datasheet
STM32通过io模拟SPI与ADC124S021通信
2019-07-11来源: eefocus关键字:STM32  io  模拟SPI  ADC124S021
/***************************** U11  *********************************/
//extern unsigned int ad_val;
unsigned char ch_temp;
#define AD_FF 1
#define AD_ZF 2
#define AD_MF 3
#define AD_GM 4
#define ADC124S21_CS_PA4_OUT                GPIO_Pin_4            //使用PA4作为输出,控制ADC124S21芯片的片选
#define ADC124S21_CLK_PA5_SCK               GPIO_Pin_5         //使用PA5作为输出,模拟用作ADC124S21的CLK
#define ADC124S21_DATA_PA7_DIN            GPIO_Pin_7       //使用PA7作为输出,连接ADC124S21的DIN
#define ADC124S21_DATA_PA6_DOUT             GPIO_Pin_6                 //使用PA6作为输入,连接ADC124S21的DOUT
#define AD_CS_H GPIO_SetBits(GPIOA,ADC124S21_CS_PA4_OUT)
#define AD_CS_L GPIO_ResetBits(GPIOA,ADC124S21_CS_PA4_OUT)
#define AD_DIN_H GPIO_SetBits(GPIOA,ADC124S21_DATA_PA7_DIN)
#define AD_DIN_L GPIO_ResetBits(GPIOA,ADC124S21_DATA_PA7_DIN)
#define AD_SCLK_H GPIO_SetBits(GPIOA,ADC124S21_CLK_PA5_SCK)
#define AD_SCLK_L GPIO_ResetBits(GPIOA,ADC124S21_CLK_PA5_SCK)
#define AD_DOUTGPIO_ReadInputDataBit(GPIOA, ADC124S21_DATA_PA6_DOUT)
 * 配置用于操作ADC124S21的模拟SPI GPIO端口
int U11ADC124S021_GPIO_init()
   GPIO_InitTypeDef ADC124S21_GPIO_InitStructure;
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
   ADC124S21_GPIO_InitStructure.GPIO_Pin  = ADC124S21_CS_PA4_OUT;   //片选引脚配置
   ADC124S21_GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
   ADC124S21_GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出
   GPIO_Init(GPIOA, &ADC124S21_GPIO_InitStructure);
   GPIO_SetBits(GPIOA,ADC124S21_CS_PA4_OUT);
   ADC124S21_GPIO_InitStructure.GPIO_Pin  = ADC124S21_CLK_PA5_SCK;   //时钟引脚配置
   ADC124S21_GPIO_InitStructure.GPIO_Pin  = ADC124S21_DATA_PA7_DIN;   //DIN引脚配置
   ADC124S21_GPIO_InitStructure.GPIO_Pin  = ADC124S21_DATA_PA6_DOUT;  //DOUT引脚配置
   ADC124S21_GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输出
   return 0;
**函数名称:U11_AD_124S021()
**函数功能:用于AD转换,读取成像镜头与天线位置
**输入变量:channel 通道数;channel=1,则选择通道1;channel=2,则选择通道2.
**输出变量:ad_val,AD转换值
u32 U11_AD_124S021(unsigned char channel)
         unsignedchar ch = 0;
   unsigned char i;
   unsigned int ad_val=0;                                //AD转换值
   AD_SCLK_H;                                //时钟输入端置高
   AD_CS_L;                                              //片选控制端置低,AD转换使能
   __nop();
   __nop();
   __nop();
   if( channel == AD_FF )
       ch = 0x00;   //选择通道1  聚焦值
   else if( channel == AD_ZF )
       ch = 0x08;   //选择通道2  变倍值
   else if( channel == AD_MF )
       ch = 0x10;   //选择通道3  天线电机值
   else if( channel == AD_GM )
       ch = 0x18;   //选择通道4  光敏值
   ch_temp = ch;
   for(i=0; i<8; i++)
       AD_SCLK_L;                                                             //时钟输入置低
       __nop();
       __nop();
       __nop();
       if((ch_temp&0x80)==0x00)
           AD_DIN_L;//通过串行方式输入通道选择
       else
           AD_DIN_H;
       ch_temp<<=1;
       AD_SCLK_H;                                                            //时钟输入置高,在此上升沿DIN实现1位输入
       __nop();
       __nop();
       __nop();
   for(i=0; i<8; i++)
       AD_SCLK_L;
       AD_SCLK_H;
