datasheet
基于CS1500设计的90W高效PFC电源技术
2011-10-26 14:41:43来源: 互联网 关键字:CS1500  PFC  电源
电源和照明镇流器设计.
Digital Power Factor Correction IC
The CS1500 is a high-performance power factor correction (PFC) controller for universal AC input, which uses a proprietary digital algorithm for discontinuous conduction mode (DCM) with variable on-time and variable frequency control, ensuring unity power factor.
The CS1500 incorporates all the safety features necessary for robust and compact PFC stages. In addition, it has burst mode control to lower the light-load/standby losses to a minimum.
Protection features such as overvoltage, overcurrent, overpower, open- and short-circuit protection, overtemperature, and brownout help protect the device during abnormal transient conditions.
The digital controller optimizes the system stability and transient performance, simplifies the PFC design, reduces the external component count and BOM costs. The simple design and minimum cost makes CS1500 the ideal choice for PFC up to 300 watts.
CS1500主要特性:
Digital EMI Noise Shaping
Excellent Efficiency Under All Load Conditions
Minimal External Devices Required
Optimized Digital Loop Compensation
Comprehensive Safety Features
• Undervoltage Lockout (UVLO)
• Output Overvoltage Protection
• Input Current Limiting
• Output Overpower Protection
• Input Brownout Protection
• Open/short Loop Protection for IAC & FB Pins
• Thermal Shutdown
图1.CS1500方框图
图2.CS1500基本应用电路图
应用电路中元件数值表:
90W高效PFC LLC谐振转换器参考设计
CS1500 90W, High-efficiency PFC w/ LLC Resonant Converter Reference Design
The CRD1500-90WLLC circuit has two stages: a digitally controlled front-end PFC and a resonant LLC converter. The CS1500 is a high-performance power factor correction (PFC) controller for universal AC input that uses a proprietary digital algorithm with variable ontime, variable frequency, & DCM, which ensures unity power factor.
The resonant LLC converter uses the L6599A controller in the second stage.
90W高效转换器参考设计主要特性:
Universal Input
– Mains Range: 90~265 VAC
– Line Frequency: 45~65 Hz
Rated Output Specification: 19 V, 90 W
EN6100-3-2 Class-D Compliance
Efficiency: 91% @ 90 W, 230 VAC
Low No-load Power Dissipation
Low PFC Component Count
Board Dimension: 61 mm x 135 mm
图3.90W高效PFC LLC谐振转换器参考设计外形图
图4.参考设计电路图(1)
图5.参考设计电路图(2)
参考设计材料清单(BOM):
关键字:CS1500  PFC  电源
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2011/1026/article_12575.html
上一篇:集成RCC式开关电源器件设计及应用
下一篇:有源和无源滤波器混合并行方案在铁路牵引站谐
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
网友正在学习IC视频
全部
CS1500
PFC
电源
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
