平台:smart210(tiny210v2)
CPU:S5PV210
目标:led灯按照一定频率闪烁
1.代码如下(如果不能编译,请去掉注释):
.globl _start
_start:
ldr r1, =0xE0200280 //config the GPJ2CON[0to15] as output
ldr r0, =0x00001111
str r0, [r1]
mov r2, #0x1000 //r2=8
led_blink:
ldr r1, =0xE0200284 //set the GPJ2DAT[0to3] as 0,4 leds would light on!
mov r0, #0xa
str r0, [r1]
bl delay
ldr r1, =0xE0200284 //set the GPJ2DAT[0to3] as 1,4 leds would light off!
mov r0, #0x5
str r0, [r1]
bl delay
sub r2,r2,#1 //r2=r2-1
cmp r2,#0 //if r2!=0 jump to led_blink
bne led_blink //then the led_blink will turn 8 times
halt:
b halt //while(1)
delay:
mov r0,#0xf000000 //r0=0xf000000
delay_loop:
cmp r0,#0 //if r0=0
sub r0,r0,#1 //r0=r0-1
bne delay_loop //after 'cmp r0,#0' ,if r0!=0 jump to delay_loop
//then the delay_loop will turn 32 times
mov pc,lr //come back the main
2.使用以下命令编译链接与反汇编
arm-linux-gcc -c -o firstled.o firstled.s //对.s文件进行预处理,编译,汇编,生成.o文件
arm-linux-ld -Ttext 0x0 -o led.elf firstled.o //链接.o文件,并设置代码段起始运行地址为0x0 ,生成.elf
arm-linux-objcopy -O binary led.elf led.bin //将.elf文件复制一份,并以二进制.bin形式保存,该形式可在开发板上使用
arm-linux-objdump -D led.elf > led_elf.dis //将.elf文件反汇编成.dis文件,方便调试程序
3.使用以下命令给led.bin添加头部
./mkmini210 led.bin led210.bin
其中,mkmini210由程序mkv210_image.c编译而来,mkv210_image.c内容如下
/* 在BL0阶段,Irom内固化的代码读取nandflash或SD卡前16K的内容,
* 并比对前16字节中的校验和是否正确,正确则继续,错误则停止。*/
#include #include #include #define BUFSIZE (16*1024) #define IMG_SIZE (16*1024) #define SPL_HEADER_SIZE 16 #define SPL_HEADER 'S5PC110 HEADER ' int main (int argc, char *argv[]) { FILE *fp; char *Buf, *a; int BufLen; int nbytes, fileLen; unsigned int checksum, count; int i; // 1. 3个参数 if (argc != 3) { printf('Usage: mkbl1 return -1; } // 2. 分配16K的buffer BufLen = BUFSIZE; Buf = (char *)malloc(BufLen); if (!Buf) { printf('Alloc buffer failed!n'); return -1; } memset(Buf, 0x00, BufLen); // 3. 读源bin到buffer // 3.1 打开源bin fp = fopen(argv[1], 'rb'); if( fp == NULL) { printf('source file open errorn'); free(Buf); return -1; } // 3.2 获取源bin长度 fseek(fp, 0L, SEEK_END); fileLen = ftell(fp); fseek(fp, 0L, SEEK_SET); // 3.3 源bin长度不得超过16K-16byte count = (fileLen < (IMG_SIZE - SPL_HEADER_SIZE)) ? fileLen : (IMG_SIZE - SPL_HEADER_SIZE); // 3.4 buffer[0~15]存放'S5PC110 HEADER ' memcpy(&Buf[0], SPL_HEADER, SPL_HEADER_SIZE); // 3.5 读源bin到buffer[16] nbytes = fread(Buf + SPL_HEADER_SIZE, 1, count, fp); if ( nbytes != count ) { printf('source file read errorn'); free(Buf); fclose(fp); return -1; } fclose(fp); // 4. 计算校验和 // 4.1 从第16byte开始统计buffer中共有几个1 a = Buf + SPL_HEADER_SIZE; for(i = 0, checksum = 0; i < IMG_SIZE - SPL_HEADER_SIZE; i++) checksum += (0x000000FF) & *a++; // 4.2 将校验和保存在buffer[8~15] a = Buf + 8; *( (unsigned int *)a ) = checksum; // 5. 拷贝buffer中的内容到目的bin // 5.1 打开目的bin fp = fopen(argv[2], 'wb'); if (fp == NULL) { printf('destination file open errorn'); free(Buf); return -1; } // 5.2 将16k的buffer拷贝到目的bin中 a = Buf; nbytes = fwrite( a, 1, BufLen, fp); if ( nbytes != BufLen ) { printf('destination file write errorn'); free(Buf); fclose(fp); return -1; } free(Buf); fclose(fp); return 0; } 这段代码完成的工作是: 第一步 分配16k 的buffer; 第二步 将led.bin 读到buffer的第16byte开始的地方; 第三步 计算校验和,并将校验和保存在buffer第8~11byte中; 第四步 将16k 的buffer拷贝到led210.bin 中; 4.下载led210.bin到smart210 这里使用minitools下载.bin文件,操作过程比较简单就不再赘述了 5.运行效果是4个LED交替闪烁,频率约为0.8s左右
上一篇:[smart210] 通过PLL设置各时钟频率的方法以及代码注释
下一篇:s5pv210 I2C通信详解
推荐阅读最新更新时间:2026-02-18 12:23
- 羽毛球训练监测器
- 一种 16 位、300 kSPS 低功耗逐次逼近 ADC 系统,具有用于高达 4 kHz 的亚奈奎斯特输入信号的最佳低功耗驱动放大器
- SY898547 EV,用于 SY89547、2.5V、3.2 Gbps LVDS 多路复用器的评估板,带内部终端
- OP484ESZ-REEL 2.5V 基准的典型应用在单 3V 电源上运行
- NCV3063 1.5A 电压反相稳压器的典型电压反相应用原理图
- 具有欠压锁定功能的 LT3973IDD-3.3 5V 降压转换器的典型应用
- NSI45030ZT1G 单串LED恒流LED驱动器的典型应用
- NCP1587A 低压同步降压控制器的典型应用
- 福禄克早期型号 8020A 万用表原理图
- 使用 Richtek Technology Corporation 的 RT8237C 的参考设计
【Follow me第三季第3期】代码
【Follow me第三季第3期】XIAO ESP32S3任务代码提交
FDCAN 数据段波特率增加后发送失败的问题分析
现代雷达系统的信号设计
BFR340T
京公网安备 11010802033920号
