一、环境
1、开发板
Tiny6410 NAND: 2G RAM: 256M MLC
2、操作系统
Ubuntu10
3、交叉工具编译链
arm-linux-gcc-4.5.1
二、下载内核源码包
linux-2.6.38
三、解压内核
tar –jxvf linux-2.6.38.tar.bz2
我解压的的路径是:
四、NAND FLASH移植
1、修改Makefile
vim Makefile
将约191行改为:
ARCH ? = arm
CROSS_COMPILE ? = arm-linux-
2、cp arch/arm/configs/s3c6400_defconfig .config
忽略这一步的话,后面会找不到System Type
3、make menuconfig
4、添加交叉工具编译链的目录
General setup --->
(/opt/FriendlyARM/toolschain/4.5.1/bin/arm-linux-) Cross-compiler too
System Type --->
[*] MINI6410 (其余的可以去掉)
这样编译出来的内核是可以被uboot引导的,然后是增加nand flash支持
vi arch/arm/mach-s3c64xx/mach-mini6410.c
第117行
struct mtd_partition mini6410_nand_part[] = {
.name = 'Bootloader',
.offset = 0,
.size = (4 * 128 *SZ_1K),
.mask_flags = MTD_CAP_NANDFLASH,
.name = 'Kernel',
.offset = (4 * 128 *SZ_1K),
.size = (5*SZ_1M) ,
.name = 'File System',
.offset = MTDPART_OFS_APPEND,
.size = MTDPART_SIZ_FULL,
}; //update at 2011-8-26 经过测试发现,这里改完后根本不起作用,甚至将整个注释也无妨,估计分区已经固死在后面的s3c_nand_mlc.fo中
拷贝友善光盘的NDND FLASH 驱动
drivers/mtd/nand/s3c_nand.c
arch/arm/plat-samsung/include/plat/regs-nand.h
drivers/mtd/nand/s3c_nand_mlc.fo
然后修改drivers/mtd/nand/Kconfig和drivers/mtd/nand/Makefile文件
在drivers/mtd/nand/Kconfig 238行增加(注意:进格要用Tab键)
config MTD_NAND_S3C
tristate 'NAND Flash support for S3C SoC'
depends on (ARCH_S3C64XX || ARCH_S5P64XX || ARCH_S5PC1XX) && MTD_NAND
help
This enables the NAND flash controller on the S3C.
No board specfic support is done by this driver, each board
must advertise a platform_device for the driver to attach.
config MTD_NAND_S3C_DEBUG
bool 'S3C NAND driver debug'
depends on MTD_NAND_S3C
help
Enable debugging of the S3C NAND driver
configMTD_NAND_S3C_HWECC
bool 'S3C NAND Hardware ECC'
help
Enable the use of the S3C's internal ECC generator when
using NAND. Early versions of the chip have had problems with
incorrect ECC generation, and if using these, the default of
software ECC is preferable.
If you lay down a device with the hardware ECC, then you will
currently not be able to switch to software, as there is no
implementation for ECC method used by the S3C
drivers/mtd/nand/Makefile中20行增加
obj-$(CONFIG_MTD_NAND_S3C) += s3c_nand.o
末尾再增加
S3C_NAND_MLC_SRC = $(shell ls drivers/mtd/nand/s3c_nand_mlc.c 2>/dev/null)
ifeq ($(S3C_NAND_MLC_SRC),)
obj-$(CONFIG_MTD_NAND_S3C) += s3c_nand_mlc.fo
else
obj-$(CONFIG_MTD_NAND_S3C) += s3c_nand_mlc.o
endif
然后再make menuconfig
Device Drivers--->
<*> Memory Technology Device (MTD) support --->
[*] MTD partitioning support
[*] Command line partition table parsing
<*> Direct char device access to MTD devices
<*> Caching block device access to MTD devices
<*> NAND Device Support --->
< > NAND Flash support for Samsung S3C SoCs 去掉不要选
<*> NAND Flash support for S3C SoC
[*] S3C NAND Hardware ECC
make zImage
五、内核添加UBIFS
1、配置内核支持UBIFS
Device Drivers --->
<*> Enable UBI - Unsorted block images --->
2、配置MTD支持UBI接口
File systems --->
[*] Miscellaneous filesystems --->
<*> UBIFS file system support
3、make
4、下载测试
只要出现正常内核分区就说明nand 驱动可以用了。
上一篇:mini6410 2.6.38移植 USB
下一篇:6410 spi 设备驱动
推荐阅读最新更新时间:2026-03-25 14:08
- 使用 Analog Devices 的 ADP3334 的参考设计
- LTC3588IMSE-1 5V 至 16V 太阳能供电 2.5V 电源的典型应用电路,具有用于增加输出能量存储和电池备份的超级电容器
- XRP7659、1.5A DC 至 DC 非同步降压稳压器的典型应用
- 使用 ON Semiconductor 的 NCP3120MNTX 的参考设计
- MAXREFDES1003:150mA、4通道、LED驱动器,SEPIC配置
- LTC4223-2 演示板,用于 AMC 的双电源热插拔控制器(故障后自动重试)
- MC33072ADR2G 运算放大器用作晶体管驱动器的典型应用
- 使用 Diodes Incorporated 的 AP1509-12S 的参考设计
- NCP382HD10AAGEVB:单输入双输出高侧配电开关评估板
- 使用 Analog Devices 的 AD7730 的参考设计
亿芯FLASH烧写_v1.92
stm32移植ucos
现代雷达系统的信号设计
BFR340T
京公网安备 11010802033920号
