datasheet
基于CS4354设计的24位立体声数模转换技术
2011-04-29 16:13:43来源: 互联网 关键字:设计  技术
The CS4354 is a complete stereo digital-to-analog system including digital interpolation, third-order multi-bit delta-sigma digital-to-analog conversion, digital de-emphasis, analog filtering, and on-chip 2 VRMS line-level driver from a 5 V supply.
The advantages of this architecture include ideal differential linearity, no distortion mechanisms due to resistor matching errors, no linearity drift over time and temperature,
high tolerance to clock jitter, and a minimal set of external components.
The CS4354 is available in a 14-pin SOIC package in Commercial (-40°C to +85°C) grade. The CDB4354 Customer Demonstration Board is also available for device evaluation and implementation suggestions.
These features are ideal for cost-sensitive, 2-channel audio systems including video game consoles, Blu-Ray Disc® and DVD players, set-top boxes, digital TVs, and DAB/DMB devices.
CS4354主要特性:
Advanced Multi-bit Delta-Sigma Modulator
101 dB A-wt Dynamic Range
-86 dB THD+N
Single-ended Ground Centered Analog Architecture
– No DC-blocking Capacitors Required
– Integrated Inverting Charge Pump
– Filtered Line-level Outputs
– 2VRMS Full-scale Output
 Low-latency Digital Filtering
 Supports Sample Rates up to 192 kHz
 24-bit I²S Input
 +5 V Analog Supply with Integrated Inverting
Charge Pump and Regulator for Core Logic, and +1.8 V to +5 V Interface Power Supplies
 50 mW Power Consumption
 14-pin SOIC, Lead-free Assembly
图1。CS4354方框图
图2。CS4354典型连接框图
CS4354评估板
Evaluation Board for the CS4354
The CDB4354 evaluation board is a dedicated platform designed to facilitate the evaluation of the CS4354 24-bit, stereo D/A converter. Evaluation requires an analog signal analyzer, a digital signal source, and a +5 V power supply. Analog line-level outputs are provided via RCA phono jacks.
The CS8416 digital audio receiver IC provides the system timing necessary to operate the Digital-to-Analog converter and will accept S/PDIF and EIAJ-340-compatible audio data. The evaluation board may also be configured to accept external timing and data signals for operation in a custom user application during system development.
To accommodate various system configurations, several hardware controls and resistor population options are provided. Current sense resistors allow for easy power calculations during system development.
CS4354评估板主要特性:
 Requires Only a Digital Signal Source and a +5 V Power Supply for a Complete Digital-to-Analog Converter System
 Demonstrates Recommended Layout and Grounding Arrangements
 CS8416 Receives S/PDIF, & EIAJ-340- Compatible Digital Audio
 Header for External PCM Audio
 Single-ended Stereo Analog Outputs
 Power and S/PDIF Error Indicator LEDs
 Hardware Controls: +5 V/3.3 V select for VL, De-emphasis select
 Current Sense Resistors for CS4354 Supplies (VA and VL)
图3。CS4354评估板方框图
图4。CS4354评估板电路图:CS8416 和CS4354
图5。CS4354评估板电路图:电源
关键字:设计  技术
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2011/0429/article_7905.html
上一篇:音频系统噪声源的排除方法
下一篇:基于CS35L01-3设计的2.9W D类音频放大技术
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
设计
技术
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
