开发板是飞凌OK210
arch/arm/mach-s5pv210/mach-smdkc110.c
首先是UART的寄存器默认配置信息:
/* Following are default values for UCON, ULCON and UFCON UART registers */
#define S5PV210_UCON_DEFAULT (S3C2410_UCON_TXILEVEL |
S3C2410_UCON_RXILEVEL |
S3C2410_UCON_TXIRQMODE |
S3C2410_UCON_RXIRQMODE |
S3C2410_UCON_RXFIFO_TOI |
S3C2443_UCON_RXERR_IRQEN)
#define S5PV210_ULCON_DEFAULT S3C2410_LCON_CS8
#define S5PV210_UFCON_DEFAULT (S3C2410_UFCON_FIFOMODE |
S5PV210_UFCON_TXTRIG4 |
S5PV210_UFCON_RXTRIG4)
static struct s3c2410_uartcfg smdkc110_uartcfgs[] __initdata = {
.hwport = 0,
.flags = 0,
.ucon = S5PV210_UCON_DEFAULT,
.ulcon = S5PV210_ULCON_DEFAULT,
.ufcon = S5PV210_UFCON_DEFAULT,
.hwport = 1,
.flags = 0,
#ifndef CONFIG_FIQ_DEBUGGER
.hwport = 2,
.flags = 0,
#endif
.hwport = 3,
.flags = 0,
下面是添加platform device的具体过程:
1.
/*调用MACHINE_START宏
MACHINE_START和MACHINE_END框起了一个machine_desc结构体的声明并根据MACHINE_START宏的参数初始化其.nr和.name成员
并将该结构体标记编译到.arch.info.init段
在MACHINE_START和MACHINE_END宏之间可以初始化machine_desc结构体的剩余成员
#ifdef CONFIG_MACH_SMDKC110
MACHINE_START(SMDKC110, 'SMDKC110')
#elif CONFIG_MACH_SMDKV210
MACHINE_START(SMDKV210, 'SMDKV210')
#endif
/* Maintainer: Kukjin Kim .phys_io = S3C_PA_UART & 0xfff00000, .io_pg_offst = (((u32)S3C_VA_UART) >> 18) & 0xfffc, .boot_params = S5P_PA_SDRAM + 0x100, .init_irq = s5pv210_init_irq,//板级中断初始化函数 .map_io = smdkc110_map_io,//板级io初始化函数 .init_machine = smdkc110_machine_init,//板级初始化函数 .timer = &s5p_systimer, MACHINE_END 2. static void __init smdkc110_map_io(void) { s5p_init_io(NULL, 0, S5P_VA_CHIPID); s3c24xx_init_clocks(24000000); s5pv210_gpiolib_init(); s3c24xx_init_uarts(smdkc110_uartcfgs, ARRAY_SIZE(smdkc110_uartcfgs)); s5p_reserve_bootmem(smdkc110_media_devs, ARRAY_SIZE(smdkc110_media_devs)); #ifdef CONFIG_MTD_ONENAND s5pc110_device_onenand.name = 's5pc110-onenand'; #endif #ifdef CONFIG_MTD_NAND s3c_device_nand.name = 's5pv210-nand'; #endif s5p_device_rtc.name = 'smdkc110-rtc'; } 3. /* table of supported CPUs */ static struct cpu_table cpu_ids[] __initdata = { { .idcode = 0x43110000, .idmask = 0xfffff000, .map_io = s5pv210_map_io, .init_clocks = s5pv210_init_clocks, .init_uarts = s5pv210_init_uarts, .init = s5pv210_init, .name = name_s5pv210, }, }; arch/arm/plat-samsung/init.c void __init s3c24xx_init_uarts(struct s3c2410_uartcfg *cfg, int no) { if (cpu == NULL) return; if (cpu->init_uarts == NULL) { printk(KERN_ERR 's3c24xx_init_uarts: cpu has no uart initn'); } else (cpu->init_uarts)(cfg, no);//这里最终会调用上面的s5pv210_init_uarts } 4. #define s5pv210_init_uarts s5pv210_common_init_uarts /* uart registration process */ void __init s5pv210_common_init_uarts(struct s3c2410_uartcfg *cfg, int no) { struct s3c2410_uartcfg *tcfg = cfg; u32 ucnt; for (ucnt = 0; ucnt < no; ucnt++, tcfg++) { if (!tcfg->clocks) { tcfg->clocks = s5pv210_serial_clocks; tcfg->clocks_size = ARRAY_SIZE(s5pv210_serial_clocks); } } s3c24xx_init_uartdevs('s5pv210-uart', s5p_uart_resources, cfg, no); } 5. arch/arm/plat-samsung/init.c void __init s3c24xx_init_uartdevs(char *name, struct s3c24xx_uart_resources *res, struct s3c2410_uartcfg *cfg, int no) { struct platform_device *platdev; struct s3c2410_uartcfg *cfgptr = uart_cfgs; struct s3c24xx_uart_resources *resp; int uart; memcpy(cfgptr, cfg, sizeof(struct s3c2410_uartcfg) * no); for (uart = 0; uart < no; uart++, cfg++, cfgptr++) { platdev = s3c24xx_uart_src[cfgptr->hwport]; resp = res + cfgptr->hwport; s3c24xx_uart_devs[uart] = platdev; platdev->name = name; platdev->resource = resp->resources; platdev->num_resources = resp->nr_resources; platdev->dev.platform_data = cfgptr;//将cfg挂到platdev->dev.platform_data上 } nr_uarts = no; } static int __init s3c_arch_init(void) { int ret; // do the correct init for cpu if (cpu == NULL) panic('s3c_arch_init: NULL cpun'); ret = (cpu->init)(); if (ret != 0) return ret; ret = platform_add_devices(s3c24xx_uart_devs, nr_uarts); return ret; } arch_initcall(s3c_arch_init);
上一篇:点亮指路灯
下一篇:ARM-Linux S5PV210 UART驱动(5)----串口的open操作(tty_open、uart_open)
推荐阅读最新更新时间:2026-03-25 11:22
- 用于 7VIN 至 16VIN、1.5V 和 1.2V 输出的 LTM4628EV DC/DC 模块稳压器的典型应用电路
- 使用 Analog Devices 的 LTC3728LIGN 的参考设计
- DER-406 - 适用于 A19 灯的 5.76 W 高 PF 非隔离降压-升压型 TRIAC 调光 LED 驱动器
- ADR5045B 5V 输出精密微功率并联模式电压基准的典型应用
- LT3970EDDB-3.42 2.5V 降压转换器的典型应用
- MC78M08BDTG 8V 电流调节器的典型应用
- LT1021DCN8-5 精密电压基准的典型应用
- DER-282 - 100W, 扁平(11 mm), LLC DC-DC转换器
- REF193 低压差开尔文连接电压基准的典型应用电路
- LT3088EM 线性稳压器用于添加软启动的典型应用
MAX32625 PICO 嵌入式程序
智能机械臂
现代雷达系统的信号设计
5962-89541022A
BFR340T
京公网安备 11010802033920号
