MAX870, MAX871 开关电容电压反相器
2011-05-30 21:26:59来源: 互联网
The ultra-small MAX870/MAX871 monolithic, CMOS charge-pump inverters accept input voltages ranging from +1.4V to +5.5V. The MAX870 operates at 125kHz, and the MAX871 operates at 500kHz. Their high efficiency (90%) and low operating current (0.7mA for the MAX870) make these devices ideal for both battery-powered and board-level voltage-conversion applications.
Oscillator control circuitry and four power MOSFET switches are included on-chip. A typical MAX870/ MAX871 application is generating a -5V supply from a +5V logic supply to power analog circuitry. Both parts come in a 5-pin SOT23-5 package and can deliver 25mA with a voltage drop of 500mV.
For a similar device with logic-controlled shutdown, refer to the MAX1720/MAX1721. For applications requiring more power, the MAX860 delivers up to 50mA with a voltage drop of 600mV, in a space-saving µMAX package.
MAX870, MAX871 关键特性
  • 5-Pin SOT23-5 Package
  • 99% Voltage Conversion Efficiency
  • Invert Input Supply Voltage
  • 0.7mA Quiescent Current (MAX870)
  • +1.4V to +5.5V Input Voltage
  • Require Only Two Capacitors
  • 25mA Output Current
  • Shutdown Control
  • MAX870, MAX871 应用/使用
    电池供电设备
  • 蜂窝电话
  • 手持终端、PDA
  • 从5V逻辑电源产生本地-5V电源
  • 医疗仪器
  • 小型LCD板
    MAX870, MAX871应用电路
    MAX870,MAX871:典型工作电路
    典型工作电路
    关键字:电容
    编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2011/0530/article_9385.html
    论坛活动 E手掌握
    微信扫一扫加关注
    论坛活动 E手掌握
    芯片资讯 锐利解读
    微信扫一扫加关注
    芯片资讯 锐利解读
    全部
    电容
    小广播
    独家专题更多
    迎接创新的黄金时代 无创想,不奇迹
    迎接创新的黄金时代 无创想,不奇迹
    ​TE工程师帮助将不可能变成可能,通过技术突破,使世界更加清洁、安全和美好。
    TTI携TE传感器样片与你相见,一起传感未来
    富士通铁电随机存储器FRAM主题展馆
    富士通铁电随机存储器FRAM主题展馆
    馆内包含了 纵览FRAM、独立FRAM存储器专区、FRAM内置LSI专区三大部分内容。
    电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2016 EEWORLD.com.cn, Inc. All rights reserved
