RT9711应用电路及参数资料
2011-04-07 21:18:18来源: 互联网 关键字:参数  资料
Theis a low voltage, single N-MOSFET high-side power switch, optimized for self-powered and bus- powered Universal Serial Bus (USB) applications. The RT9711 equipped with a charge pump circuitry to drive the internal MOSFET switch; the switch's low RDS(ON), 80mW, meets USB voltage drop requirements; and a flag output is available to indicate fault conditions to the local USB controller.
Additional features include soft-start to limit inrush current during plug-in, thermal shutdown to prevent catastrophic switch failure from high-current loads, under-voltage lockout (UVLO) to ensure that the device remains off unless there is a valid input voltage present. The maximum current is limited to typically 2.5A in dual ports in accordance with the USB power requirements, lower quiescent current as 25uA making this device ideal for portable battery-operated equipment.
The RT9711 is available in SOT-23-5 and SOP-8 packages requiring minimum board space and smallest components.
• Compliant to USB Specifications
• Built-In N-MOSFET
► Typical RDS(ON) : 80mW (SOT-23-5), 90mW (SOP-8)
• Output Can Be Forced Higher Than Input (Off-State)
• Low Supply Current :
25uA Typical at Switch On State
1uA Typical at Switch Off State
• Guaranteed 1.5A Continuous Load Current
• Wide Input Voltage Ranges : 2.5V to 5.5V
• Open-Drain Fault Flag Output
• Hot Plug-In Application (Soft-Start)
• 1.7V Typical Under-Voltage Lockout (UVLO)
• Current Limiting Protection
• Thermal Shutdown Protection
• Reverse Current Flow Blocking (no body diode)
• UL Approved-E219878
• RoHS Compliant and 100% Lead (Pb)-Free
Application
• USB Bus/Self Powered Hubs
• USB Peripherals
• ACPI Power Distribution
• PC Card Hot Swap
• Notebook, Motherboard PCs
• Battery-Powered Equipment
• Hot-Plug Power Supplies
• Battery-Charger Circuits
Typical Applications Circuit
关键字:参数  资料
编辑:神话 引用地址:http://www.eeworld.com.cn/mndz/2011/0407/article_6619.html
上一篇:高效率升压转换器应用技巧
下一篇:RT9173B应用电路及参数资料
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
网友正在学习IC视频
全部
参数
资料
小广播
独家专题更多
东芝在线展会——芯科技智社会创未来
东芝在线展会——芯科技智社会创未来
2017东芝PCIM在线展会
2017东芝PCIM在线展会
TI车载信息娱乐系统的音视频解决方案
TI车载信息娱乐系统的音视频解决方案
