Using the DS32kHz with Dallas
2011-12-28 15:08:46来源: 互联网
OverviewThis application note is intended to answer some frequently asked questions about using the DS32kHz TCXO (temperature-compensated crystal oscillator) and Dallas Semiconductor real-time clocks (RTCs).
Using the DS32kHz
The DS32kHz has four pins that are required for operation: VCC, VBAT, GND, and 32kHz_OUT. The VCC, VBAT, and GND are power supply connections and must either be connected to a positive supply or grounded. The 32kHz_OUT signal is intended to drive the X1 input of the RTC. The X2 pin of the RTC should be allowed to float when driving the X1 input with an oscillator.
The DS32kHz ICC and IBAT specifications are measured with no output load. The input characteristics of the oscillator on a RTC will determine how much additional current the DS32kHz will consume. The additional current can significantly increase the size of the battery needed for operation.
Choosing an RTC
Dallas Semiconductor has a wide selection of RTCs from which to choose. Some of these devices were designed using a P-WELL process while the more recent devices have been designed using the first-generation N-WELL process. The second-generation N-WELL RTCs incorporate improvements that reduce the current consumption of the TCXO/RTC combination. The following data shows the current consumed by typical devices from each process. The data were taken at a battery voltage of 3.5V at +25°C.
KEY:
Ind = Individual Currents; DS32kHz with output open, RTC with crystal attached and running.
Direct = DS32kHz driving the RTC X1 input directly.
RC = DS32kHz driving the RTC with a 1MΩ resistor in series with a 100pF capacitor to the X1 input.
Table 1. N-WELL (First Generation)
Mode DS32kHz IBAT (µA) DS1306 IBAT (nA)
Ind 1.60 518
Direct 11.9 386
RC 2.14 584
Table 2. N-WELL (Second Generation)
Mode DS32kHz IBAT (µA) DS1337 ICC (nA)
Ind 1.59 612
Direct 3.73 626
RC 2.11 622
Table 3. P-WELL
Mode DS32kHz IBAT (µA) DS1202 IBAT (nA)
Ind 1.63 625
Direct 87.1 3,410
RC 2.17 685
Note the RTC in each of the aforementioned tables are different RTCs. This accounts for the difference in the clock currents when comparing the tables.
If the RTC has an oscillator-enable bit, the oscillator must be enabled. If the bit is not enabled, additional current will be drawn and the clock might not operate.
Table 4. RTC LIST
P-WELL Devices First Generation N-WELL Devices Second Generation N-WELL Devices
DS1202 DS12885 DS1337
DS12885 DS1302 DS1338
DS1283 DS1305/DS1306 DS1339
DS1284 DS1307 DS1672
DS1384 DS1315
DS14285 DS1500/DS1501
DS1384 DS1315
  DS1602
  DS1670/DS1673/DS1677
  DS1685
  DS1688/DS1689
  DS17285/DS17485/DS17885
Summary
When using P-WELL and first-generation N-WELL RTC devices, use an RC circuit to achieve the minimum possible timekeeping current.
The second-generation N-WELL devices use only slightly more current with an RC circuit
关键字:DS32kHz  Dallas
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2011/1228/article_13664.html
论坛活动 E手掌握
微信扫一扫加关注
论坛活动 E手掌握
芯片资讯 锐利解读
微信扫一扫加关注
芯片资讯 锐利解读
全部
DS32kHz
Dallas
小广播
独家专题更多
TTI携TE传感器样片与你相见,一起传感未来
富士通铁电随机存储器FRAM主题展馆
富士通铁电随机存储器FRAM主题展馆
馆内包含了 纵览FRAM、独立FRAM存储器专区、FRAM内置LSI专区三大部分内容。
走,跟Molex一起去看《中国电子消费品趋势》!
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2016 EEWORLD.com.cn, Inc. All rights reserved
