IMX6ULL - Linux根文件系统(rootfs)构建
发布者:RadiantBreeze最新更新时间:2025-02-28 来源: cnblogs关键字:Linux  根文件系统  rootfs 手机看文章 扫描二维码
随时随地手机看文章
一、Ubuntu-base20.04.3
Ubuntu官方已经制作好了各架构、各版本的base版根文件系统,只需下载下来做少许改动即可。
下载Ubuntu Base 20.04.3 LTS (Focal Fossa)
ubuntu-base-20.04.3-base-armhf.tar.gz 2021-08-19 10:56 22M
解压
mkdir rootfs
sudo chmod 777 rootfs
tar -zxvf ubuntu-base-20.04.3-base-armhf.tar.gz -C rootfs
#避免后面更新软件报错
sudo chmod 777 ./rootfs/tmp/
安装工具
sudo apt-get install qemu-user-static
sudo cp /usr/bin/qemu-arm-static ./rootfs/usr/bin/
拷贝主机DNS
sudo cp /etc/resolv.conf ./rootfs/etc/resolv.conf
更换下载源
cp ./rootfs/etc/apt/source.list ./rootfs/etc/apt/source.list.bak
vim ./rootfs/etc/apt/source.list
`Esc` + `:`
%s/ports.ubuntu.com/mirror.tuna.tsinghua.edu.cn/g
`Enter`
创建挂载脚本vim mount.sh
内容如下:
#!/bin/bash
mnt() {
echo 'MOUNTING'
sudo mount -t proc /proc ${2}proc
sudo mount -t sysfs /sys ${2}sys
sudo mount -o bind /dev ${2}dev
sudo mount -o bind /dev/pts ${2}dev/pts
sudo chroot ${2}
umnt() {
echo 'UNMOUNTING'
sudo umount ${2}proc
sudo umount ${2}sys
sudo umount ${2}dev/pts
sudo umount ${2}dev
if [ '$1' == '-m' ] && [ -n '$2' ] ;
then
mnt $1 $2
elif [ '$1' == '-u' ] && [ -n '$2' ];
then
umnt $1 $2
else
echo ''
echo 'Either 1'st, 2'nd or both parameters were missing'
echo ''
echo '1'st parameter can be one of these: -m(mount) OR -u(umount)'
echo '2'nd parameter is the full path of rootfs directory(with trailing '/')'
echo ''
echo 'For example: ch-mount -m /media/sdcard/'
echo ''
echo 1st parameter : ${1}
echo 2nd parameter : ${2}
fi
更改权限:
sudo chmod +x mount.sh
挂载
source mount.sh -m ./rootfs/
更新软件
apt update
apt install sudo vim kmod net-tools ethtool ifupdown rsyslog htop iputils-ping language-pack-en-base ssh
注意:ssh必须安装,不然后面链接串口服务会出错
设置用户名和密码
root@zsd-virtual-machine:/# passwd root
New password:
Retype new password:
passwd: password updated successfully
root@zsd-virtual-machine:/# adduser zsd
New password:
`Enter`
`Enter`
`Enter`
`Enter`
设置IP和名称
root@zsd-virtual-machine:/# echo 'zzssdd2-imx6ull' > /etc/hostname
root@zsd-virtual-machine:/# echo '127.0.0.1 localhost' >> /etc/hosts
root@zsd-virtual-machine:/# echo '127.0.0.1 zzssdd2-imx6ull' >> /etc/hosts
设置串口终端
ln -s /lib/systemd/system/getty@.service /etc/systemd/system/getty.target.wants/getty@ttymxc0.service
注意:
如果提示报错提示如下:
root@zsd-virtual-machine:/# ln -s /lib/systemd/system/getty@.service /etc/systemd/system/getty.target.wants/getty@ttymxc0.service
/usr/bin/ln: failed to create symbolic link '/etc/systemd/system/getty.target.wants/getty@ttymxc0.service': No such file or directory
说明/etc/systemd/system/目录下没有getty.target.wants目录。
解决方法:安装ssh会创建该目录,然后重新执行一遍设置串口终端命令即可。
退出
#退出qemu模拟器
exit
#取消挂载
source mount.sh -u ./rootfs/
#打包
sudo tar -czvf ubuntu-base-20.04.3-rootfs.tar.gz rootfs/*
