datasheet
基于ADuM6202的5KV隔离双路DC电源转换技术
2011-10-23 14:42:01来源: 互联网 关键字:ADuM6202  隔离  双路DC  电源
ADuM6200/ADuM6201/ADuM62021是5KV隔离双路DC/DC电源转换器和隔离器,包括了两路数字隔离器iCoupler和两路DC/DC转换器isoPower,5.0V输入时可提供绝缘输出5.0V或3.3V,功率高达400W,信号隔离是DC到25MHz(NRZ),主要用在RS-232/RS-422/RS-485收发器,工业现场总线隔离,电源起动偏压和栅极驱动,隔离的传感器接口以及工业PLC等。
图1.ADuM6200/ADuM6201/ADuM62021功能方框图
EVAL-ADuMQSEBZ评估板
The EVAL-ADuMQSEBZ can be used with most Coupler® isolation products in the 16-lead, wide-body SOIC and QSOP packages. The evaluation board supports the common pad positions for power, ground, and I/O pins found in nearly all of the Coupler products and is a configurable board that can be adapted to many Coupler products.
EVAL-ADuMQSEBZ评估板主要特性:
Convenient connections for power through screw terminal blocks
Add-on BNC connector for 50 Ω signal sources
On-board signal routing
Support for signal wrap back
Simple signal paths to reduce transmission line effects
Pull-up and pull-down provided for control lines
Support for isoPower
Project area that supports surface-mount and through-hole devices
图3.EVAL-ADuMQSEBZ评估板外形图
图4.EVAL-ADuMQSEBZ评估板电路图
EVAL-ADuMQSEBZ评估板材料清单(BOM):
图5.EVAL-ADuMQSEBZ评估板布局图
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2011/1023/article_12404.html
上一篇:电容式触摸感应按键设计方案
下一篇:UPS电源、ATX电源与P4电源的区别
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
网友正在学习IC视频
全部
ADuM6202
隔离
双路DC
电源
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
