datasheet
RT9605/RT9605A应用电路
2014-01-18 10:16:21来源: 互联网 关键字:RT9605  RT9605A  应用电路
The RT9605A is a high frequency, triple-channel synchronous-rectified buck MOSFET driver specifically designed to drive six power N-MOSFETs. The part is promoted to pair with RichTek's multiphase buck PWM controller family for high-density power supply implementation. The output drivers of RT9605A can efficiently switch power MOSFETs at frequency 300kHz typically. Operating in higher frequency should consider the thermal dissipation carefully. Each driver of RT9605A is capable to drive a 3nF load in 30/40ns rising/falling time with little propagation delay from input transition to the gate of the power MOSFET. The device implements bootstrapping on the upper gate with only an external capacitor and a diode required.
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2014/0118/article_23920.html
上一篇:具有正负输出电压的桥式整流电路
下一篇:RT9602应用电路
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
RT9605
RT9605A
应用电路
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