二、Debian 11
直接使用三方制作好的Debian根文件系统,比如Linaro
使用Multistrap或Debootstrap工具构建自己的Debian根文件系统
下面我使用debootstrap工具构建Debian11根文件系统(别问为什么不用multistrap,问就是不会︶︹︺)
安装工具
sudo apt install binfmt-support qemu qemu-user-static debootstrap
抽取Debain文件系统
sudo debootstrap --arch=armhf --foreign bullseye rootfs https://mirrors.tuna.tsinghua.edu.cn/debian/
参数说明:
arch:CPU架构
bullseye:debian版本名,这是版本11的名称
foreign:在与主机架构不相同时需要指定此参数,仅做初始化的解包
rootfs:要存放文件系统的文件夹
https://mirrors.tuna.tsinghua.edu.cn/debian/:下载源,这里使用国内的清华源
抽取成功后如下:
$ ls ./rootfs/
bin   debootstrap  etc   lib   root  sbin  tmp  var
boot  dev          home  proc  run   sys   usr
复制qemu-arm-static到刚构建的基本系统中
完成文件系统引导
sudo DEBIAN_FRONTEND=noninteractive DEBCONF_NONINTERACTIVE_SEEN=true chroot rootfs debootstrap/debootstrap --second-stage
参数说明:
chroot rootfs
更改根目录为rootfs:就是变更当前进程及其子进程的可见根路径。变更后,程序无法访问可见根目录外文件和命令。
避免debconf向用户询问任何问题(非交互式),相当于是静默配置安装。
了解更多debconf - Debian Wiki
debootstrap
man debootstrap
debootstrap --help
了解更多Debootstrap - Debian Wiki
完成后提示如下:
I: Base system installed successfully.
更换下载源
#备份
sudo cp ./rootfs/etc/apt/sources.list ./rootfs/etc/apt/sources.list.bak
#编辑
sudo vim ./rootfs/etc/apt/sources.list
#换成如下内容:
# 默认注释了源码镜像以提高 apt update 速度,如有需要可自行取消注释
deb https://mirrors.tuna.tsinghua.edu.cn/debian/ bullseye main contrib non-free
# deb-src https://mirrors.tuna.tsinghua.edu.cn/debian/ bullseye main contrib non-free
deb https://mirrors.tuna.tsinghua.edu.cn/debian/ bullseye-updates main contrib non-free
# deb-src https://mirrors.tuna.tsinghua.edu.cn/debian/ bullseye-updates main contrib non-free
deb https://mirrors.tuna.tsinghua.edu.cn/debian/ bullseye-backports main contrib non-free
# deb-src https://mirrors.tuna.tsinghua.edu.cn/debian/ bullseye-backports main contrib non-free
deb https://mirrors.tuna.tsinghua.edu.cn/debian-security bullseye-security main contrib non-free
# deb-src https://mirrors.tuna.tsinghua.edu.cn/debian-security bullseye-security main contrib non-free
创建挂载脚本vim mount.sh
内容如下:
#!/bin/bash
mnt() {
echo 'MOUNTING'
sudo chroot ${2}
umnt() {
echo 'UNMOUNTING'
sudo umount ${2}sys
sudo umount ${2}dev
then
mnt $1 $2
then
umnt $1 $2
else
echo ''
echo ''
echo ''
echo ''
fi
更改权限:
挂载
执行以下命令
echo 'proc /proc proc defaults 0 0' >> etc/fstab
设置Linux中的locale环境参数
export LC_ALL=C
如果不设置在后面安装软件时会有如下提示:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = 'zh_CN:en_US:en',
LC_ALL = (unset),
LC_PAPER = 'zh_CN.UTF-8',
LC_NUMERIC = 'zh_CN.UTF-8',
LC_IDENTIFICATION = 'zh_CN.UTF-8',
LC_MEASUREMENT = 'zh_CN.UTF-8',
LC_NAME = 'zh_CN.UTF-8',
LC_TELEPHONE = 'zh_CN.UTF-8',
LC_ADDRESS = 'zh_CN.UTF-8',
LC_MONETARY = 'zh_CN.UTF-8',
LC_TIME = 'zh_CN.UTF-8',
LANG = 'zh_CN.UTF-8'
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ('C').
