MAX2160 ISDB-T应用参考设计
2011-04-21 10:42:43来源: 互联网 关键字:应用  参考  设计
Figure 1. The reference design for the MAX2160 tuner plus demodulator.
Figure 2. System block diagram.
Lab Measurements
Figure 3. Sensitivity measures better than -97dBm. The tradeoff in sensitivity is also shown when an optional WCDMA or cdma2000® rejection filter is added at the RF input.
Figure 4. A WCDMA blocker rejection filter response. To implement on-board coexistence of ISDB-T with a WCDMA system, additional input filtering is required to reject the cellular transmit-band frequencies. The optional reference-design filtering is a combination of two filters, which provide approximately 47dB of attenuation at the cellular transmit band (marker 4).
Figure 5. CDMA-2000 blocker rejection filter response. To implement on-board coexistence of ISDB-T with a cdma2000 system in a handheld application, additional input filtering is required to reject the cellular transmit-band frequencies. The optional reference-design filter provides approximately 42dB of attenuation at cdma2000 transmit frequencies (marker 4).
Additional Measurements
Parameter Conditions Target Measured Units
Maximum Input UHF: Ch. 13, Ch. 33, Ch. 52 0 8.9, 8.2, 7.3 dBm
Adjacent Channel Selectivity
(Desired: -70dBm)
UHF: Ch. 13, Ch. 33, Ch. 52 35 45, 47, 45 dBc
WCDMA Blocker Performance UHF: Ch. 13, Ch. 33, Ch. 52 24 23.5, 24, 24 dBm
cdma2000 Blocker Performance UHF: Ch. 13, Ch. 33, Ch. 52 10 21, 21, 21 dBm
ISDB-T Frequency Plan
Figure 6. The ISDB-T RF signal is broadcast in the UHF band, as shown above. The channel spacing is 6MHz.
Detailed Description
The MAX2160/MAX2160EGB tuner ICs are designed for use in Japanese mobile digital-TV (ISDB-T single-segment) applications. The devices directly convert UHF band signals to a low-IF by using a broadband I/Q downconverter. The operating frequency range extends from 470MHz to 770MHz.
The MAX2160/MAX2160EBG support both I/Q low-IF interfaces and single low-IF interfaces. The devices are thus universal tuners for various digital demodulator implementations.
The MAX2160/MAX2160EBG integrate LNA, RF and low-IF variable-gain amplifiers (VGAs), I and Q downconverting mixers, and bandpass filters providing in excess of 42dB of image rejection. The parts operate with either high-side or low-side local oscillator (LO) injection. The devices' VGAs provide in excess of 100dB of gain-control range.
The MAX2160/MAX2160EBG also have fully monolithic VCOs and tank circuits, and a complete frequency synthesizer. A XTAL oscillator and separate TCXO input buffer are also included. The devices operate with XTAL/TCXO oscillators from 13MHz to 26MHz, which enable the shared use of a VC-TCXO in cellular handset applications. Additionally, a divider is provided for the XTAL/TCXO oscillator, thus allowing for a simple and low-cost interface to various channel decoders.
cdma2000 is a registered trademark of Telecommunications Industry Association.
关键字:应用  参考  设计
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2011/0421/article_7391.html
上一篇:磁性天线与中频变压器的基础知识
下一篇:MAX2118卫星调谐器的扩充噪声系数数据
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
网友正在学习IC视频
全部
应用
参考
设计
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
