datasheet
基于MC1321x系列设计的2.4GHz ZigBee开发方
2011-04-15 17:18:47来源: 互联网 关键字:系列  设计  开发
本文介绍了MC1321x系列主要特性,方框图, 802.15.4标准调制解调器方框图和MCU(HCS08, Version A)方框图,以及13213-网络协调板(NCB)和13213-传感器参考板(SRB)电路图.
Freescale 公司的MC1321x系列是第二代ZigBee平台,集成了低功耗2.4GHz RF收发器和8位MCU,能实现点对电连接到完整的ZigBee mesh网络,是高性价比的完整解决方案.RF收发器和标准802.15.4兼容,工作在2.4 GHz ISM频带,包括有低噪音放大器,1mW输出功率,带VCO的PA,发送/接收开关,电源稳压以及全扩展频谱编码和译码.MCU具有HCS08 Version A特性,并提供多达60KB的闪存和4KB的RAM.
MC1321x系列主要特性:
General Platform Features
• 802.15.4 Standard compliant on-chip transceiver/modem
— 2.4GHz
— 16 selectable channels
— Programmable output power
• Multiple power saving modes
• 2V to 3.4V operating voltage with on-chip voltage regulators
• -40℃ to +85℃ temperature range
• Low external component count
• Supports single 16 MHz crystal clock source operation or dual crystal operation
• Support for SMAC, IEEE 802.15.4 Standard-Compliant MAC, SynkroRF, BeeStack, BeeStack Consumer (ZigBee RF4CE) software solutions
• 9mm x 9mm x 1mm 71-pin LGA
Microcontroller Features
• Low voltage MCU with 40 MHz low power HCS08 CPU core
• Up to 60K flash memory with block protection and security and 4K RAM
— MC13211: 16KB Flash, 1KB RAM
— MC13212: 32KB Flash, 2KB RAM
— MC13213: 60KB Flash, 4KB RAM
• Low power modes (Wait plus Stop2 and Stop3 modes)
• Dedicated serial peripheral interface (SPI) connected internally to 802.15.4 modem
• One external 4-channel (5-channel internal) 16-bit timer/pulse width modulator (TPM) module and one external 1-channel (3-channel internal) 16-bit timer/pulse width modulator module, each with selectable input capture, output capture, and PWM capability.
• 8-bit port keyboard interrupt (KBI)
• 8-channel 8-10-bit ADC
• Two independent serial communication interfaces (SCI)
• Multiple clock source options
— Internal clock generator (ICG) with 243 kHz oscillator that has +/-0.2% trimming resolution and +/-0.5% deviation across voltage.
— Startup oscillator of approximately 8 MHz
— External crystal or resonator
— External source from modem clock for very high accuracy source or system low-cost option
• Inter-integrated circuit (IIC) interface.
• In-circuit debug and flash programming available via on-chip background debug module (BDM)
— Two comparator and 9 trigger modes
— Eight deep FIFO for storing change-of-flow addresses and event-only data
— Tag and force breakpoints
— In-circuit debugging with single breakpoint
• System protection features
— Programmable low voltage interrupt (LVI)
— Optional watchdog timer (COP)
— Illegal opcode detection
• Up to 32 MCU GPIO with programmable pullups
RF Modem Features
• Fully compliant 802.15.4 Standard transceiver supports 250 kbps O-QPSK data in 5.0 MHz channels and full spread-spectrum encode and decode
• Operates on one of 16 selectable channels in the 2.4 GHz ISM band
• -1 dBm to 0 dBm nominal output power, programmable from -27 dBm to +3 dBm typical
• Receive sensitivity of <-92 dBm (typical) at 1% PER, 20-byte packet, much better than the 802.15.4 Standard of -85 dBm
• Integrated transmit/receive switch
• Dual PA ouput pairs which can be programmed for full differential single-port or dual-port operation that supports an external LNA and/or PA.
• Three low power modes for increased battery life
• Programmable frequency clock output for use by MCU
• Onboard trim capability for 16 MHz crystal reference oscillator eliminates need for external variable capacitors and allows for automated production frequency calibration
• Four internal timer comparators available to supplement MCU timer resources
• Supports both packet data mode and streaming data mode
• Seven GPIO to supplement MCU GPIO
Software Features
Freescale provides a wide range of software functionality to complement the MC1321x hardware. There are three levels of application solutions:
• SMAC
• IEEE 802.15.4 Standard-Compliant MAC
• SynkroRF
• BeeStack
• BeeStack Consumer (ZigBee RF4CE)
MC1321x系列应用:
Applications include, but are not limited to, the following:
• Residential and commercial automation
— Lighting control
— Security
— Access control
— Heating, ventilation, air-conditioning (HVAC)
— Automated meter reading (AMR)
• Industrial Control
— Asset tracking and monitoring
— Homeland security
— Process management
— Environmental monitoring and control
— HVAC
• Health Care
— Patient monitoring
— Fitness monitoring
• Consumer
— Human interface devices (keyboard, mice, etc.)
— Remote control
— Wireless toys
图1.MC1321x系列系统级方框图
图2. 802.15.4标准调制解调器方框图
图3. MC1321x MCU方框图 (HCS08, Version A)
图4.MC1321x系列RF参数评估电路图
图5.MC1321x系列带F天线的RF单端口电路图
MC1321x 评估套件 (EVK)
This manual provides a detailed hardware description of the MC1321xEVK which consists of a 13213-Network Coordinator Board (13213-NCB) and a 13213-Sensor Reference Board (13213-SRB).
The functionality of the 13213-NCB and 13213-SRB boards is very similar. The primary difference between the two boards revolves around the peripheral circuits, not in the reference design itself.
The 13213-NCB and 13213-SRB provide all the necessary components to evaluate and use the MC1321x solution. The 13213-NCB and the 13213-SRB are built around the Freescale MC1321x family. The MC1321x family is Freescale’s second-generation ZigBee platform which incorporates a low power 2.4 GHz radio frequency transceiver and an 8-bit microcontroller into a single 9x9x1 mm 71-pin LGA package.
The 13213-NCB and the 13213-SRB are compliant with the following standards:
• FCC standard 47 CFR, part 15, section 15.247
• ETSI EN 300-328-1
• ETSI EN 300-328-2
图6.13213-网络协调板(NCB)外形图
图7.13213-传感器参考板(SRB)外形图
图8.13213-NCB电路图(1)
关键字:系列  设计  开发
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2011/0415/article_7066.html
上一篇:基于RFID(射频识别技术)和语音合成的导游讲解系统
下一篇:移动IP技术在CDMA2000通信中的技术应用及实现
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
全部
设计
开发
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