/usr/bin/locale: Cannot set LC_CTYPE to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_MESSAGES to default locale: No such file or directory
/usr/bin/locale: Cannot set LC_ALL to default locale: No such file or directory
安装软件
apt update
apt install sudo
apt install net-tools
apt install ethtool
apt install htop
apt install ssh
设置用户
#设置root用户密码
passwd root
#添加新用户
adduser zzssdd2
设置以太网
echo 'auto eth0' > /etc/network/interfaces.d/eth0
echo 'iface eth0 inet dhcp' >> /etc/network/interfaces.d/eth0
设置IP和名称
退出
#退出qemu环境
exit
# 取消挂载
#打包
sudo tar -zcvf debian_bullseye-rootfs.tar.gz ./rootfs/*
三、Buildroot
Buildroot是一个简单、高效且易于使用的工具,可以通过交叉编译生成嵌入式Linux系统。更详细的了解参考官方手册The Buildroot user manual
下面使用buildroot-2021.08.1版本对IMX6ULL平台进行配置。
下载:https://buildroot.org/download.html
解压 :tar -jxvf buildroot-2021.08.1.tar.bz2
进入图形配置界面:make menuconfig
注:下面贴出来的都是经过手动配置更改的选项,没有贴出来的则表示使用默认设置
配置Target options
Target options  --->
Target Architecture (ARM (little endian))
Target Binary Format (ELF)
Target Architecture Variant (cortex-A7)
Target ABI (EABIhf)
Floating point strategy (NEON/VFPv4)
ARM instruction set (ARM)
配置Toolchain
Toolchain  --->
Toolchain type (External toolchain)
Toolchain (Custom toolchain)
Toolchain origin (Pre-installed toolchain)
(/usr/local/arm/gcc-arm-10.3-2021.07-x86_64-arm-none-linux-gnueabihf) Toolchain path
($(ARCH)-none-linux-gnueabihf) Toolchain prefix
    External toolchain gcc version (10.x)
    External toolchain kernel headers series (4.20.x)
    External toolchain C library (glibc/eglibc)
    [ ] Toolchain has RPC support?
    [*] Toolchain has C++ support?
配置System configuration
System configuration  --->
(zzssdd2) System hostname
(Hello zzssdd2) System banner
/dev management (Dynamic using devtmpfs + mdev)
(root) Root password
(eth0) Network interface to configure through DHCP
配置Target packages
这一步根据自己的需求选择安装需要的包即可(这里为了下一步编译快一些我保持默认选择)。
按需配置完成后:Save --> Exit --> 执行make命令等待编译完成后在Buildroot根目录下的output/images目录下可以看到编译好的根文件系统。
注意:
如果编译之前执行过make则需要先执行make clean清理一下再执行make命令,否则可能报错。
如果遇到某些包下载巨慢、下不动、下载失败的情况,可以根据编译信息提示的地址复制到浏览器手动下载。下载下来后将其复制到Buildroot根目录下的dl目录下,然后CTRL+C终止编译 --> make clean清除上次编译 --> make重新编译。
四、验证
参考开发板直连电脑搭建NFS&TFTP环境第四节
关键字:Linux  根文件系统  rootfs 引用地址:IMX6ULL - Linux根文件系统(rootfs)构建
上一篇:IMX6ULL - 移植linux-imx_5.4.70_2.3.0
下一篇:【IMX6ULL学习笔记】十九、Pinctrl、GPIO驱动驱动框架
小广播
最新单片机文章
何立民专栏 单片机及嵌入式宝典
厂商技术中心
