datasheet
便携式麦克风前置放大器
2013-11-13 13:13:07来源: 互联网 关键字:便携式  麦克风  放大器
便携式麦克风前置放大器 (Portable Microphone Preamplifier)
Parts:
P1______________2K2  Linear Potentiometer
R1,R2,R3______100K   1/4W Resistors
R4______________8K2  1/4W Resistor
R5_____________68R   1/4W Resistor
R6______________6K8  1/4W Resistor
R7,R8___________1K   1/4W Resistors
R9____________150R   1/4W Resistor
C1______________1΅F   63V Polyester Capacitor
C2,C3,C4______100΅F   25V Electrolytic Capacitors
C5_____________22΅F   25V Electrolytic Capacitor
Q1___________BC560C   45V 100mA Low noise High gain PNP Transistor
Q2___________BC550C   45V 100mA Low noise High gain NPN Transistor
J1_____________Jack socket (Mono 3 or 6 mm.)
Device purpose:
This circuit is mainly intended to provide common home stereo amplifiers with a microphone input. The battery supply is a good compromise: in this manner the input circuit is free from mains low frequency hum pick-up and connection to the amplifier is more simple, due to the absence of mains cable and power supply.
Using a stereo microphone the circuit must be doubled. In this case, two separate level controls are better than a dual-ganged stereo potentiometer.
Low current drawing (about 2mA) ensures a long battery life.
Circuit operation:
The circuit is based on a low noise, high gain two stage PNP and NPN transistor amplifier, using DC negative feedback through R6 to stabilize the working conditions quite precisely. Output level is attenuated by P1 but, at the same time, the stage gain is lowered due to the increased value of R5. This unusual connection of P1, helps in obtaining a high headroom input, allowing to cope with a wide range of input sources (0.2 to 200mV RMS for 1V RMS output).
Notes:
Harmonic distortion is about 0.1% @ 1V RMS output (all frequencies).
Maximum input voltage (level control cursor set at maximum) = 25mV RMS
Maximum input voltage (level control cursor set at center position) = 200mV RMS
Enclosing the circuit in a metal case is highly recommended.
Simply connect the output of this device to the Aux input of your amplifier through screened cable and suitable connectors.
关键字:便携式  麦克风  放大器
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2013/1113/article_20658.html
上一篇:带低音增强的立体声前置放大器电路 (Stereo Pream
下一篇:简单的电子管耳机放大器
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
便携式
麦克风
放大器
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