   AD_CS_H;
   ad_val=0;
   AD_SCLK_H;
   AD_CS_L;
   __nop();
   __nop();
   __nop();
   for(i=0; i<8; i++)
       ad_val=(ad_val<<1);
       AD_SCLK_L;
       __nop();
       __nop();
        __nop();
       if(AD_DOUT)
           ad_val++;
       else
           __nop();
           __nop();
           __nop();
       if((ch&0x80)==0x00)
           AD_DIN_L;
       else
           AD_DIN_H;
       ch<<=1;
       AD_SCLK_H;
       __nop();
       __nop();
       __nop();
   for(i=0; i<8; i++)
       ad_val=(ad_val<<1);
       AD_SCLK_L;
       __nop();
       __nop();
       __nop();
       if(AD_DOUT)
            ad_val++;
       else
           __nop();
           __nop();
           __nop();
       AD_SCLK_H;
   AD_CS_H;
   ad_val=(ad_val&0x0fff);
                   //adtest=ad_val;
                   returnad_val;
编辑:什么鱼 引用地址:http://www.eeworld.com.cn/mcu/ic467464.html
上一篇:STM32之SPI与QSPI学习笔记
下一篇:DSP2808与ARM STM32F103的SPI通讯例程及详解
关注eeworld公众号 快捷获取更多信息
关注eeworld公众号
快捷获取更多信息
关注eeworld服务号 享受更多官方福利
关注eeworld服务号
享受更多官方福利
STM32开发笔记20: STM32L053R8T6的keil配置
单片机型号:STM32L053R8T6    使用STM32CubeMX生成STM32L053R8T6相关的应用程序代码后,使用Keil开发环境第1次下载的时候,提示如下错误,我使用F0和F4的单片机,没有遇到过。    仔细查看工程设置,原因在工程设置中,我们需加入相应的Flash配置信息,如下图所示,具体的选择,要根据单片机的类型,我们可以仔细查看数据手册。    但下载的时候,偶尔还会提示如下错误:    这件事情网上说了很多的解决方法,我自己测试,更改2处Keil的设置既可以解决,如下图所示。    此2处更改后,反复
发表于 2019-07-16
STM32开发笔记21: USB驱动的移植
单片机型号:STM32L053R8T6    现在使用的STM32L053R8T6单片机带有USB接口,原先一直使用UART转USB芯片来完成USB功能的支持,现在这款单片机带了就希望使用以下。由于已经建立了自己的工程目录,再重新使用STM32CubeMX生成的工程文件,重新建立是不显示的,所以本文探索将USB驱动文件移植到自己项目中的方法,我使用的是USB的CDCD类,步骤如下:    1、使用STM32CubeMX使能USB,如下图所示:    2、设置时钟,USB需要48M时钟,使用内部和外部均可,我这里使用外部时钟。    3、生成工程文件
发表于 2019-07-16
STM32开发笔记22: 手动添加驱动文件
单片机型号:STM32L053R8T6    我们可以通过STM32CubeMX生成工程代码,但是如果我们的工程已经建立完毕了,或者说我们在原有的工程上,开始新的项目设计,此时又需加入新的驱动,该如何呢?本文探讨其解决方法。    1、STM32CubeMX的驱动路径如下图所示,我们希望加入什么驱动,就直接将其对应的.c文件加入到工程中即可。    2、为了使该模块生效,我们还学将其使能。其使能宏,在stm32l0xx_hal_conf.h中,如下图所示。    3、上述工作完成后,我们就可以对工程进行编译了,至于驱动的具体调用方法,我们可以参看ST
发表于 2019-07-16
STM32开发笔记23: 使用__weak修饰符
单片机型号:STM32L053R8T6在 HAL 库中,很多回调函数前面使用__weak 修饰符。 weak 顾名思义是“弱”的意思,所以如果函数名称前面加上__weak 修饰符,我们一般称这个函数为“弱函数”。加上了__weak 修饰符的函数,用户可以在用户文件中重新定义一个同名函数,最终编译器编译的时候,会选择用户定义的函数,如果用户没有重新定义这个函数,那么编译器就会执行__weak 声明的函数,并且编译器不会报错。 举个例子:我们打开工程模板,找到并打开文件stm32f4xx_hal.c 文件,里面定义了一个函数 HAL_MspInit,定义如下:__weak void
发表于 2019-07-16
STM32开发笔记24:STM32L0低功耗设计——需求概述
单片机型号:STM32L053R8T6    这几篇日志将详细记录,自己应用stm32进行低功耗设计的全过程。    使用芯片:STM32L053R8T6    运行模式:        Range 1:电源电压限制在1.71-3.6V,CPU最大运行频率为32MHz。        Range 2:CPU最大运行频率为16MHz。        Range 3:CPU最大运行频率4.2MHz    低功耗模式:
发表于 2019-07-16
STM32开发笔记25:STM32L0低功耗设计-使用Keil和ST-Link下载程序
单片机型号:STM32L053R8T6    继续项目的开发工作,突然发现,程序不能够正常下载到单片机中了,提示如下图所示的错误,我使用的是keil和ST-Link。    这个问题在我第1次调试的时候发生过1次,我认为是我误操作将芯片烧坏了,因为当时又反复的焊接了一下芯片,也没有修好,就把这件事情放下了。    今天再次出现,自己感觉可能和低功耗有关,仔细查看刚刚下载的程序,里面上来程序就进入低功耗,没有任何退出语句,所以应该是CPU不响应下载命令了。    按照这种思路,先将单片机的复位引脚接地,然后点击下载按钮的同时,放开复位引脚,居然成功
发表于 2019-07-16
小广播
何立民专栏
单片机及嵌入式宝典
电子工程世界版权所有 京ICP证060456号 京ICP备10001474号 电信业务审批[2006]字第258号函 京公海网安备110108001534 Copyright © 2005-2019 EEWORLD.com.cn, Inc. All rights reserved
