datasheet
直流电源交换电路
2014-01-10 21:57:57来源: 互联网 关键字:直流电源  交换电路
电路能力测试-1:直流电源交换电路
Circuit Knowledge Test-1: DC-DC Switching Regulator
  1. If MP1580 switching frequency set at 400 KHz, and DC regulator output 5V, then please plot the switching wave-shape at IC pin-3 with line input 12V and 16V.假设MP1580工作在400 KHz,且稳压输出为5V,画出输入电压分别为12V 及 16V时,IC pin-3的正确波形。
  1. Now the DC regulated output is 5V. If we want to change the DC regulated output to 9V, what value of RP86 and RP89 are suitable for this change.目前的直流稳压输出为5V,如果希望提升为9V输出,如何修改RP86 及 RP89的数值。
  1. Explain the charge and discharge functions of MA701, LP15, CP61 components in details. 说明MA701, LP15, CP61元件的冲放电功能。
  1. According to MP1580 switching efficiency chart data: DC 12V input and DC 5V 240mA output will display 85% efficiency. What input current rating will be for 12V supply? 根据MP1580的规格书,当直流12V输入,输出为5V 240mA时,转换效率为85%,计算输入电流值。
  1. Same condition as the Question-4: If MP1580 IC with SOP-8 package dissipation 160°C/W, then what surface temperature will be for MP1580 at 25°C room temperature?同上第四题,MP1580采用SOP-8包装的传热系数为160°C/W,计算其室温25°C时的IC表面温度。
  1. What is the maximum allowable ripple voltage at 5V DC regulated output to assure 40 db S/N if this 5V will supply for a video function IC? 当直流稳压输出5V,用来供应影像电路时,为了确保达到40 db S/N,求其最大容许连波电压数值。
  1. Explain the function of CP59, LP17, LP16 components? 说明CP59, LP17, LP16元件的功能。
试题解答
ANS-1:
ANS-2:
RP86=62K, RP89=1K8.
(R86+R89+R87)/R87 = 5.0/Vref     then Vref=5.0/4.12=1.22
RN86+RN89 = (9.0/Vref * R87) –R87 = 63.8K (62K + 1K8)
RP86=62K, RP89=1K8.
ANS-3:
Switching pulse comes from ICP9 pin-3 and charge through LP15 to CP61 during switching-on duty-cycle. The inductive voltage across LP15 will then charge through DP8 to CP61 during switching-off duty-cycle. (Note that inductive current will produce reverse voltage across coil LP15)
ANS-4:
120 mA
DC input power = 5 * 0.24 / 0.85 = 1.41 W    then DC input current = 1.41/12 = 120 mA.
ANS-5:
58.6 °C
Power loss = 1.41-1.2 = 0.21 W   then Thermal heat rise Tht = 160 * 0.21 = 33.6 °C
Final junction temperature Tj = 25 + 33.6 = 58.6 °C
ANS-6:
50 mVpp.
Because 40 db means 1% level, then 5 Volt d-c only allows for 50 mVpp ripple noise.
ANS-7:
CP59: Boot-straping capacitor for driving output power FET.
LP17: Filter choke for filtering switching pulse generated from ICP9.
LP16: Filter choke for filtering switching noise to reach 40 db noise limit.
关键字:直流电源  交换电路
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2014/0110/article_23424.html
上一篇:LM369的典型应用电路
下一篇:LM396的封装形式
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
直流电源
交换电路
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
