列头
static volatile int ev_press = 0; /*中断事件标志,中断服务程序将它置1,tq2440_buttons_read将它清0 */
static irqreturn_t buttons_interrupt(int irq, void *dev_id)   //按键中断服务程序
    struct button_irq_desc *button_irqs = (struct button_irq_desc *)dev_id;
    int down;
    // udelay(0);
    down = !s3c2410_gpio_getpin(button_irqs->pin);  //得到该pin的状态0/1
    if (down != (key_values[button_irqs->number] & 1)) { // Changed
    key_values[button_irqs->number] = '0' + down;
        ev_press = 1;
        wake_up_interruptible(&button_waitq);   //唤醒休眠的进程www.linuxidc.com
    return IRQ_RETVAL(IRQ_HANDLED);
/*应用程序执行open('/dev/buttons',...)系统调用时,s3c24xx_buttons_open函数将
 *被调用,它用来注册6个按键的中断处理程序*/
static int s3c24xx_buttons_open(struct inode *inode, struct file *file)
    int i;
    int err = 0;
    for (i = 0; i < sizeof(button_irqs)/sizeof(button_irqs[0]); i++) {
    if (button_irqs[i].irq < 0) {
        continue;
//注册中断服务程序   irq中断号  buttons_interrupt中断服务程序 IRQ_TYPE_EDGE_BOTH中断触发方式 name 中断名字
        err = request_irq(button_irqs[i].irq, buttons_interrupt, IRQ_TYPE_EDGE_BOTH,
                          button_irqs[i].name, (void *)&button_irqs[i]);
        if (err)
            break;
    if (err) {             //如果发生错误,free掉所有的中断服务程序
        i--;
        for (; i >= 0; i--) {
        continue;
        disable_irq(button_irqs[i].irq);
            free_irq(button_irqs[i].irq, (void *)&button_irqs[i]);
        return -EBUSY;
    ev_press = 1;//标志中断发生了
    return 0;
/*应用程序对设备文件/dev/buttons执行close(...)时,
 *就会调用s3c24xx_buttons_close函数*/
static int s3c24xx_buttons_close(struct inode *inode, struct file *file)
    int i;
    for (i = 0; i < sizeof(button_irqs)/sizeof(button_irqs[0]); i++) {         //设备关闭实际上就是free掉中断服务程序
        continue;
    return 0;
 /*应用程序对设备文件/dev/buttons执行read(...)时,
  *就会调用s3c24xx_buttons_read函数
static int s3c24xx_buttons_read(struct file *filp, char __user *buff, size_t count, loff_t *offp)
    unsigned long err;
    if (!ev_press) {
    if (filp->f_flags & O_NONBLOCK)
        return -EAGAIN;
    else
        /*    __wait_event_interruptible()首先定义并初始化一个wait_queue_t变量__wait,
        *  其中数据为当前进程current,并把__wait入队。
        *  在无限循环中,__wait_event_interruptible()将本进程置为可中断的挂起状态,
        *反复检查condition是否成立,如果成立则退出,如果不成立则继续休眠;
        *条件满足后,即把本进程运行状态置为运行态,并将__wait从等待队列中清除掉,
        *从而进程能够调度运行。如果进程当前有异步信号(POSIX的),则返回-ERESTARTSYS。
        wait_event_interruptible(button_waitq, ev_press);
    ev_press = 0;
    err = copy_to_user(buff, (const void *)key_values, min(sizeof(key_values), count));
    return err ? -EFAULT : min(sizeof(key_values), count);
 /*应用程序对设备文件/dev/buttons执行select(...)时,
  *就会调用s3c24xx_buttons_poll函数,作用:判断设备的可读写状态
static unsigned int s3c24xx_buttons_poll( struct file *file, struct poll_table_struct *wait)
    unsigned int mask = 0;
    poll_wait(file, &button_waitq, wait);
    if (ev_press)
        mask |= POLLIN | POLLRDNORM;
    return mask;
 /*这个结构是字符驱动设备程序的核心www.linuxidc.com
  *当应用程序操作设备文件时所调用的open,read,write等函数
  *最终会调用这个结构中的对应函数
static struct file_operations dev_fops = {     //定义dev_fops结构
    .owner   =   THIS_MODULE,                  /*这是一个宏,指向编译模块时自动创建的__this_module变量*/
    .open    =   s3c24xx_buttons_open,
    .release =   s3c24xx_buttons_close,
    .read    =   s3c24xx_buttons_read,
    .poll    =   s3c24xx_buttons_poll,
static struct miscdevice misc = {        //定义名为misc的混杂设备
    .minor = MISC_DYNAMIC_MINOR,
    .name = DEVICE_NAME,
    .fops = &dev_fops,
static int __init dev_init(void)
    int ret;
    ret = misc_register(&misc);      //注册misc混杂设备
    printk (DEVICE_NAME'tinitializedn');
    return ret;
static void __exit dev_exit(void)
    misc_deregister(&misc);          //注销misc混杂设备
module_init(dev_init);
module_exit(dev_exit);
MODULE_LICENSE('GPL');
MODULE_AUTHOR('FriendlyARM Inc.');
[1] [2]
关键字:驱动程序 引用地址:mini2440_buttons.c驱动程序解读
上一篇:Mini2440 按键驱动程序学习笔记
下一篇:micro2440利用LEDS与BUTTONS驱动实现按键控制led灯【开发总结】
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
