datasheet
MAX1551+MAX9001组成的单节锂离子电池充电电路
2014-01-06 13:57:08来源: 互联网 关键字:MAX1551  MAX9001  锂离子电池
There are many battery shapes that, unfortunately, allow users to incorrectly insert the battery. The simple circuit inFigure 1 gives a single-cell Li-ion battery charger added protection from damage due to backward battery insertion. In the circuit, the MAX1551 linear-mode single-cell Li-ion battery charger delivers the charging current to the cell from either an AC adapter or USB power supply. The MAX9001 is also powered from one of these supplies.
Figure 1. This circuit protects the MAX1551 single-cell Li-ion battery charger from surge current caused by backward battery insertion.
During normal operation, the MAX9001's comparator output is high and the FET is on. When the battery is inserted backwards, the MAX9001's output goes low, a condition that turns the FET off. This blocks the flow of potential battery surge current out of the BAT terminal. The rapid switching of the FET keeps the current surge to less than 50mA; that surge lasts for less than 200ns before dampening, as shown in Figure 2. Connecting the battery in reverse without this external protection would destroy the MAX1551.
Figure 2. The top curve of this oscilloscope capture represents the backward insertion of the battery in the Figure 1 circuit. The bottom curve is the battery current.
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2014/0106/article_22976.html
上一篇:差动输入交流耦合电路
下一篇:带隔离电源的电路设计
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
MAX1551
MAX9001
锂离子电池
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
